Old 12-01-2011, 05:04 PM   #1891
Post Ta05 Gear Diff
Purchased the TA05 Gear diff #54312. What size Hexes are the really tiny screws that hold the diff halves together? Thank you for your response.
johntrickle2 is offline   Reply With Quote
Old 12-02-2011, 09:31 AM   #1892
Zac_with_no_K's Avatar
Questions??
I'm running a 13.5 brushless motor with 64 pitch gears. 28 pinion 81 spur
When running it in the street (no track time yet) the motor is usually just warm but the ESC gets noticeably hotter than the motor. I've only been using 3000 mAH 7.2v NiMH batteries but I got a 5000 mAH 40c Li-Po that I haven't used with it yet.
I'm worried if I have a bad gear ratio I'm going to kill my ESC.
I still don't understand gear ratios or anything, but is my set-up a recommended ratio?
If not, where should I start and what size gears should I invest in?
Anything helps, thanks.
Zac
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 12-02-2011, 04:55 PM   #1893
Starteur's Avatar
Does somebody have the part number for the gear diff outdrives? I want to buy spares!
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer.
Starteur is offline   Reply With Quote
Old 12-02-2011, 06:31 PM   #1894
It's the S parts
# 19115157
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 12-02-2011, 06:57 PM   #1895
Starteur's Avatar
thank you!
Old 12-02-2011, 09:12 PM   #1896
Starteur's Avatar
Can't find it......
Old 12-03-2011, 06:34 AM   #1897
Starteur's Avatar
[IMG]///C:/Documents%20and%20Settings/home/Mes%20documents/Mes%20images/header_54312.JPG[/IMG]
Here is what I need
Old 12-03-2011, 05:17 PM   #1898
To you guys that are running the Exotek chassis.....can you post pics of how you routed your wires from the esc to the motor? I know the plastic tub has the brace/guard but since you lose that with the carbon chassis you lose that brace.
nickvig is offline   Reply With Quote
Old 12-04-2011, 10:26 PM   #1899
WC
WC's Avatar
Trader Rating: 28 (100%+)
should be 1.5mm if not 2.0... definitely metric
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 12-05-2011, 01:22 AM   #1900
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
TA-05 ver.2
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-10-2011, 04:09 PM   #1901
Trader Rating: 68 (100%+)
New to Tamiya,what is the difference in the rearmounts==1a,1c,1d the inner rear mounts,is this for toe?or width?thanks
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-12-2011, 08:04 PM   #1902
http://www.petitrc.com/reglages/tami...ckSettings.pdf
Old 12-17-2011, 03:19 AM   #1903
Hi im a newbie on this forum
ive been reading thru 100+ pages on this thread and im having probs with my ver 2
The problem is that on the straights and high speed corners the car just spins even with a little tap on the controller and hardly runs straight, On the low speed corners its just about borderline and the rear just wanna break loose (as theres enough grip up front to throw it off)
(I checked the arms are equal length etc etc)
Specs:
TA05 ver 2
Brand new carbon reinforced chassis
Universal front driveshafts
Front medium sway bar
Rear soft sway bar
TRF dampers with medium springs ( 2 holes, 55wt oil)
Tamiya SS-RZ motor 5.75.1 gear ratio
Tamiya medium narrow tyres all round
Front ball diff (tight as i dare)
Rear ball diff (loose)
I kinda know how to tune a car and i have the xray setup manual to guide me thru, plus ive done things to make it 'understeer more' but its still the same (without going to extreme angles on toe and camber)
alex_evo is offline   Reply With Quote
Old 12-17-2011, 06:11 AM   #1904
VooDooPH's Avatar
Specs:
TA05 ver 2
Rear soft sway bar
Check of you're using the same sized diff pulley front and rear. Kit comes with both 36 & 37 pulleys. Also running a spool up front and harder springs in front.
Old 12-17-2011, 07:30 PM   #1905
Thanks will give that a check, didnt know the kit came with different size pulleys as i bought mine pre built 2nd hand ages ago lololol
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
