Old 05-09-2012, 08:34 PM   #2056
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Look for a Version 1 if you do a extreme conversion kit.
the 1 has all the parts u need anyway.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 05-10-2012, 10:47 PM   #2057
maxepower's Avatar
Unhappy Used TA-05's
Originally Posted by jameyfoto View Post
bmmer. the cheapest ta05 I've found is around $200...
Keep looking I'm sure you can find a use one for around $100. There's always somebody selling their used TA-05's. Keep asking here on RC tech!
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 05-10-2012, 11:19 PM   #2058
iPearl's Avatar
I am looking for a Center Pulley/Spur assembly Stock from TA05 V2
No spur needed just need the Spur holder the shaft and all that jazz
Old 05-13-2012, 01:26 PM   #2059
Ok so I got a used ta05 on ebay with engine and esc. I should have all the parts I need, assuming its all functional right?
jameyfoto is offline   Reply With Quote
Old 05-14-2012, 11:10 AM   #2060
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
aside from a random screw or spacer, you should be set - i'm not familiar with conversion set you bought, but its made to swap out with minimal additions...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-21-2012, 06:18 AM   #2061
MikeXray's Avatar
Trader Rating: 73 (100%+)
2 things, is there a spring chart that shows the white with red, blue and yellow dot spring rates? I ended up using top springs to make the car stiffer, which helped.
can a 417 steering rack fit in this car? there is only one other option for ackerman, and I think the car just needs longer links in general, it's hard to get it to turn in, but it still has great mid corner.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-23-2012, 03:47 PM   #2062
Trader Rating: 30 (97%+)
I just had a quick question hoping some one could answer, does the new gold edition ta05 ver 2 give you both setup, like the ta06, can you make the car with standard front suspension or ifs thanks
zaraz is offline   Reply With Quote
Old 05-24-2012, 08:17 PM   #2063
bencason's Avatar
This photo on the Tamiya USA site shows the Gold edition TA05 V2 with stand-up shocks. I am looking forward to seeing the manual so I can put together the part numbers to convert from IFS shocks to stand-up shocks.
http://www.tamiyausa.com/product/ite...oduct-id=84275
By any chance, has anyone done such a conversion and have a parts list handy or can point me to one?
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
bencason is offline   Reply With Quote
Old 05-24-2012, 08:51 PM   #2064
ta04evah's Avatar
I converted my TA05v2 ifs to stand up shocks on the front. What you basically need is another rear bulkhead and a front shock tower.
I went with after market parts with a aluminum rear bulkhead which you replace the front one with, and a carbon fiber front shock tower for a TA05 v1.
Bulkhead
http://broadtechonlineshop.com/eagle...l.aspx?id=3553
Shock Tower
http://broadtechonlineshop.com/eagle...?id=TA05-02/WO
On the gold TA05v2 you can still see the ifs shock mount in place, this has to be left there to add strength to the plastic chassis.
p.s. The aluminum bulkheads shown above use the larger TA05v1 plastic bearing holders instead of the smaller TA05v2 ones.
The part number for those is "A Parts 51208".
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 05-25-2012, 05:28 AM   #2065
JD Skyline's Avatar
Done this conversion about 2 months ago. Like ta04evah wrote just with the shock tower and the bulkhead. Like this conversion very much and it wil stay this way For me personally the car is handling better then with the IFS setup.
JD Skyline
"NO GUTS NO GLORY"
Tamiya TRF418, Tamiya TT-01 Type E and Still lookin'for more Tamiya cars.......
http://jdskyline.blogspot.com/
JD Skyline is offline   Reply With Quote
Old 05-25-2012, 06:49 AM   #2066
bencason's Avatar
Thanks for the info JD Skyline and ta04evah.
I've been fighting an off-power looseness in the rear-end for a while now and thought it might be easier to correct if I didn't have the IFS front suspension. I had hoped the conversion was easy/straight-forward. Your posts sure make it sound that ways so I am going to give it a try.
Old 05-25-2012, 11:24 PM   #2067
For ppl who has used the exotek EX05 conversion, How good is it ?? is it as good as a TRF 416 ??? as i have seen mixed reviews
alex_evo is offline   Reply With Quote
Old 05-27-2012, 02:02 AM   #2068
ta04evah's Avatar
Depends which option you use.
If it's the option for stand up shocks then it'll work quite well out of the box.
If it's the IFS version, then leaving out a couple of screw on the top plate in front and behind the center top plate screw on the motor mount will let it flex a little to give more grip on a slippery track.
After converting to stand up shocks on the front I still have the IFS mount on the chassis. I removed the 2 aluminum posts that are between the plastic IFS mount and lower EX05 chassis which allowed the car to flex a bit more. Removing those posts transformed my car from something that felt the rear end was lose and wanted to let go to a car that gives great grip and corner speed in turns.
I could get the replacement non IFS top plate to do away with the IFS mount but the car is working well for me as it is and it's a nice thing to mount a transponder on.
Of course different setups will work for different people, the complexity and excessive free play of the IFS was something I did not want on the car.
Cheers
Rob.
Old 05-27-2012, 07:38 AM   #2069
Thanks for the info !!
Will deffo try leave some screws out on the top deck and see how it behaves as i like the IFS setup atm
Old 05-27-2012, 09:01 AM   #2070
MikeXray's Avatar
I made some progress with the car, I ran it in 13.5 blinky with solaris hard tires and a beat up P37 body, it got around ok, still needs turn in though. I raised the front RC 1mm, and added 1mm kick up to the rear, and also started using the front holes on the knuckles, this allows for full lock.
Still have TOP springs on the car, probably need to go back and try the tamiya set with the other changes.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
