Old 12-03-2009, 08:35 AM   #391
gashuffer's Avatar
Trader Rating: 48 (100%+)
For sale ready to lay the smack down.
TA05v.II New
gashuffer is offline   Reply With Quote
Old 12-03-2009, 09:39 AM   #392
Pingers's Avatar
[QUOTE=gashuffer;6672611]For sale ready to lay the smack down.
[QUOTE]
You never replied to my PM, I was really interested in this.
Pingers is offline   Reply With Quote
Old 12-03-2009, 05:52 PM   #393
Akudou's Avatar
Saw the pic of your verII and was impressed on what you have installed on it. The Carbon rear shock tower from IFS fit on it?
TA05v.II New
Akudou is offline   Reply With Quote
Old 12-03-2009, 08:25 PM   #394
Akudou's Avatar
Anyone installed the tamiya's stabiliser bar for TA05? Got myself Tamiya's stabiliser bars and when i tried installing it according to the manual i find some problems installing it to the front lower arm. Does anyone have any step by step pictures on installing it or does anyone have a closeup pic of the whole front part?
Old 12-03-2009, 09:20 PM   #395
What issue are you having ?
I have the 53842 set and from what I remember it fitted as per the attached instructions. I recall there was also some notes in the original manual at the back (where hop ups are ) , that you had to cut the black plastic or something.
I am not at home now , so no pics , but have a look at the original manual too ....
I am not sure if the V2 has the same assembly instructions as the IFS
gimpex is offline   Reply With Quote
Old 12-03-2009, 10:13 PM   #396
Akudou's Avatar
I have problems where i dont know which black plastic parts i have to cut on my ver2. I have the same stabiliser set as you have but still having a headache on where that part should be cut at.
Old 12-03-2009, 11:41 PM   #397
Super Moderator
Grizzbob's Avatar
I'm not sure if the original TA05 sway bar kit can fit right(though I'm not saying it won't), but I know that I used the same set that works on the TRF cars(415, 416, etc.), because its mounts were meant for the reversible suspension arms(which the ver.2 uses), & they fit & work perfectly.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-03-2009, 11:44 PM   #398
Skitee's Avatar
The TA-05 sway bar kit is the correct part, he just needs to cut plastic part A1 at the front so that the sway bar doesn't bind in the front.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-04-2009, 12:15 AM   #399
Akudou's Avatar
Some pics would be a very big help to me bro.
Old 12-04-2009, 12:30 AM   #400
Skitee's Avatar
Shape the red sections so that they don't interfere with the sway bar
Old 12-04-2009, 02:09 AM   #401
tom_chang79's Avatar
Sweet, good info since I'm planning to get a sway bar too. 4wd *should* run sway bars in the rear at least for a track with good traction.
Do you guys run both the front and rear?
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-04-2009, 02:34 AM   #402
Old 12-04-2009, 03:37 AM   #403
Akudou's Avatar
Thanks. Just realised from your pic that you are using upright suspension system. Wondering if anyone using the IFS suspension system installed the sway bar before?
Old 12-04-2009, 03:46 AM   #404
Yep , I have an IFS.
Maybe try posting a pic to show us what problem you are having.
Old 12-04-2009, 04:56 AM   #405
Skitee's Avatar
That isn't a pic of my car, I had to make the same change on my standard TA-05R and on my Ver.II
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
