Old 01-13-2010, 12:21 PM   #676
tom_chang79's Avatar
Originally Posted by aktug78 View Post
Hello, tamiya advises this part as a option part(53952 Center One-Way Set for Porsche Type 934 ), what is tihis part for?
It's to allow your fronts to continue spinning even though you applied brakes... So essentially, on-power, you'll have all four wheels spinning, during braking, you will have rear brakes but not the front. It makes it so off-power, it feels like a rear wheel drive vehicle...
Originally Posted by slolx50 View Post
Has anyone come up with a list of parts to convert the IFS to the IFS Ver2?
And does anyone see any benefits to changing the IFS-R to the Ver2 tub/suspension/motormount parts?
As far as I can tell, the chassis, motor mount, pulleys, and new belts... Everything else seems like an TA05, TA05-IFS, TB03, 415/416 parts... Also remember to get the individual hinge blocks. The Version 2 uses two sets of individual hinge blocks with two sets of the 416 hinge blocks... Oh pivot balls too. Can't have enough of those...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 01-13-2010, 12:50 PM   #677
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Akudou View Post
Does 53994 body post mounts shifted away from the original position? I got the other one and now i didnt wanna install it since the body post got shifted wider apart. most of my shells are made for the original post position.
Yes they are wider apart but that can be looked at as better stability on the body. Don't be worried about lining up the body because the front mounts give you the positioning, but need to put the body posts on the other side because they bottom out on the turnbuckles. Thats what I needed to do because I was using the 1mm down spring retainers and there was barely enough room to clear with a ride height of 5.5mm rear. All in all definitely get the IFS stay.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-13-2010, 04:53 PM   #678
What sort of GT bodies can we take advantage of with the IFS/version2 style laydown shock? So far, all I know is the NSX, but there's gotta be other bodies that can take advantage of this low profile right?
RIP TAP RC
Old 01-13-2010, 05:24 PM   #679
Akudou's Avatar
Thanks. I guess it does help alot but it doesnt help my shells which already have bodypost holes that fits the original body post position. When i say shells, i say around 13 to 14 of my shells. That would means i have to do all of them if i was to adapt the wide body post of the carbon rear damper stay.
Akudou is offline   Reply With Quote
Old 01-13-2010, 05:25 PM   #680
Akudou's Avatar
Saw a few shells which would make good GT bodies with low nose profiles are the Xanavi GT-R35, Corolla Axio and the Lexus SC-430
Old 01-13-2010, 09:32 PM   #681
Akudou's Avatar
Am running 11.5t Team powers Brushless motor. Anyone tried 11.5t and may i know what FDR you guys are using?
Old 01-14-2010, 12:09 AM   #682
Pingers's Avatar
My favorite IFS body is #51292 Tamiya EBBRO 350R
Pingers is offline   Reply With Quote
Old 01-14-2010, 05:29 AM   #683
Trader Rating: 114 (100%+)
My TA05V2 with Upgrade pack came in yesterday! Woohoo! Noe I need the rest of my parts!
Chris Furman is offline   Reply With Quote
Old 01-14-2010, 09:53 AM   #684
Send a message via MSN to aktug78
[QUOTE=tom_chang79;6848344]It's to allow your fronts to continue spinning even though you applied brakes... So essentially, on-power, you'll have all four wheels spinning, during braking, you will have rear brakes but not the front. It makes it so off-power, it feels like a rear wheel drive vehicle...
Thanks for ur answer, so its suitable for drifting or like a handbrake, isnt it?
aktug78 is offline   Reply With Quote
Old 01-14-2010, 11:36 AM   #685
slolx50's Avatar
So does anyone have an opinion about which car would be better, the VerII or IFS-R?
Thanks!
www.TheRCShack.com <----Check them out!
slolx50 is offline   Reply With Quote
Old 01-14-2010, 12:30 PM   #686
Any Tamiya is good! It is all about how YOU drive it!
Old 01-14-2010, 05:20 PM   #687
Default New guy checking in with a ?
Hi all,
Been lurking here for a while and have read this thread and the old IFS thread. Lots of good info here and you all are very thorough and timely with your answers.
I am racing my V2 on carpet in the stock class. I want to put CVD's on the front. I have the aluminum outdrives on the inside of the of the drive shafts. I mistakenly ordered Tamiya part number (84007) thinking it was the front 46mm CVD's but it is the light weight rear swing shafts. Can they be used on the front? If so, what part number do I need to complete the CVD's? If they cannot be used on the front, what part numbers should I buy for the front CVD's?
woodys3b is offline   Reply With Quote
Old 01-14-2010, 05:35 PM   #688
Originally Posted by woodys3b View Post
Hi all,
You only run the lightweight in the rear, never in the front. They will get bent in the first few laps.. It'll be like throwing your money out the window.
You need part 51092
Old 01-14-2010, 05:42 PM   #689
<PsOp>
Guest
Posts: n/a
I have a ta05r and want to convert into IFS what parts do I need to get. Where do you guys order your Tamiya hop-ups at?
Old 01-14-2010, 06:14 PM   #690
1. I did a search, and found it posted 3 times what parts to buy. Search the on-road forum.. IFS conversion
2.
SPEEDTECHRC.COM
AMPDRAW.COM
and.. EBAY!
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
