Old 05-13-2015, 01:59 PM   #2521
KA2AEV's Avatar
Sak
Im not sure what the M04 looks like mechanically, Ive never seen one
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 05-13-2015, 08:35 PM   #2522
ThePanda's Avatar
Trader Rating: 64 (100%+)
yes, it would be very similar to a ta05 m 4 chassis, driveline wise. The m 4 uses a gear diff stock and the v2 uses a ball diff un less you swapped it out.
ThePanda is offline   Reply With Quote
Old 05-14-2015, 05:57 AM   #2523
KA2AEV's Avatar
Originally Posted by KA2AEV View Post
Okay guys Im not sure if I have a problem with my Ver2 build or I screwed the pooch somehow
I was installing the rear end last night and the dog bone and setup for the left rear
seems really tight almost to the point where I could say the dog bone isn't sitting in the axle properly
Any thoughts on if I could have put that dif together wrong or something else???
Mike
Anyone have any thoughts on this?
Oh and By The Way
Old 05-14-2015, 07:37 AM   #2524
Check the diff, to see if it is assembled correctly. You may have the diff screw, nut and spring in the wrong diff halves.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 05-14-2015, 07:59 AM   #2525
sakadachi's Avatar
Oh I see... Thanks for the info! I guess if you don't have the oil gear diff then my response is VOID.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 05-14-2015, 08:22 AM   #2526
Trader Rating: 18 (100%+)
can you post a pic?
back9monsta is offline   Reply With Quote
Old 05-14-2015, 09:53 AM   #2527
KA2AEV's Avatar
Thanks Mooby will do
Monsta I'll try to put a pix up but it looks normal its just tight!
Oh and By The Way
Old 05-14-2015, 10:57 AM   #2528
There is a right/wrong side the t-nut goes in. The instructions show that the diff halves flip from one picture (fig 1) to the next (fig 2).
Old 05-14-2015, 12:22 PM   #2529
KA2AEV's Avatar
Okay gotta look into that
That kind of makes sense
Thanks again
Oh and By The Way
Old 05-14-2015, 02:11 PM   #2530
KA2AEV's Avatar
You called it, that's exactly what I didn't pick up
You would think that after the ball diffs I've built for our mini 03 n 05 that I would have noticed that!
I hope that someone at Tamiya picks that screwup in the drawings that you found
Thank You Mooby!
Oh and By The Way
Old 05-14-2015, 07:05 PM   #2531
Thank You Mooby!
If you look closely, the cartoon arrow twists.
Glad I could help. Putting the finishing touches on my Gold Ed. v2. I went w/ the gear diffs.
Old 05-15-2015, 04:32 AM   #2532
KA2AEV's Avatar
Wow
After looking at it I figured out why I never noticed that arrow
I thought that it was just a ink problem with my manual
They should add the part numbers to that second part of the drawing
to avoid any confusion
Im just wondering how many others out there experienced the same problem
I did and never figured it out!
Are you planning on keeping the gearing stock or will you be upgrading the
gears for racing???
Oh and By The Way
Old 05-15-2015, 07:42 AM   #2533
Wow
gears for racing???
I built this kit for a TCS race next spring. I will be running GT-3, so I plan on gearing 88-49 64p, for a 3.70 fdr.
Old 05-21-2015, 09:45 PM   #2534
MD
MD's Avatar
Trader Rating: 118 (100%+)
I have a TA05 VII. I want to replace the bushings in the steering rack with bearings. The bushing part number is 19805185. I cannot find the size. I would like to install bearings, but I don'r know the size. Can you help me?
MD is offline   Reply With Quote
Old 05-22-2015, 02:17 AM   #2535
Anybody has some or know where i can get the tamiya 53990 ta05 bulkhead.
Realy like to have one>
checked tamiya usa and they have in stock but when i order i receive a message it't not in stock?
Please your reply
Bresser1 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
