Old 05-27-2012, 11:55 AM   #2071
Zac_with_no_K's Avatar
So do the stand up shocks -connected to shock tower- work a lot better than the IFS for everyone? Does anyone perfer the IFS??
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 05-28-2012, 05:32 AM   #2072
ATM i prefer the IFS dont really know why but so far its working, also anyone using the gear diff for TA05 what is a good oil wt for the rear
alex_evo is offline   Reply With Quote
Old 05-28-2012, 02:51 PM   #2073
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
OVA is offline   Reply With Quote
Old 05-28-2012, 02:57 PM   #2074
OVA
OVA's Avatar
Default Short Tamiya Hard Shock Spring Set
Tamiya Suspension Springs Short/Black Touring Cars TAM42168
Question are these springs set are to soft for 4wd sedan?
I need the harder short spring and not looking for the soft one like use for the mini car..
Old 05-28-2012, 05:07 PM   #2075
Trader Rating: 69 (100%+)
Yes, they are too soft for sedan. They become the included set for F104 now.
eComet is offline   Reply With Quote
Old 05-28-2012, 05:53 PM   #2076
OVA
OVA's Avatar
do they tamiya make any harder short spring at all?
Old 05-29-2012, 12:04 PM   #2077
over gear's Avatar
Trader Rating: 15 (100%+)
I have an Exotek EX05 chassis for sale if anyone is interested.
Exotek Tamiya TA05 EX05 V2 Chassis
over gear is offline   Reply With Quote
Old 06-01-2012, 12:42 PM   #2078
Exclamation
I'm stuck deciding wether to race 17.5 or scale spec 21.5 with my TA05vII.
The advice I got was to go for a 3.6-3.8 ish FDR for 17.5.
What spur/pinion gear sizes should I purchase?
I didn't get a FDR for the 21.5 scale spec class but hoping that the above FDR for 17.5 might be close??
What spur/pinion gears should I buy if I end up going scale-spec??
I really don't know how big the track is and if there's a lot of tight turns or long straights though.
Any advice helps a lot! Thanks!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 06-01-2012, 12:49 PM   #2079
OVA
OVA's Avatar
hi
I would start with the stock Spec 21.5 first..becuase you can race this class any where..Fastraxx.Fw and 4Season..putting in the 17.5 it is alittle harder to get the car to dialed compare the 21.5 power plant...'
I have the TA05V2 as well.... I would start 3.5FDR for 21.5 motor and then gear up if needed...
Old 06-01-2012, 04:42 PM   #2080
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
I have some parts for sale that are left over from my TA05V2 Build
To get the car dialed via gears u need to find out first if ur motors likes RPM or Torque.
There is a 4 teeth difference between them. I am running a different FDR than the rest of the guys with 17.5 and i can still catch up with them and only come in at 120-150 degrees.
Also Changing the Piston holes and Oil in the front IFS shocks Helps according to track.
U can shim the Ball studs to imitate Shock tower adjustment.
And finally u need to buy Alu Rockers bc Plastic ones have way too much slop.
I got my TA05v2 with IFS Dialed in with Exotek chassis, was able to hang with any of these TC6.1 Schumacher 416 and 417.
Genuine Tamiya TRF TA05 V2 417 416 Parts Hop Ups
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 06-01-2012, 05:21 PM   #2081
Trader Rating: 30 (97%+)
anyone with the gold edition, can you confirm if you are given both options to build the car standard or ifs, also does the carbon steering bridge 53883 work with the version 2 steering or not, thanks
zaraz is offline   Reply With Quote
Old 06-02-2012, 11:42 AM   #2082
hi
Thanks for the advice! And cool, sounds like we'll be racing eachother. I used to race up here with Atomic Hobbies back around 2005 until they closed.
And I would rather race in stock spec because it would be slower and a lot easier for me and also like you said, easier to get the car dialed. but if I get the 17.5 I would be able to swap it into my SC truck and be able to take that to TRCR. Unless I can find a decent 21.5 motor/ESC for a cheap price.
Would a silvercan geared high enough be competitive against 21.5's?
And how do you find the FDR? would I want a larger spur gear and smaller pinion? or would I want the largest size pinion to the smallest size spur gear I can find?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 06-02-2012, 11:58 AM   #2083
MikeXray's Avatar
Trader Rating: 73 (100%+)
If you buy a Novak ballistic or thunderpower, you can buy just the stator so you can use the same motor for 21.5 and 17.5
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-02-2012, 11:58 AM   #2084
The carbon bridge does fit into the v2 steering. I've got it in mine, but I felt I needed to get extra flanged bearings to mirror the ones supplied. If I built my car again though I wouldn't bother with it, instead would just go for the carbon reinforced parts and some bearings instead. I don't think the there's much if any advantage of having the carbon linkage. If anyone wants to see a picture of how it's installed then let me know and I'll pull my chassis brace off and take a photo.
cain.c is offline   Reply With Quote
Old 06-02-2012, 01:01 PM   #2085
OVA
OVA's Avatar
how to find the FDR spur gear divide by pinion x 2.05 internal gear = FDR
If you have the perfect or good silver can , yes ,it is enough be competitive against 21.5 at the med size track ...25.5 motor no problem for silver can keep up...
The 4.9 FDR is a good start in most cases...it best to get the cooling fan so it can keep the motor from getting too hot...
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
