Old 07-03-2012, 11:43 AM   #2176
Trader Rating: 30 (97%+)
I have a brand new exotek ta05 with every option for sale in the for sale section, 399 includes a brand new 2007 nsx light weight body, all aluminum tamiya parts bulk heads, suspension mounts etc, Its my second car, and its brand new, built as a backup, but my original does not break so do not need this one, I spent almost 800 on everything so getting a deal on this kit,
zaraz is offline   Reply With Quote
Old 07-05-2012, 12:45 PM   #2177
Zac_with_no_K's Avatar
I was finally able to race my now VTA class TA05vII. It was a lot of fun and I was very happy with how the car held up.
I couldn't get enough steering and the traction didn't seem too good.
Are there any tips on improving these in this car?
I was thinking I could dremel my chasis so I could increase the d/r setting. I'm using the kimbrough servo saver with the screw in the top right corner.
I'm running a spool front and ball diff in the rear. Are there any tips on how to keep the belt tensions?
I have the yellow sway bar in front and red in the back. 40wt shock oil all around so suspension is very stiff.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 07-05-2012, 01:21 PM   #2178
MikeXray's Avatar
Trader Rating: 73 (100%+)
I didn't want to dremel the chassis for TCS reasons, but I think the rack is actually the limiting problem, instead I am using the forward holes in the steering knuckles, these provide better throw.
I raised the front roll center with 1mm shims under all 3 blocks, and added .5mm shims under the front rear blocks, all of that helped with steering. Also play with the rear shock position.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-05-2012, 03:12 PM   #2179
with my original ta05 ver ii r, I have the rear shocks all the way out, so as straight as you can get, no rear sway bar, front blue and rear yellow tamiya springs, that should fix your rear traction problem, as for not having enough steering, so you have your epa to the max, as on my car I have tons of steering and my epa is 90 percent, if they are maxed, try the inner hole as mentioned, or trying using tamiys pink springs and a light swaybar, also play with your dual rate settings
Old 07-10-2012, 06:17 AM   #2180
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
anyone know the part number for the pulley case that comes in the ta05 gear diff?? I got a leaky one and want to get another - plus, I'm ordering the other spare parts for the diff
or - does anyone know if the 51468 Gear Diff Unit Pulley Case - TRF417 (37T) will fit the TA05 gear diff?
the ta05 diff seems to be sold out all over
Bodies By Bean | Team Belly
k_bojar is online now   Reply With Quote
Old 07-10-2012, 07:08 AM   #2181
MikeXray's Avatar
I just got one from hkshobby
Old 07-10-2012, 07:53 AM   #2182
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Tower still has a gear diff set...
http://www3.towerhobbies.com/cgi-bin...?&I=LXBGSC&P=7
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 07-10-2012, 08:31 AM   #2183
k_bojar's Avatar
i'll have to look there - i requested a password reset, but never got an email from them...bastards
i forget tower has these things as well - I just usually look at speedtech or TQ RC, since they usually have the best prices and quickest shipping
Old 07-12-2012, 09:34 AM   #2184
Sam9's Avatar
Anyone here know where I can get the TA05 v2 in Australia?
Beware of Shane Cornish, don't do deals with him.
Sam9 is offline   Reply With Quote
Old 07-12-2012, 10:30 AM   #2185
Not sure where you could get one locally. Tower Hobbies ships international if you want to go that route....
http://www3.towerhobbies.com/cgi-bin...?&I=LXYHY5&P=7
Old 07-17-2012, 04:43 PM   #2186
would cutting the top chassis plate on the exotek chassis in the back give more rear traction, or has anyone with the chassis tried it, coz I see a lot of t3 and 417 cut the top decks to get more flex, so just wondering if that would be the same for the exotek
Old 07-17-2012, 04:48 PM   #2187
stitchy's Avatar
We ship worldwide too
http://www.speedtechrc.com/store/ebp...?catmainid=120
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-19-2012, 08:41 AM   #2188
k_bojar's Avatar
anyone here run a fan on their motors?? if so, how and where did you mount them??
I was thinking the little air scoop might be enough, but don't wanna take any chances
Old 07-19-2012, 08:53 AM   #2189
MikeXray's Avatar
used a clip on mount, couldn't find another way, might have been able to rig up a lexan mount, but lacked the motivation
Old 07-19-2012, 05:28 PM   #2190
ta04evah's Avatar
I use one of these and it works quite nicely.
http://os.3racing.hk/products.php?products_key=4745
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
