Old 08-10-2013, 10:48 PM   #2401
thats tight
thanks
just ordered... the spur was on sale lol
rescue119 is offline   Reply With Quote
Old 08-12-2013, 04:02 PM   #2402
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Who's going to TCS nationals?
I'm struggling with my GT2 car. I can only manage to run 1-2 minutes before my car starts fishtailing everywhere. I'm running 7000wt in the rear diff.
I might not make it afterall if the car is this bad.
Racing4Evo is offline   Reply With Quote
Old 08-12-2013, 04:15 PM   #2403
Hebiki's Avatar
Trader Rating: 26 (100%+)
i'll be at TCS Nats... will only be there on Friday though. Traction/grip at Tamiya last Sat sucked or my set up was just that bad. lol. will be working on a new baseline set up for Nats.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-12-2013, 09:30 PM   #2404
Racing4Evo's Avatar
Cool thanks. I thought the new surface had better traction?
Old 08-14-2013, 09:59 AM   #2405
what motors you running in vta ... I am running 21.5 speedpassion v3. compared to some I seem really slow. the timing can only go up 10* on it as well..
Old 08-14-2013, 10:15 AM   #2406
edhchoe's Avatar
Trader Rating: 41 (100%+)
I use novak ballistic with red wire.
edhchoe is offline   Reply With Quote
Old 08-14-2013, 10:18 AM   #2407
Rick Vessell's Avatar
Which timing board do you have in the motor? I run the yellow one with nearly full advance. Works out to about 25' if I remember correctly.
Rick Vessell is offline   Reply With Quote
Old 08-14-2013, 10:48 AM   #2408
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I tried out the speedpassion V3 and found it like a lot more gear then a 4.2 FDR - was going to run 21.5 at a ROAR race, but went back to the novak for the event. so unless you're running an open gearing VTA class, you might wanna go with the novak
or try the option Rick mentions above and change the sensor board
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-14-2013, 05:15 PM   #2409
this year they just went to open fdr
and the board is the one that it came with. didnt know you could change them
Old 08-19-2013, 12:05 PM   #2410
ThePanda's Avatar
Trader Rating: 64 (100%+)
I have been looking for a ta05 v.2 for a while now. If anyone has one that they are willing to separate with, please, shoot me a pm. Looking for box stock rollers.
ThePanda is offline   Reply With Quote
Old 08-19-2013, 10:57 PM   #2411
Racing4Evo's Avatar
Anybody have a good asphalt setup on B3 tires they want to share?
Old 09-12-2013, 09:02 AM   #2412
CSeils's Avatar
Trader Rating: 48 (100%+)
Default What do I change first?
Need some suggestions on set up? Not sure if I'm doing this correctly. Tried to change a few things the last time I was at the track and didn't seem to make a difference. Using a softer front spring helped a little.
I need more "on power" front grip for my TA05. Car tends to push when going into corners. Any chance a spool might help?
Running USGT class on carpet with HPI "X" pattern tires.
Current set up :
Front
4 Hub
-2 Camber
3 hole piston
40wt oil
Yellow spring
Ball Diff
#3 hole on inner camber link w/1mm spacer
0mm spacer on outside camber link
2mm spacer on rocker arm
#2 push rod position on susp. arm
Rear
-1 Camber
3 hole piston
40wt oil
Blue spring
#5 hole on upper arm position w/.5mm spacer
#2 hole on outer axle w/2mm spacer on outside camber link
#3 hole on shock tower
#1 hole on arm
Any suggestions?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 09-12-2013, 10:04 AM   #2413
Current set up :
Front
4 Hub
-2 Camber
3 hole piston
40wt oil
Yellow spring
Ball Diff
Rear
-1 Camber
3 hole piston
40wt oil
Blue spring
#1 hole on arm
Any suggestions?
Carl,
I will email you my setup tonight. I have to check a few things before I send it your way.
Rick
Old 09-12-2013, 10:31 AM   #2414
AngryRog's Avatar
Trader Rating: 19 (100%+)
Spool will help it rip on corner exit, push badly on entry. Different driving style required. I prefer heavy gear diff over spool and ball diff.
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03.1, M05v2 Pro, M05v2-R, M07, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 09-12-2013, 11:34 AM   #2415
Hebiki's Avatar
Current set up :
Front
4 Hub
-2 Camber
3 hole piston
40wt oil
Yellow spring
Ball Diff
Rear
-1 Camber
3 hole piston
40wt oil
Blue spring
#1 hole on arm
Any suggestions?
email sent to the address in your sig.
Hebiki Design Works
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
