Old 09-21-2009, 07:23 AM   #226
syndr0me's Avatar
Trader Rating: 32 (100%+)
Any guesses on when the carbon reinforced chassis will be available for this car?
syndr0me is offline   Reply With Quote
Old 09-21-2009, 10:00 AM   #227
hey everyone, is the aluminum gear box (53990) a recomended hop up for the ta05v2?i was just wondering because the stock gearboxes seem rather weak.
thanks guys
PAO_F is offline   Reply With Quote
Old 09-21-2009, 10:31 AM   #228
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Exclamation
Originally Posted by 94eg! View Post
It won't simply bolt on because it has a built-in 16T pulley on the one-way. TA05 ver-2 ueses 18T center pullies. You would have to get the old TA05 center pulley and belts to make it work...
Not only are the center pullys different , the diff pullys are different. The TA05 has 36 teeth and the new car has 37.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-21-2009, 08:26 PM   #229
Super Moderator
Grizzbob's Avatar
Originally Posted by Hatebreed View Post
not yet but probably soon
what part does not fit on the carbon chassi? most parts used from the ta05 regardless ver1 or 2 should fit what i can see
the only thing that might not fit is the steering parts from ver2
No, the main chassis is different too, it's narrower, & that also means the chassis braces have to be different too. Also, the new chassis is meant to use the new seperated suspension mounts, while all the older versions are not. So we'll just have to wait for Tamiya to release new carbon-filled parts(which I expect shouldn't take too long).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-21-2009, 09:29 PM   #230
Nice car. I'll be waiting for a possible ms version if it will be made.
Obsidian is offline   Reply With Quote
Old 09-22-2009, 02:55 AM   #231
yeah but what i meant is that most parts from the ver2 fits on the 3racing chassi for the old ta05!
and with the 3r chassi you get the braces and everything. so steering and the seperated sus mounts should be the only thing that dont fit.
was thinking of getting the ver2 or converting my ifs r but went for a 416we instead.
Hatebreed is offline   Reply With Quote
Old 09-23-2009, 05:38 PM   #232
Akudou's Avatar
My verII is ready running on 5.5T Brushless. Can anyone help me out on the option parts etc TBO3,TR415,416 for upgrade on my VERII? Am eager to put on option parts as soon as possible and i will update you on its performance on drifts as well.
My Ride: TA05 VerII, TT01D, TT01, HPI E10, Lightning
Akudou is offline   Reply With Quote
Old 09-23-2009, 09:16 PM   #233
Default One Way Question
Does anyone know if there is a replacement diff joint outdrives that fit on the TA-05 one way but allow the driveshafts with the plastic inserts to be used.
Maybe the 416 outdrives or older 415 perhaps?
Has anyone thought about or done this???
Eat more possum!
Lees52 is offline   Reply With Quote
Old 09-23-2009, 09:34 PM   #234
Default shock spring
kit original shock spring, is it good?
If change to onroad spring set, what color to use fr/rr? what the spring rate compare to the stock one, it is softer/harder?
QDriver is offline   Reply With Quote
Old 09-24-2009, 07:33 PM   #235
Super Moderator
Grizzbob's Avatar
Honestly, I'm not sure any of Tamiya's one-way outdrives can accomodate those plastic blades. But that's why most of us who use a one-way also get some steel dogbones, they stand up to the abuse VERY well....
Bob Seay
Go Pokes!!!
Old 09-24-2009, 07:37 PM   #236
Super Moderator
Grizzbob's Avatar
Not sure about the kit springs, but there is a good place to see the spring rates for all of Tamiya's others, check out www.thard.co.uk , they have LOTS of good info for us, including spring rates for a LOT of different springs & some good gearing charts & suspension mount toe setting charts(can tell you which blocks to use to achieve a given setting). I consider it a must for ANYONE who runs a Tamiya.....
Bob Seay
Go Pokes!!!
Old 09-28-2009, 11:47 PM   #237
bl4
bl4's Avatar
Hi need some info from you guys. Do you guys insert an O-ring(black color) on the ball connector for the damper? If yes does it apply the same thing on all the turnbuckle ball connector also? Thks!
bl4 is offline   Reply With Quote
Old 09-29-2009, 09:26 AM   #238
Kevin CBR's Avatar
I believe the stock silver spring is in between the blue (hard) and white (extra hard) Tamiya spring.
Kevin CBR is offline   Reply With Quote
Old 09-29-2009, 07:47 PM   #239
Racecrafter's Avatar
Trader Rating: 25 (96%+)
You would be correct Sir!
(Belt cars are slow..... )
Jimmy
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-30-2009, 06:53 PM   #240
bl4
bl4's Avatar
Pls help! Everytime I enter a corner the car rear since to keep on spining out. What may cause this? Thks!
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
