Old 11-15-2009, 05:55 PM   #331
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Akudou View Post
Had a few options part installed on my ver 2 such as seperate suspension mounts, steering set, rocker arm set, pinions and gears. Am planning to get the Tamiya's option part front bulkhead from the ifs as that seems to be the correct fit. Does anyone knows the option part number for the rear bulkhead that fits the ver 2?
It's the rear bulkhead of the TA05. I don't know the part number but you can do a google search and it will come up.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-15-2009, 06:52 PM   #332
RandomFellow's Avatar
53990
http://www.tamiyausa.com/product/ite...oduct-id=53990
RandomFellow is offline   Reply With Quote
Old 11-15-2009, 08:32 PM   #333
Akudou's Avatar
Thank you very much for the prompt replies. Am goin to sort it out to see if theres any available in the stores. Shouldnt be long to have my ver II fully hopped. Am still awaiting for the TRF shocks in stocked at our local store.
Akudou is offline   Reply With Quote
Old 11-15-2009, 10:39 PM   #334
tom_chang79's Avatar
Originally Posted by FX Racing View Post
Does anyone know if 3 Racing makes a carbon graphite chassis for the V2? If so what other parts will I need to upgrade like bulkheads etc and has anyone had any luck with ceramic diff balls, are they better than the tungsten diff ball set? Thanks
As far as I know, they don't. Don't get confused with the 3Racing chassis that's labeled as "Version 2." It's confusing, but it's "Version 2" for 3Racing and not in reference to Tamiya's TA05 version 2 car...
I guess I'm going to get a 64-pitch, 96T spur for mine...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 11-15-2009, 10:56 PM   #335
Anyone interested in the Subaru Dunlop Cusco Body set that came with the kit? I've ordered an HPI 97 Honda Accord body set (this thing was almost as hard to find as Tamiya's PIAA/JACCS Accord body set) for this car so I don't need it.
The body set comes with NIP Wing, Side mirrors, and Decals, including the body of course
PM me if you're interested, I'm looking to sell it for cash or trade for another NIP body set...
RIP TAP RC
Old 11-15-2009, 11:11 PM   #336
Ok, is it just me, or is the battery hold-down bar VERY flimsy? Should I just buy a CF one and get it over with? Will a DB-01 battery hold down work? The DB-01's looks ALOT beefier...
RIP TAP RC
Old 11-16-2009, 09:56 AM   #337
gashuffer's Avatar
The stock battery hold down is just fine. Resist the temptation to spend
T-Sal
Old 11-16-2009, 05:09 PM   #338
Akudou's Avatar
My ver2 had a slight impact last night and upon that i found that the screw of the king pin had come off and when i tried to screw it back on, the thread was loose. Now i had to use threadlock to secure it temporarily. Does anyone know the part number or hopup part for the front c-hub?
Old 11-16-2009, 05:37 PM   #339
FX Racing's Avatar
What about the TB03 chassis made by 3 Racing, reason I ask is because at the track i raced at wore a hole near the motor(this happened with alot of cars) or a carbon reinforced chassis?
FX Racing is offline   Reply With Quote
Old 11-16-2009, 07:01 PM   #340
over gear's Avatar
Trader Rating: 15 (100%+)
pm MikeR . he's working on something like these. http://www.exotekracing.com/HOME.html
over gear is offline   Reply With Quote
Old 11-16-2009, 09:08 PM   #341
As far as I know, TB03 and the TA05 are totally different cars... TB03 is shaft driven, I don't think it would fit...
As for the Exotek stuff, they look real trick! I wouldn't mind holding out for a nice Exotek stuff. I've seen quite a few TC5 owners using their stuff...
RIP TAP RC
Old 11-16-2009, 09:26 PM   #342
Akudou's Avatar
Does anyone know the part number (be it originial or hopup part) for the front c-hub of ver2?
Old 11-16-2009, 10:19 PM   #343
Look in manual for original
F part plastic - 51293 ( left and right together)
Hopup , blue alu from 3racing TA05-IF16/LB
Note :same parts as for IFS
Personally I would reccommend plastic in front. My original IFS is as blue as possible but in front I went back to plastic parts ( except for bulkhead) and titanium for turnbuckles... I found alu to break or bend a lot easier
gimpex is offline   Reply With Quote
Old 11-16-2009, 10:27 PM   #344
Let me post this here as the IFS thread is very slow these days - applies to V2 also , but with a 37T instead .
Is there any advantage (or otherwise) to using the wide pitch 36T pulley ( 49472 ) as a replacement for the standard white kit pulley. The wide pitch one , has every second tooth missing , and from the side it only has holes for the balls with a rim where the original pulley has other holes on the outer perimeter.
I bought it as a replacement for the rear , but the question applies to front or rear.
Old 11-16-2009, 11:11 PM   #345
Skitee's Avatar
The wide pitch pulley supposedly allows the drivetrain to be more efficient since less belt teeth are in direct contact with the pulley and hence less friction is generated, apparently they're only to be used in stock classes (10.5/13.5/17.5/21.5) because the extra torque generated by mod winds just ends up ripping the belts to shreds.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
