Old 03-23-2012, 01:18 AM   #2011
Originally Posted by toast. View Post
Just to make sure - you're saying to get a V2 instead of a TA05 and trying to convert it to a V2.
Thanks - im basing my info off of a "Best 1/10 Electric Plastic Chassis Touring Car" so want to make sure i start with the right car - thanks!
yes get the v2 kit. the supports in the chassis plate are different. also the motor and mid shaft or center shaft if you wanna call it that are lower in the chassis
Originally Posted by alex_evo View Post
Hey guys
I have been rebuilding my Ver.2 follwoing the manaul everything seems fine unitl i put the motor in.
Once i put the motor in everything seems tight. Before i could move the motor&diffs by pulling on one of the belts, now it seems alot harder just doesn't want to move without some force. Without the motor its quite free and smooth.
Both spur & pinion are worn but still useable and i have left enough clearence for the gears too
Wasn't like this before i took it apart
What will be a good setting for the belt tension ?? as i think it maybe to tight
Motor used is a Ezrun 5.5T
yes your diffs are very tight if it binds up like that. back them off at least 3 or 4 spots..check the build up manual, it should tell you where to put them as a baseline setting. ive dont the same thing and i actually damaged my motor and my front belt...100 bucks later it was working again..you want them as loose as possible without them jumping when you take off at the start or during heavy breaking...shoot me a pm if you need help
Andy Laaaaaaaaaachance
evader-fan-69 is offline   Reply With Quote
Old 03-23-2012, 06:25 AM   #2012
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Im new to the Tamiya TA-05 V2 crowd and I've been going through lots of posts trying to get up to speed. Bought a used TA05 V2 with a Novak Dually ESC (no reverse) and for my current driving skills i definitely need reverse.
I've been looking at a Hobbywing eZRun 60A and a Mamba Max ESC 5700 or 7700.
Please tell me if im looking at the right ESC's
If you're going to run stock class sedan, I'd get something like this:
http://www.amainhobbies.com/product_...tor-Combo-175T
or
http://www.shopatron.com/products/pr...6.0.0.0?pp=10&
Either way, you'd be getting a good inexpensive start in that class.
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 03-25-2012, 07:06 PM   #2013
CW22's Avatar
Trader Rating: 93 (100%+)
Default TRF shock
Hi guys, I need a suggestion about the Tamiya TRF shock.
Does it make a lot different to replace the shock with the TRF shock, compare with the stock Tamiya plastic shock that come with the TA05 V2?
Please advise me, thank you.
CW22 is offline   Reply With Quote
Old 03-26-2012, 05:36 AM   #2014
TRF shocks are way better than the plastic stock ones. Can instantly feel that its better
alex_evo is offline   Reply With Quote
Old 03-26-2012, 08:46 AM   #2015
CW22's Avatar
Default TRF shock or 3 Racing shocks?
Thanks, that's is true considering the price is $60. Any body have use the 3 racing shock?
That is only $25 a sets of 4, I just wondering how's the quality of that 3Racing shocks? Can anybody have a comment?
Thank you.
Old 04-04-2012, 08:11 AM   #2016
toast.'s Avatar
I'm new to the TA-05 v2 and need some help. My car only seems to go if I push it, once it stop it wont move forward any more although the steering still works.
Do I need a new ESC, if so please recommend one?
Thanks!
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 04-04-2012, 08:21 AM   #2017
MikeXray's Avatar
Trader Rating: 73 (100%+)
Thanks!
What motor are you running? if brushed, like a silver can or 27t, that usually mean you have a hung brush. If brushless, try changing your sensor cable.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-04-2012, 08:22 AM   #2018
kwkride's Avatar
What motor and ESC do you have in it right now?
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 04-04-2012, 08:51 AM   #2019
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I agree - if you are using a brushless motor, check the sensor cable...I had the happen to me before, and was fixed by replacing the sensor cable
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-04-2012, 09:40 AM   #2020
toast.'s Avatar
The motor is Trinity Cobalt, not sure if motor is brushless but i doubt it.
Dually novak esc.
Is this old tech, should i replace them.
I checked the wiring and it looks fine but ill keep looking.
Thanks for great quick feedback.
Old 04-04-2012, 09:57 AM   #2021
MikeXray's Avatar
Dually novak esc.
Yes that is brushed, the hood will look like this:
first try pulling on the wires that go to the brushes and see if they move freely, you can also remove the spring and see if they are worn to nothing, when they get about 1/4 of the size pictured the springs have trouble pushing them hard enough to make contact with the comm.
Old 04-04-2012, 05:58 PM   #2022
toast.'s Avatar
Took the engine out resodered wires but still no luck.
Any recommendations for new brushless engine and esc combo?
I rather get a nice one and spend a little money then buy a cheap one and have to replace it shortly. I plan on Racing not drifting.
Old 04-05-2012, 04:20 AM   #2023
k_bojar's Avatar
depending on whether your track runs blinky or boosted classes - this one would be a real nice setup for blinky 17.5
http://www.teamnovak.com/products/br...ive/index.html
for a boosted class, can't go wrong with the Tekin RS
blinky = no dynamic timing in the speedo, all timing is on the motor
boosted = dynamic timing in the speedo
a lot of tracks run a blinky 17.5 class, but you'd need to see what your local track actually does
Old 04-05-2012, 04:31 AM   #2024
kewdawg's Avatar
Can you tune the plastic shocks with pistons?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-05-2012, 04:34 AM   #2025
k_bojar's Avatar
quinn moon??? you're still around??
yes, the plastic shocks can still be tuned with pistons...All of tamiya shocks have always been said to be outstandings - you just get the bling factor with the TRF (plus threaded adjusted, super smooth inners)...but anything (aside from the threaded adjusters) for the TRF shocks can be added to the plastic body shocks...just make sure they are the black plastic, not the see thru stuff - that plastic is much more brittle
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
