Old 09-22-2015, 10:56 AM   #2566
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Did somebody mention my name?
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 09-22-2015, 11:24 AM   #2567
SagadSetup's Avatar
Originally Posted by PC232 View Post
Hi all..
I new this hobby RC 1/10..
I just brought TAMIYA TA05 ver2 just done building...
hope any best recommended setup on road high speed..
1.chassis setup
2.ESC,Motor,Heat sink,
3.Damper
4.Servo
5.Battery and Charger
6.Pinion,Spur,Moter Gear
7.Tire and Wheel
8.Radios and Receiver
Yes, everything that my friends littleZEN and sakadachi has pretty much everything covered specially the o-rings. Thanks Sak!
In addition, I'd like to share these links:
https://www.tamiyausa.com/articles/t...e#.VgGW9PlVhBd
https://www.tamiyausa.com/articles/l...test_setup.pdf - set up sheet
You said high speed road? Like parking lot runs? or do you plan to race it?
Old 09-23-2015, 09:24 AM   #2568
sakadachi's Avatar
Yeah, no problem and thanks for the follow through. I worked on my M-Four last night and re-did the rear diff oil weight so ordered more of those Kyosho o-rings since I was down to my last pack. It's real handy to have a a couple of those 37T pulley oil diffs for quick swaps with different oil weights. I use AE oil and have 100k, 50k, 10k, 7k, 5k, 3k diffs on hand
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 09-23-2015, 11:28 PM   #2569
Super Moderator
Grizzbob's Avatar
Originally Posted by littleZEN View Post
I'm sure Sagadsetup, aka Mr. TA05 will confirm but the stock v2 came with ball diffs I believe.
Here is a good place for info to get started:
http://www.petitrc.com/reglages/tami...TamiyaTA05.htm
And finally, there's already a TA05 thread to answer all your questions:
Tamiya TA05 Touring Sedan
True, & there's also already a ver2 thread, which is why I merged the new one with it...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-25-2015, 07:30 PM   #2570
SagadSetup's Avatar
Nowadays it's hard to find a TCS legal full hopped up TA05 V2. The bulkheads alone are difficult to find. IF you do find it, it's pricey.
Even the carbon reinforced chassis is nowhere to be found...
Old 09-28-2015, 01:14 PM   #2571
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i've been trying to track down the rear bulkhead for a while and can't find it anywhere... got the front one, and the chassis - just need the rear bulkhead to be good
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-28-2015, 01:35 PM   #2572
MD
MD's Avatar
Trader Rating: 113 (100%+)
Do you mean part number 51208?
MD is offline   Reply With Quote
Old 09-29-2015, 09:32 AM   #2573
k_bojar's Avatar
i got those parts, i was referring to the rear aluminum bulkhead
Old 09-29-2015, 10:15 AM   #2574
SagadSetup's Avatar
It's part number 53990. I have been searching hi and low for these parts.
I did find one from ewippler but it's gold.
I am actually tempted to buy it. My TA05 will turn out to be blue-gold. Lol.
I wouldn't mind as long as it's TCS legal.
Gotta save for it...
Old 09-29-2015, 11:29 AM   #2575
Hi guy...
can TAMIYA TA05 VER2 change to drift car..?? if can..
which part must change...thx very much..
PC232 is offline   Reply With Quote
Old 09-29-2015, 12:58 PM   #2576
MD
MD's Avatar
http://shopping.rcmodel.hk/parts-ep-...d-p-11129.html
http://www.fusionhobbies.com/product...inium-bulkhead
http://tamiya-au.com/shop/en/86969-t...-bulkhead.html
http://skybluehobby.com/catalog/prod...head+(%2353990)
https://translate.google.com/transla...87&prev=search
http://dynamic.carletontechnologies....90&data=Tamiya
i found the above, but they may be out of stock or too expensive.
Old 09-29-2015, 01:06 PM   #2577
SagadSetup's Avatar
Ouch...
Thanks for the input @MD.
Which of these shops are the "most reliable" to buy from? Not including fusion hobbies.
Old 09-29-2015, 01:21 PM   #2578
SagadSetup's Avatar
Hi guy...
Parts to change:
1. Buy a set of drift wheels and tires
2. Remove drive belt in front.
3. Add more negative camber front and rear
That's for starters only. You can further enhance your car's performance buy buying more parts to which I don't have much knowledge of.
Enjoy.
Old 09-29-2015, 01:21 PM   #2579
MD
MD's Avatar
Ouch...
You're welcome. Unfortunately, I don't no anything about them.
Old 09-29-2015, 01:25 PM   #2580
SagadSetup's Avatar
If I had a full hopped up TCS legal TA05 V2, I'd keep it... To me, it's one of Tamiya's greatest cars.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
