Old 06-06-2013, 09:20 AM   #2326
edhchoe's Avatar
Trader Rating: 41 (100%+)
How much do these cars weigh? I will find out this weekend but just curious if I have been racing underweight (<1450g) for my class.
edhchoe is offline   Reply With Quote
Old 06-06-2013, 09:35 AM   #2327
MikeR's Avatar
Trader Rating: 14 (100%+)
Sold
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-06-2013, 09:35 AM   #2328
FNG RIDER's Avatar
Default Weight
For Tamiya GT3 21.5 class the weigh limit it 1400 grams.
I weighed in at last Tamiya race at TQ. my car is all stock plastic chassis w/ ti screws, shorty lipo, stock weight body, stock spoke wheels. It weighed in at 1480 grams.
I have since added a graphite impregnated chassis and light weight body. It should weigh in below 1400 grams now. I hope; )
RC10B5, Tekno 410 sct, TA05 v2 Reedy 17.5, Revolt 30, Seaport Tug, Axial SCX10 Rubicon ess sound system.
FNG RIDER is offline   Reply With Quote
Old 06-06-2013, 10:33 AM   #2329
edhchoe's Avatar
I use long batteries so I should be OK. thanks.
How do people use lipo packs for TCS on the tub chassis without grinding any plastic? I had to trim/grind some to get my rectangular lipo seated somewhat securely.
Old 06-06-2013, 10:34 AM   #2330
Hebiki's Avatar
Trader Rating: 26 (100%+)
last time i raced TCS, we were allowed to grind the bumps down for proper lipo placement. but that was 3 years ago.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-06-2013, 10:49 AM   #2331
FNG RIDER's Avatar
I don't grind, it lays just a little angled. probably won't hurt anything. I know hot shoes that don't bother grinding still going fast. You are allowed to grind for Tamiya.
Old 06-06-2013, 10:53 AM   #2332
edhchoe's Avatar
I currently have FDR 3.48 with 88t spur and 52 pinion. What size gears do you use to get lower FDR? I can't seem to use 53t pinion because of lack of space.
Old 06-06-2013, 11:23 AM   #2333
FNG RIDER's Avatar
for racing with the Reedy 17.5 I run plus or minus 4 to on FDR for 21.5 a tooth or two smaller on the pinion.
You may have reached the max because of the space.
Old 06-06-2013, 10:32 PM   #2334
Super Moderator
Grizzbob's Avatar
Honestly, I've never had need to gear mine that tall(only been running mine in the VTA class at Mike's Hobby Shop in TX, it's the closest to where I live, though it's about 250 miles away), but if a 52 tooth pinion is as big as you can fit, tehn you'll probably need to look for smaller spurs(I believe there are some as low as 78 teeth, maybe even smaller), that might be your best bet.
As for weight, with a driver figure, I think mines comes out to about 1570g(& Mike's is now enforcing the 1550g min., so I'm good to go with it), if your track is enforcing all the USVTA rules, then you should still be fine, I'd think(once you have a driver figure in there, & use a full size battery)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-08-2013, 11:56 AM   #2335
Stevomatik's Avatar
Just got a used ta05 version 2... Can I run 26mm or do I have to stick to 24 mm wheels.
Stevomatik is offline   Reply With Quote
Old 06-08-2013, 07:33 PM   #2336
Super Moderator
Grizzbob's Avatar
I'd guess if the wheels don't have any strange kind of offset to them, then they should be ok. And if you have any problems, you could either use wheel shims or some 6mm wide hexes on the axles(which is what I use to fit the 26mm & 31mm wheels that are specified for the VTA class)....
Bob Seay
Go Pokes!!!
Old 06-09-2013, 12:02 AM   #2337
Stevomatik's Avatar
Oooooo ok it came with 26 mm wheels and they rub a lil... Thanks for the tip ill throw some shims on there or I may jus invest in some 24's
Old 06-10-2013, 03:19 PM   #2338
My daughter tried the Tamiya GT 4wd class this year.
+ YouTube Video
Tamiya TA05v2, life battery, 12t brushless motor.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 06-13-2013, 07:04 AM   #2339
nsgland's Avatar
Trader Rating: 19 (100%+)
What track is that?
NSG Racing
Tamiya TA05 V2
Futaba,Tekin,Savox,LRP,Exotek,Sorex,Alpha
CapeFearRaceway.com
nsgland is offline   Reply With Quote
Old 06-13-2013, 10:22 AM   #2340
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
+ YouTube Video
how did she do???
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
