Old 12-17-2011, 07:35 PM   #1906
Trader Rating: 30 (97%+)
also make sure the diff retainer ring the plastic piece are supposed to be facing the way it shows in the manual, if left and right are not the same position it throws the whole drivetrain off
zaraz is offline   Reply With Quote
Old 12-17-2011, 08:48 PM   #1907
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by alex_evo View Post
Thanks will give that a check, didnt know the kit came with different size pulleys as i bought mine pre built 2nd hand ages ago lololol
easy way to check is to look at the pulleys outermost ring...
solid = 36T
with holes = 37T
36T
37T
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-17-2011, 10:20 PM   #1908
Super Moderator
Grizzbob's Avatar
Also, you mentioned using Tamiya tires, but which ones are you using? They have several different compounds, & if you're using the wrong one for your track, you WILL spin out alot. Tires are still at least 70% of a good setup. Could you tell us more about exactly which tire you're using, & what kind of track you're running on? That can help us to help point you in the right direction.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-18-2011, 12:35 AM   #1909
Thanks for the above pic !!!!! deffo makes it alot easier than counting haha
I know tires are very important, as in most race cars you tune the car for the tire as there is tire control, but for me im running the car at open practise's so can use any but funds are limited lololool
ATM running the tires that came with the kit so i think tamiya medium narrow slicks on a medium-high grip asphalt outdoor track
The car is ok round the low speed corners but on the high speed straights it wanders and when i try correcting it, the car just spins even with little amount of steering.
I toe out at the front this helped alittle but still very nervous on the straights
Also the play in the steering linkage (the bridge that connects the steering k16) has alot of play, i took it apart and found that the flange tube BB19 moves in the vertical direction and thats causing the play in the steering
alex_evo is offline   Reply With Quote
Old 12-18-2011, 05:35 PM   #1910
Super Moderator
Grizzbob's Avatar
Well I do understand dealing with racing on a budget, but if you're using Tamiya kit tires on low-med grip asphalt, then I can almost guarantee it's the tires. Those things are about as hard as hockey pucks compared to real racing rubber, if you switch to something like some Solaris OG's(it's a spec premounted tire, some shops sell them for about $25 per SET mounted & ready to use) or Jaco Blue premounts, I think you'll see a BIG improvement everywhere....
Bob Seay
Go Pokes!!!
Old 12-18-2011, 07:10 PM   #1911
RC Passion's Avatar
Toe out helps to increase steering, but also causes the car to wander while trying to go straight! Try a more neutral toe or even a degree of toe-in in the front. Tires, like the other guys mentioned, are a big factor in getting the car to hook up! Ask "the fast guys" what tires they use and go from there!
RC Passion is online now   Reply With Quote
Old 12-18-2011, 10:39 PM   #1912
Yes thats true but from what the Xray T3 setup book says (FRONT TOE)
toe in 'increases nervousness' 'makes car more difficult to drive"
toe out 'increases straight line stability' 'makes car easier to drive"
since im having straight line stability issues thats why i have the front toe out.
Think i need the rear to toe in more with the suspension blocks by the look of things
Gonna start again with nuetrul front toe and work from there.
Will get better tyres once the ones i have now are gone as they are newish and only been ran around 3 times lolol
Old 12-20-2011, 03:35 AM   #1913
Been reading thru the manual alot lately and found out that the previous owner has used wrong parts to build the car im like WTF !!!!
So gonna get the right parts and sort this out !! no wonder it didnt run right at high speeds !!!
Thanks for the above info/tips and ppl trying to help me out deffo appreciate it
Old 12-29-2011, 10:27 AM   #1914
CSeils's Avatar
Trader Rating: 48 (100%+)
Has anyone been having issues with the front diff thrust bearing wearing out quickly? I built the diff according to the instructions. Once the bearing goes, it loosens the diff to the point that I'm driving a two wheel car. I have gone through two of them in the last 8-10 races.
Any suggestions?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 12-29-2011, 10:58 AM   #1915
C5R01's Avatar
Send a message via Yahoo to C5R01
Any suggestions?
Check your thrust bearing direction, one side is round on the edge and one side is flat.. Flat side goes on the oudside. If you don't do that it loosens and issues evolve.. Fred told me about that ( it is not listed in the directions).
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 12-30-2011, 04:38 PM   #1916
Super Moderator
Grizzbob's Avatar
And if that doesn't help, you could always get a TOP racing ceramic thrust assembly, works great in that car, the 416, & even in my DB01R, smooth & VERY long lasting. Having said that though, I do have to admit I don't run a diff up front, I actually prefer a spool(but I have the ceramic setup in my rear diff, smooth as silk & lasts MONTHS before needing a rebuild)....
Bob Seay
Go Pokes!!!
Old 12-30-2011, 07:35 PM   #1917
CSeils's Avatar
Thanks guys,
I checked the Tamiya thrust bearing to make sure i had it in correctly. If I have more problems, i'll change to a TOP bearing.
Since I am using it for VTA, I can not use a spool.
Thanks for the help.
Old 12-31-2011, 09:15 PM   #1918
Super Moderator
Grizzbob's Avatar
Thanks guys,
Why not? I haven't seen any rules prohibiting spools for VTA(& I run my v2 in VTA when I can, & that's what I use in my car). Maybe I missed something, or your local track has rules I'm not aware of?
Bob Seay
Go Pokes!!!
Old 01-11-2012, 08:22 PM   #1919
Trader Rating: 20 (100%+)
Do they sell suspension blocks in plastic? Don't fancy buying the aluminum ones at ten bucks a pop.
Gyr0 is offline   Reply With Quote
Old 01-11-2012, 09:06 PM   #1920
@Art_Mighty's Avatar
Thanks guys,
Current VTA rule set
According the the rules spools are just fine. A lot of us use spools or gear diffs with really thick greases / diff locking fluids. Most tracks end up banning one-ways in VTA for some reason.
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
