Old 12-15-2009, 11:21 PM   #451
thats a transponder mount.
DA_cookie_monst is offline   Reply With Quote
Old 12-16-2009, 08:40 AM   #452
gashuffer's Avatar
Trader Rating: 48 (100%+)
You don't use that. It's a outdated PT mount.
gashuffer is offline   Reply With Quote
Old 12-16-2009, 09:46 AM   #453
TwoTone's Avatar
Originally Posted by Pingers View Post
I can't find this piece in the manual anywhere. Is this a Tamiya wrench? I can't figure out what it's for.
I don't have personal experience, but just letting you know that I read that those purdy clear pieces aren't as strong as the normal black plastic.
TwoTone is offline   Reply With Quote
Old 12-16-2009, 10:01 AM   #454
Akudou's Avatar
I believe thats the TA-05 limited edition parts. Correct me if im wrong but since this is a V.2 page, some of that clear blue parts will not fit on the V.2
Akudou is offline   Reply With Quote
Old 12-16-2009, 01:38 PM   #455
Pingers's Avatar
I don't think any of those parts in particular would have a problem fitting. Bumper parts, body mounts & battery strap? I don't think those were changed on the V2.
Pingers is offline   Reply With Quote
Old 12-16-2009, 01:39 PM   #456
Pingers's Avatar
Thanks man - I only bought them for the body posts. If they snap - Ohwell.
Old 12-16-2009, 02:09 PM   #457
tom_chang79's Avatar
Cookie monster beat me to it, but yeah, I say that's a transponder mount. It's not used in the V2...
Originally Posted by Skitee View Post
You could possibly go to a 108tooth spur
I thought more like 96 to 98T. But Skitee, you're the TA05 v2 expert! The 96T 64-pitch gear's outer diameter seemed closer to the kit's spur, but I'm not sure until what point will the gear protrude out the bottom...
Do you need to run a lower FDR? I'm running 4600Kv Castle in mine, have it geared with kit's Spur/Pinion (which is about 7.5 I think?) and the motor NEVER comes off hot... I think the little scoop below the motor also helps with the motor temp...
The ESC is a Mamba Max, which fits snug in the ESC mounting section, and the MM can take some heavy beating Wattage/Heat-wise. I've put that ESC through some torture...
64p. How far up you think this will go?
My guess is 98T at the max, 96T to be safe, but Skittee is much more knowledgeable, I'm just a novice with this chassis...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-16-2009, 05:33 PM   #458
Akudou's Avatar
I have personally installed the 96, 100 and 105 with ease and was wondering if it can go any higher. Am looking for a 108T to install.
Old 12-16-2009, 07:18 PM   #459
Pingers's Avatar
What size pinion are you running with a 105 spur?
Old 12-16-2009, 08:18 PM   #460
Akudou's Avatar
Have fitted size 28 & 29 so far for my drift setting while on TC i have fitted 34-39. but on 100t spur you will be able to fit only 26 the lowest.
Old 12-16-2009, 10:08 PM   #461
105? That's great info. You're talking about the 64 pitch size and not the metric 0.4 Tamiya size right?
RIP TAP RC
Old 12-16-2009, 10:33 PM   #462
Akudou's Avatar
Yes, it's the 64 pitch size.
Old 12-17-2009, 10:38 AM   #463
gashuffer's Avatar
Some updated pics of my v.II
Old 12-17-2009, 09:04 PM   #464
Pingers's Avatar
Looking good! So does the V2 not come with a sway bar kit or do you guys just not run them in the GT class.
Old 12-17-2009, 11:17 PM   #465
Skitee's Avatar
Correct the Ver.II kit does not come with sway bars
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
