Old 06-04-2012, 07:35 PM   #2101
Super Moderator
Grizzbob's Avatar
Originally Posted by Zac_with_no_K View Post
Thank you, I guess I'll be switching to 64p then.
Another question..
Does anyone know if Xray or team associated on-road springs will fit the TRF shocks?
I know the xray springs have the same diameter of 1.5. I don't know if they're the same length or anything.
Just asking because I know my lhs has xray springs and not sure but most likely have AE springs and I would prefer to support them than making any online orders
Yes, Associated springs work fine on the Tamiya shocks, I use them all the time(especially since their range of stiffness is greater than the Tamiyas, an AE green is softer than any Tamiya, & an AE red is harder than a Tamiya white, & then AE springs can go further than that, very handy)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-04-2012, 10:57 PM   #2102
Zac_with_no_K's Avatar
Thanks Gizzbob!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 06-04-2012, 11:00 PM   #2103
Originally Posted by OVA View Post
I found the package..there are a few are missing in the package.I'm wondering who was in the cookir jar?
what color spring are you looking for?
Thanks again, and I'm not sure yet on the colors. I guess whatever stiffness seems to work best at the home depot parking lot!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 06-05-2012, 03:56 AM   #2104
Tested my car today happy with the chassis but having problem with the esc/motor.
Im using hobbywing ezrun 5.5T motor 60A esc combo but after 5mins of play the esc cuts for 2mins then it works again, was thinking its the receiver as its been wet before but steering works.
Gearing im using is stock 70T spur and 18T pinion outside temp was 30+ degress
Any help appreciated
alex_evo is offline   Reply With Quote
Old 06-05-2012, 04:44 AM   #2105
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by zaraz View Post
is 82/44 in 64p or 48p thanks
64p
sometime its easy to tell by the pinion I don't know of many 48P pinions that go to 44 teeth
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-05-2012, 04:57 AM   #2106
k_bojar's Avatar
Originally Posted by MikeXray View Post
I don't think 100/58 fits, I run 82/44 for 17.5, that has room to go larger on the pinion.
hmmm...i think i need to reconsider my spur gear in mine
Old 06-05-2012, 04:50 PM   #2107
Trader Rating: 29 (97%+)
who makes a white 82 teeth 64p gear thanks
zaraz is offline   Reply With Quote
Old 06-05-2012, 04:55 PM   #2108
stitchy's Avatar
We carry the RW and Xenon ones.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 06-05-2012, 07:04 PM   #2109
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
you best bet it to put the car on the track and go from there...you may not need extra spring ...
give me your email I will sent you the set up...
OVA is offline   Reply With Quote
Old 06-06-2012, 10:46 AM   #2110
Thank you, pm sent
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 06-06-2012, 01:08 PM   #2111
Originally Posted by bencason View Post
I run 48P but the conversion is easy. The stock spur is roughly equivalent to a 70T 48P which would be about a 84T 64P spur.
I have run an 81T 48P but it sticks through the bottom of the chassis about 3mm. I haven't hit it on anything but I don't race outside. 81T 48P is equivalent to 108T 64P. I ordered a 73T 48P gear that I plan to switch to [I've gone back to the stock spur until it comes in] which is roughly a 97T in 64P.
So I'd say a 64P 108T spur is probably the largest you want to use for indoor racing on smooth surfaces but there is some risk since the spur sticks below the chassis.
If you have access to several 64P spurs around 96T to 98T, I suggest using the one fits without any part of the spur sticking below the chassis. If you are OK with the spur sticking below the chassis, then 108T fits. If you go much larger than 108T, it may rub on the aluminum mount or drag on the ground when the chassis rolls.
according to robinson racing, a 70t 48pitch is 93t 64 pitch,
so back to me trying to run a fdr of 3.6, would say a 93t 64p spur gear and a 53t 64p pinion physically fit in the car thanks
Old 06-06-2012, 02:50 PM   #2112
???E-Racer's Avatar
I need to know what version of the car I have.
Do I have version 2 or the older version?
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 06-06-2012, 02:59 PM   #2113
stitchy's Avatar
from the motor mount, seems like a v2?
Old 06-06-2012, 06:12 PM   #2114
k_bojar's Avatar
with a 3racing chassis, maybe??
Old 06-07-2012, 02:10 PM   #2115
Questions??
For VTA I calculated 24 different FDR's that equal 3.5. I just don't know what spur gear to use.
The highest spur I've done is 93 with a pinion of 54. I didn't want to go much high because I don't know what's too big for 64 pitch gears. I also noted that 70/41 is exactly 3.5 if that makes any difference..
I've done every spur tooth count inbetween 69 to 93.
Does anyone have an opinion on what spur gear would work best? Even if it's higher than 93.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
