Old 04-18-2012, 04:12 AM   #2041
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Dirt_McGirt View Post
Sorry, I am somewhat a rookie. What is fdr? You're from Aliso, you must go to the Tamiya track. Any gearing help from you would helpful as that is where I am planning to run.
FDR = final drive ratio
the mathematical equation goes like this (spur/pinion) x the internal ratio of the car (diff gear/puller / center pulley/bevel gear)
so on the V2 - the internal ratio is 2.055 (37t pulley/18t center pulley)
so, if you had a 95t spur, and put a 48t pinion on your car you'd get the following:
(95/48) * 2.055 = 4.07 FDR
basically the lower the number, the more top-end the car will have, but you'll loose some bottom end grunt (power off turns)...however, this is all related to the track you're running...if you are running on a real small, tight (lots of turns) track, a FDR like my example above, could possibly overheat and destroy your motor - so on a track like that, you'd want a higher FDR
make sense?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-18-2012, 07:45 PM   #2042
make sense?
Cool thanks for the info. So a little lower fdr will help it run a little cooler?
Dirt_McGirt is offline   Reply With Quote
Old 04-18-2012, 08:50 PM   #2043
tamiya TA 05 ver II can used to drift?
meva is offline   Reply With Quote
Old 04-19-2012, 04:24 AM   #2044
k_bojar's Avatar
not really...a lower FDR (like 3.8 v 6.5) would generate more heat in the motor...You're best (and safest) bet would be to ask around at your track and see what most of the guys are running and go from there..Plus every motor has a sweet spot - a gearing combination that really makes it sing - so when you ask you track mates, make note of what motors they are running..
what i normally do is ask someone, and then go (for example) 1 tooth smaller for a sllightly higher FDR - just because everyone's driving style is different, what works for faster dude "A", may not work for you (or feel quick), so adjusting up or down in necessary...
rule of thumb:
lower FDR = more top end, less grunt off corners
higher FDR = lower top end, more bottom end grunt
Old 04-19-2012, 04:30 AM   #2045
k_bojar's Avatar
sure why not? I don't drift (at least intentionally ) but pretty much every chassis can be used as a drift car
probably wanna check out the drift threads and see what mods guys are doing to get the most out of their chassis
Old 04-19-2012, 08:26 PM   #2046
maxepower's Avatar
Talking FDR for Tamiya
As you can see I run at the Tamiya track just about every week and most of us are running Reedy sonics, Thunder power, Duo 3's or Ballistics and we all run around 3.8 on all the motors. Motor temps are coming off at 140-170. degrees F. after about 6 minutes with a fan, so I would say that's pretty conservative! Right now I'm using Reedy sonic and Thunder power and both are real close in power. I'll run closer to 4.0 FDR on the Thunder power and closer to 3.8 on the Reedy. My ESC is the NOVAK EDGE! This is all in the Blinky or linear spec. class racing for TCS.
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 04-20-2012, 10:06 AM   #2047
CW22's Avatar
Trader Rating: 93 (100%+)
Default TA05 gearing
Just my 2$
So, on the Reedy Sonic 17.5T your FDR is 3.8, do mind telling me what pinnion and what number spur you using? thank you.
CW22 is offline   Reply With Quote
Old 05-02-2012, 07:10 AM   #2048
MikeXray's Avatar
Trader Rating: 73 (100%+)
Are there 2dg chubs for this car?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-02-2012, 07:40 PM   #2049
maxepower's Avatar
Talking Spur/pinion
95/50 = FDR 3.895 Actually closer to 3.9 than 3.8
Old 05-02-2012, 07:42 PM   #2050
maxepower's Avatar
Exclamation WHAT?
Please translate!
Old 05-02-2012, 07:43 PM   #2051
k_bojar's Avatar
Please translate!
2 degree c-hubs
Old 05-02-2012, 07:48 PM   #2052
maxepower's Avatar
Red face 2 DEGREE C-HUBS!
2 degree c-hubs
OOOH! Now I understand.
I do know Tamiya made 2 deg. C-hubs for the earlier version TA05. Not sure if they made it for V2! I'll see if I can find out?
Old 05-08-2012, 07:01 PM   #2053
Hey all, I'm considering building my first car from scratch and I like what I'm seeing with this as a base: http://broadtechonlineshop.com/eagle...aspx?id=3860V2
I hate the idea of buying a whole v2 just to strip some parts off and add them to this. Is there any such thing as a parts list to take the above link and turn it into a car? I already have electronics I'll be stripping off my current car. This will be used as a drift car.
jameyfoto is offline   Reply With Quote
Old 05-08-2012, 09:37 PM   #2054
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
PLan to shell out some cash if you buy parts.
Buying a basic kit and converting is still cheaper especially buy a used TA05
Only parts u will be using of it is the bulk head which you will upgrade anyway.
The arms, and the diffs, Belts, and all the metal pins shafts and turn buckles and cups.
The rest if junk to you with a conversion LOL
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 05-09-2012, 05:36 PM   #2055
bmmer. the cheapest ta05 I've found is around $200...
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
