Old 06-17-2012, 10:17 AM   #2131
???E-Racer's Avatar
Took a couple photos with the body on it.
Im not a fan of the yellow that's just the type of shell that came with it.
I plan on painting a blue mustang shell for it eventually.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 06-17-2012, 08:03 PM   #2132
Trader Rating: 30 (97%+)
is the spec r rear gear diff pulley housing the same as the tamiya one, I want to switch all my pulleys to black and was wondering if its the same so I can just buy the pulley and not the whole unit thanks
zaraz is offline   Reply With Quote
Old 06-18-2012, 09:22 AM   #2133
Oortael's Avatar
Originally Posted by Oortael View Post
Hi,
I have another question, too.
I messured following weights on each tire with 4 small scales:
rear left: 435g
rear rigth: 224g
front left: 381g
front rigth: 239g
IMHO it would be best to have the left and the rigth hand side of the car balanced at the same weight.
Could the car be tweaked somewhere?
What are the best ways to balance the weight of the car? What relation (front to left) is common?
regards
Oortael
Has no one any idea how to fix this?
Oortael is offline   Reply With Quote
Old 06-18-2012, 10:02 AM   #2134
MikeXray's Avatar
Trader Rating: 73 (100%+)
that's a huge difference, like you don't have a battery in the car difference. The total is only 1279 which seems a bit light overall. What electronics are you using?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-18-2012, 12:41 PM   #2135
Oortael's Avatar
Here is what I use:
Esc: Speedpassion Cirtix Stock Club Race
Motor: Corally Red 17.5T
Receiver: Spektrum SR3000
Servo: Sanwa SDX-801
Lipo:Jamara 5000
I'll measure the components later .
Old 06-18-2012, 12:44 PM   #2136
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Oh, I see you have your VTA driver figure ready. Is that donatello?
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 06-18-2012, 12:51 PM   #2137
Zac_with_no_K's Avatar
Exclamation
I just got HPI VTA tires. 26mm 0 offset for front and 31mm 6mm offset for rear.
Does anyone know if I'll need to modify anything to make these fit?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 06-19-2012, 12:13 PM   #2138
Oortael's Avatar
Could it be that the chassis plate of the TA-05 ver.II has some tweak out of the box? I figured out, that when I twist my chassis around it's length (imaginary line parallel to the belt drive) all axles have the produce the same force on each tire.
Old 06-19-2012, 01:54 PM   #2139
MikeXray's Avatar
Some have complained about that, I haven't found it to be an issue. Do you have a level style tweak station?
Old 06-19-2012, 02:32 PM   #2140
C&B RC's Avatar
You most likely will need to add a washer between the front hub & wheel to space it out so the tire isn't rubbing the knuckle arm.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 06-19-2012, 06:43 PM   #2141
Thanks, what size washers would work for that?
Also, does anyone know what the largest size 64p spur and pinions will fit?
I need to order a 82t spur with 48t +/- pinions but worried the pinion would be too large..
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 06-19-2012, 07:49 PM   #2142
C&B RC's Avatar
I need to order a 82t spur with 48t +/- pinion but worried the pinion would be too large..
Washer I use is 5.25mm ID 12mm OD thickness can vary depending on how much you need. Not sure on MAX spur / pinion
Old 06-19-2012, 08:02 PM   #2143
Super Moderator
Grizzbob's Avatar
I can't really comment on spur/pinion(I use 64 pitch in my touring cars), but these washers will work to space out the VTA wheels... http://www.speedtechrc.com/store/ebp...id=613&id=7158 .
Or, you could use what I use, which is this: http://www.speedtechrc.com/store/ebp...nid=615&id=823 , that eliminates the need for any spacers to make the wheels clear everything....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-20-2012, 06:57 AM   #2144
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
does anyone know if the V2 and the 416 share the same body post locations? assuming you're running the carbon rear shock tower and not the stock one??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-20-2012, 07:30 AM   #2145
I just decided to buy some 64p gears. I ordered an 82 spur and 50t pinion. (I had $15 in store credit at amain about to expire). I can let you know how they fit. They should be here by the end of the week.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
