TA-05 ver.2
#2418
Idea is the same.
2mm over the base ride height is where I start.
1. Measure the ride height.
2. Measure the height as you lift the car. When the tires are no longer on the ground...
Take the difference between the two measurements. That's the droop.
If car pushes going into the turn, the rear end might not have enought lift(droop) for the weight to transfer.
If the car pushes coming out of a turn(on power understeer), the front end is lifting up too much and weight is transferred to the rear too much.
If the car spins out going into a turn, the rear might have too much droop resulting in too much weight transfer forward.
From the base set up the tire and saucing seem to have the greatest effect on handling.
And the next thing is droop, IMO.
#2419
Idea is the same.
glad you typed it out.. i was too lazy to do so.
#2420
I just redid my ta05 v2 and I am loose on exit,
Seems like the rear end is hopping when I apply power on exit causing it to spin out
I might have my ball diff to tight. Would that cause it?
have red springs, blue sway bar, 40wt oil
The front end of the case is stiffer but is exactly where I want it,
Any ideas .
Any ideas .
#2421
Any ideas .
Any ideas .
or go back to full stock set up and go from there one adjustment at a time. oversteer stiffen front or softer rear. Ball diff should be back off a little past 1/2 turn from full lock up.
My set up for TCS carpet is yellow springs, ball diffs. lightest swaybars, 40 wt but every track is different. if it oversteers stiffen front, less rear droop,
no spool. make one adjustment at a time.
#2423
Hey guys, newbie here to the world of these touring cars...i come from a line of just bashing...just wondering if the TA05 ver. 2 Gold Edition is worth it's weight in gold?...by that i mean...is it worth the $499 price tag or whatever...or is it better to just go with the base version and upgrade?...ur guy's advice would greatly be appreciated.
#2426
#2427
#2430
well...i just got a ta05 v2 gold edition...but my intentions are not for racing but for parking lot and mall drifting...so it's all good...just needed at decent base setup...
i appreciate all your guy's input...
