Old 03-27-2014, 09:41 AM   #2461
Originally Posted by Racing4Evo View Post
i think it comes with the short reversible arms, I'm not entirely sure but it is a stock TA05 V2R. I've only raced the car once since I bought it so I'm not too familiar with it...
-Short arms have (2) holes on either side for the shocks to mount to
-Long arms have (3) holes on one side and (2) holes on the other to mount the shocks to
If you have the short arms. Use the widest shock mount hole and start with C-C blocks up front
If you have long arms use the middle hole on the (3) hole location side. And start with A-A blocks
XA-D or E in the rear, long camber links. Flat in the front and slightly angled in the rear, I already told you shock and spring set up. Start middle hole all around on shock towers. Medium sway bar front and soft in rear. Run a spool. I still like ball diffs. LTC-R body. Start 1-1/2 camber all around to start. If bite gets really high. Sauce rears for 15 minutes and fronts for have the time. If bite gets high sauce half the fronts. If the car still is edgy, glue the front side walls.
This should get you in the ball park. Good luck
Juan Aveytia is offline   Reply With Quote
Old 03-27-2014, 11:00 AM   #2462
Trader Rating: 152 (100%+)
How about a starting set up at tamiya track on b3 tires?
S I O is offline   Reply With Quote
Old 03-27-2014, 11:06 AM   #2463
I never ran that car at the tamiya track. Sorry but from my experience. Tamiya set ups from one car to another don't change much. Find a set up and try it
Old 03-28-2014, 01:28 AM   #2464
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Come see me on Saturday and I will give you mine. I think I have good starting setup but we can work together to fine tune it...
Racing4Evo is offline   Reply With Quote
Old 03-28-2014, 01:32 AM   #2465
Racing4Evo's Avatar
Tested a ball diff tonight, MUCH better. What kind of droop are your running?
Old 03-28-2014, 06:39 AM   #2466
6 & 5 on carpet is my starting point
Old 07-26-2014, 06:05 AM   #2467
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
anyone have a decent starting point for USGT on carpet with the RIDE spec tires?
or at least a rubber tire carpet setup - with the IFS
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-31-2014, 10:33 AM   #2468
k_bojar's Avatar
anyone running the V2 in GT2 or GT3 and have a decent setup for carpet?
Old 08-04-2014, 11:18 AM   #2469
AngryRog's Avatar
Trader Rating: 19 (100%+)
'Been running a spool with the plastic outdrives, they're worn and replacements are out of stock. Will the outdrives for the 417 fit? Suggestions? This is for 21.5 spec racing, so the lighter the better...
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03, M05v2 Pro, M05v2-R, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 08-04-2014, 01:11 PM   #2470
ThePanda's Avatar
Trader Rating: 64 (100%+)
the ta05 spool comes with steel outdrives though... is it a different brand of spool ?
ThePanda is offline   Reply With Quote
Old 08-04-2014, 01:20 PM   #2471
AngryRog's Avatar
I am guessing Tamiya, as it passed tech at the last TCS Regional at Aliso. We had picked the car up used, but were assured it was 100% Tamiya.
Spool is plastic outdrive cups with aluminum sleeves over them if that helps.
Old 08-04-2014, 07:51 PM   #2472
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Hey bud if that's the car you got from me everything on that car was Tamiya. Here is the part and the number for the outdrives. See if Sean at TQ can get it for you if not come see me at the Tamiya track I do have extra that I can sell it to you if you like.
http://www.tqrcracing.com/shop/produ....asp?p_id=4522
LionArtPrints - Custom Apparel, Hats, PitMats, RC Car Bags, and More
LionArtPrints - On Facebook
tiko is offline   Reply With Quote
Old 08-05-2014, 08:23 AM   #2473
AngryRog's Avatar
Yes, same car. You have pm.
Old 08-08-2014, 11:07 AM   #2474
AngryRog's Avatar
Just a heads up that the Tamiya 51443 outdrives for the TRF417 will fit the TA05 spool with a slight mod because of a small pin offset variance.
Old 08-17-2014, 09:16 PM   #2475
tom_chang79's Avatar
Hi All,
I'm dusting off my TA-05V2 and planning to run it again, I have a few questions after poking around on the internet regarding this chassis:
1) I'm in Southern California, what's a good in-door and/or out-door track to run this on? Is the Tamiya track near Irvine still open?
2) I'm really interested in getting a carbon fiber/graphite chassis mainly for LiPos (I got rid of the NiMH batts long ago), does anyone know where I can get the EX05 chassis? Seems like it was discontinued long ago.
Any help would be greatly appreciated, thanks!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
