TA-05 ver.2
#181
The blue belts don't fit at all. The 2 options available are the Black Low friction belts as Grizzbob pointed out and the white belts from the IFS-R.
#182
When using metal outdrives, then a little grease is all that's needed to hold the diff ring steady. And if it does slip, the outdrive won't melt.
#183
Hi all,
I just picked up the Cusco Subie and I'm stoked! Any building tips? Hop-ups needed? I'm putting the black Tamiya shocks on it first.
Do the aluminum TA05-IFS suspension parts fit?
#184
#185
#186
What online stores do you guys recommend for purchasing spares? NONE of my LHS's stock Tamiya parts (or kits, for that matter!) in the Dallas area if you can believe that!
#187
#188
What is the best choice to upgrade & lighter the chasis? Thks!
#189
Aluminum suspension mounts
Aluminum rocker arms
Universals for front and maybe rear
Aluminum TRF shocks
Aluminum TRF shocks
#190
Can this Tamiya 46mm Assembly Universal Shaft (OP-#53847) be use? Thks!
#191
Yes that is the correct size drive shaft.
#192
#193
Belt Tensioner on TA05 v2?
Hi,
Does anyone of you knows if we can install a belt tensioner in TA05 v2 chassis? Because I have this like a little bit loose belt, and when it runs, its like it is skipping a tooth. The kit is brand new was run just to test it out.
#194
You don't need a belt tensioner for this car, there is more than enough adjustment available to stop the belt from skipping.
There is a dedicated TA-05 V.II thread where something similar was sorted out, go read it you may have the same problem.
http://www.rctech.net/forum/electric...er-2-a-13.html
#195
Eccentric diff holders adjust the belt tension. If the standard kit-instruction position allows skipping, you need to move them out a notch or two...
