TA-05 ver.2
#2221
#2222
Heya guys. Quick question. Has the TA05 V2 R ever been released with any different damper set other than TRF Special Damper Set - Hard Black Coating
(these)
https://www.tamiyausa.com/product/it...oduct-id=42102
(these)
#2224
(these)
(these)
I dont know wht they are but I want confirmation they arent the kit ones - I think they are the 3Racing ones.
#2226
#2228
TA05v1 wins Speedtechrc's Grand Club Race
17.5 Blinkey
Pos 1 Solomon F. - Tamiya TA05 V1
Pos 2 Max V. -Tamiya trf 417X
17.5 Blinkey
#2229
if anyone is interested, I have a brandnew ta05 ver ii, it started life as a ver ii type r, I then added a exotec chassis, and bought every tamiya option part for it, including all blue screws, spend almost 1200 on it, it looks amazing, pm me if interested, also have the 2007 nsx bodies with it two finished and 4 brand new, comes with all the option tags from all the parts added to it, here are some pics
list of parts
TAMIYA ALUMINUM TRF SHOCKS WITH BOTTOM ALUMINUM RETAINERS
TAMIYA ALUMINUM IFS FRONT BULK HEAD LOWER AND UPPER
TAMIYA ALUMINUM REAR ALUMINUM BULK HEAD LOWER AND UPPER
TAMIYA CVD FRONT AND REAR
ALL SHIMS AND SPACERS ARE TAMIYA ALUMINUM BLUE ONES
TAMIYA 1XA SPLIT ALUMINUM BLOCKS REAR
TAMIYA 1E ALUMINUM BLOCK REAR
TAMIYA 1XC SPLIT ALUMINUM BLOCKS FRONT
TAMIYA 1XC ALUMINUM BLOCK FRONT
TAMIYA FLOURINE COATED SUSPENSION ENDS
TAMIYA ALL BLUE SUSPENSION NUTS
TAMIYA ALUMINUM 3X32 TIE RODS X9
TAMIYA ALUMINUM ROCKER ARMS
TAMIYA ALUMINUM RACING STEERING SET
TAMIYA VER II ALUMINUM MOTOR MOUNT
TAMIYA CARBON REINFORCED FRONT AND REAR A ARMS
SQUARE ALUMINUM C HUBS
TAMIYA ALUMINUM REAR HUBS
TAMIYA LOW FRICTION BELTS FRONT AND REAR
TAMIYA FRONT SPOOL
SPEC R REAR GEAR DIFF
TAMIYA CARBON REAR IFS CARBON STAY
TAMIYA FRONT CARBON BUMPER STAY
TAMIYA LIGHT WEIGHT FRONT BUMPER
TAMIYA LIGHTWEIGHT NEW NSX 2007 BODY SET COMPLETE NEW OR THE BUILT ONE
TAMIYA ALUMINUM WHEEL HEXES
TAMIYA BALL BEARING SET
TAMIYA CARBON REINFORCED K-PARTS
STAIN LESS STEEL SCREWS
TAMIYA ALUMINUM BLUE SCREWS
TAMIYA CARBONFIBRE REAR BODYMOUNT, SO YOU CAN FIT TAMIYA BODIES WITH THE HOLES MARKED
SQUARE FRONT KNUCKLES
SQUARE STEERING BALL BEARINGED LINK
EXOTEK NUT SCREWS FOR EASY BATTERY RELEASE
EVERYTHING ON THE CAR IS ANODIZED BLUE SO LOOKS UNIFORM AND AMAZING
ALL THE EDGES ON THE CARBON FIBRE WERE SANDED SMOOTH AND SEALED THEY LOOK AMAZING, SHINY AND PROPER
SPEND OVER 1200 ON THIS CAR,
ASKING 599 SHIPPED WITH TRACKING NUMBER, CANADA AND US, ROLLING CHASSIS ONLY, NO ELECTRONICS, NO BODY, NO WHEELS AND TIRES, NO MOTOR, NO RECEIVER, BUT IF YOU WANT ANYTHING YOU SEE IN THE PICTURE, I CAN MAKE A PACKAGE DEAL
list of parts
TAMIYA FRONT SPOOL
#2230
#2231
I bought a ta05 direct coupling diff (53877) to put on the rear of my v2 for drifting setup and the belt is too loose even at the tightest setting. What options do I have to make it work?
Will TA05 version1 belt do the job? It is 339mm which is 3mm shorter than version 2 belt.
#2232
How do I know this? Don't ask!! hahaha!
When I assembled mine correctly the belts were very tight. I had to back it one or two notches.
#2233
I triple checked it. But the direct coupling diff pulley is 36T. The OEM is 37T. That one tooth makes a big difference in circumference of the pulley.
I am going to order 53843 belt.
Edit: on the package it says to use with 54023, which is a 37T pulley. I will order that instead.
#2234
I've been using these pulley's for the last 10 months of regular weekend racing in my V2 TA05 and they have held up surprisingly well. One of them is used on a ball diff and the other is a direct coupling.
http://broadtechonlineshop.com/eagle...px?id=DP01-37T
They range from 36tooth to 40tooth.
There's also a bunch of good drifting accessories for the TA05 at that site, I've ordered quite a few items from them and their shipping times are very good.
Cheers
Rob.
