Old 10-10-2009, 02:12 AM   #256
bl4
bl4's Avatar
Originally Posted by cheehtae View Post
loosen your rear diff a bit, maybe it's too tight. Front diff should be a little tad tighter than your rear. also ck your spring rates.
Check on the diff but still the same. Try putting 3mm spacer on the rear separate suspension mounts, 3mm spacer(inside), 1mm spacer(outside)for the rear upper arm, front yellow spring & stabilizer, rear red spring & stabilizer, 2mm spacer front upper arm. suspension mount front - 0 , rear - 2.5. Any comments?
bl4 is offline   Reply With Quote
Old 10-11-2009, 12:02 AM   #257
bl4
bl4's Avatar
Is Front 6mm, Rear 5mm correct setting for the ride height? Thks!
Old 10-11-2009, 07:02 AM   #258
cheehtae's Avatar
Trader Rating: 15 (100%+)
rear should be always higher than the front, or same height at least. That's how I set-up my car.
http://home.scarlet.be/~be067749/58/tc/print.htm
http://www.competitionx.com/rc-tuning-guide.nxg
see if this links would help
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-11-2009, 10:06 AM   #259
bl4
bl4's Avatar
rear should be always higher than the rear, or same height at least. That's how I set-up my car.
Thks for the info!
Old 10-11-2009, 12:33 PM   #260
so you mean front should be lower than the front , or same height at least ??????
gimpex is offline   Reply With Quote
Old 10-11-2009, 01:27 PM   #261
cheehtae's Avatar
That's how I would set up my car, that's how set up my car. I don't ussually go below 5 in the front and my rear would be 5.5 - 6 depending on track surface.
Old 10-11-2009, 07:32 PM   #262
bl4
bl4's Avatar
What is the parts number for C-C setting for the front?
Old 10-13-2009, 09:06 PM   #263
Kevin CBR's Avatar
Originally Posted by Racecrafter View Post
You would be correct Sir!
(Belt cars are slow..... )
Jimmy
And shaft cars, are, well, shaft cars.
Kevin CBR is offline   Reply With Quote
Old 10-14-2009, 01:35 AM   #264
Skitee's Avatar
Hi your C-C isit #54174(1C-1XC) and #54071(1C)? Thks!
Yes that's correct
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 10-20-2009, 07:14 AM   #265
FX Racing's Avatar
Hi
Im looking at racing my TA05 Ver II in stock class(17.5 Brushless) does anyone have a general race setup that works well with lipos? Any help would be greatly appreciated.
FX Racing is offline   Reply With Quote
Old 10-23-2009, 01:35 AM   #266
tom_chang79's Avatar
I'm planning to get a TA05 ver. II soon. I'm not too big of a fan of the Subie Cusco body. Would anyone here be willing to trade me a unpainted body for body for the Cusco?
I'm looking for a unpainted NSX or a Skyline R34 body...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 10-23-2009, 04:54 AM   #267
Akudou's Avatar
Am looking to upgrade more parts on my V2. Currently i have upgrade a few parts including the front universal using the TB03 parts. However i fear the rear wouldnt fit. Anyone have the option part number for the rear universal as well as option part number for the other hop ups? Thanks in advance
Akudou is offline   Reply With Quote
Old 10-23-2009, 06:00 AM   #268
slakr's Avatar
Trader Rating: 25 (100%+)
53724 - Tamiya TB Evo IV 46mm Swing Shaft (Lightweight)
51092 - Tamiya 46mm SWING For TB Evo.IV/TRF415MS
53919 - Tamiya TA05 Alu. Differential Joint Set
49425 - Tamiya TA05 Aluminum Diff Joint (Blue)
42102 - Tamiya TRF Special Damper Set (Hard BK)
54095 - Tamiya TB-03 Racing Steering Set
53877 - Tamiya TA05 Front Direct Coupling
54023 - Tamiya 37T One-Way Pulley
54083 - Tamiya Short Reversible Suspension Set
53883 - Tamiya TA05 Carbon Steering Plate (w/bearing & hardware)
XRAY XB2, XB2T ~ TLR 22-4 2.0 ~ Mugen MBX7TR Eco ~ JQ THE eCar WE, THE Car WE
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 10-23-2009, 12:57 PM   #269
greymachine's Avatar
You might already know this, but a new V2 kit is coming out, the Corolla Axio.
greymachine is offline   Reply With Quote
Old 10-23-2009, 08:41 PM   #270
bl4
bl4's Avatar
Originally Posted by Skitee View Post
Yes that's correct
Thks alot!
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 10:33 PM
SEO by vBSEO 3.5.0
