Old 12-14-2009, 02:13 PM   #436
gashuffer's Avatar
Trader Rating: 48 (100%+)
TA05
gashuffer is offline   Reply With Quote
Old 12-14-2009, 02:18 PM   #437
How much narrower is the V.2 chassis compared to the original?
DA_cookie_monst is offline   Reply With Quote
Old 12-14-2009, 04:18 PM   #438
gashuffer's Avatar
3mm
Old 12-14-2009, 06:06 PM   #439
Pingers's Avatar
Originally Posted by tom_chang79 View Post
More toe-in in the rear helps your car square up when coming you come out of a turn and throttling it...
Curious, that's not a V2 chassis is it? The V2 has those "individual" blocks for the hinges that are closer to the battery. Which chassis is that???
TA05, I post here 'cause it's way more active than the TA05-IFS forum and I know awesome you guys are with answers.
Pingers is offline   Reply With Quote
Old 12-14-2009, 09:04 PM   #440
tom_chang79's Avatar
There's a lot of hardcore TA05 guys in here. I'm just a beginner, and apprentice of this chassis!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-14-2009, 09:06 PM   #441
This chassis is underrated. It's your poor-man's TRF415/416, but yet costs about 1/4 the price almost...
Except when you start adding the blue stuff... and the CF stuff...
I like this chassis, it's really smooth...
One thing I did notice about touring cars in general on asphalt track, our cars are like a vacuum cleaner! It sucks up all the rubber bits... I think my TA05 picks up more junk off the track than my off-road vehicles...
RIP TAP RC
Old 12-14-2009, 10:30 PM   #442
Akudou's Avatar
Anyone knows how high the spur can be installed on the verII? I can get it to go at 105 but wondering if it can go any higher.
Akudou is offline   Reply With Quote
Old 12-14-2009, 11:08 PM   #443
Just a quick questions, when you turn 1 of the wheel, will all your will turn freely (smooth)?
I have this problem when I tighten my wheel nuts. I've loosen it. Any other things to take note?
mezan is offline   Reply With Quote
Old 12-14-2009, 11:34 PM   #444
Skitee's Avatar
Just something to take note of if you are running the plastic wheel hexes, if you over tighten the wheel nut then you squash the wheel hex and it binds/rubs against the hub.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-15-2009, 02:12 AM   #445
Which pitch are you talking about? The 0.4 pitch or the inch-based pitches, 48p, 64p?
It seems like the kit's spur in 0.4 pitch is as high as it goes... Maybe a tooth or two more before it sticks out underneath?
I would use that as the major diameter you can fit if you're doing other pitches...
RIP TAP RC
Old 12-15-2009, 02:42 AM   #446
Are the cells much closer in to the venter line, or have they managed to move the motor in?
Old 12-15-2009, 03:30 AM   #447
Akudou's Avatar
64p. How far up you think this will go?
Old 12-15-2009, 04:19 AM   #448
Skitee's Avatar
You could possibly go to a 108tooth spur
Old 12-15-2009, 07:41 PM   #449
Pingers's Avatar
I run a FUTABA 3PM Radio System 2.4GHz w/ R603FF. Can I just pick up an additional R603FF or R603FS receiver and use the same radio for my on-road.
Also what speed control\motor are you guys running for those in the 17.5 stock class.
Old 12-15-2009, 10:07 PM   #450
Pingers's Avatar
I can't find this piece in the manual anywhere. Is this a Tamiya wrench? I can't figure out what it's for.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
