TA-05 ver.2
#1831
Would 44mm universals work in the rear without changing anything?
#1832
Also, does anyone has a good high bite asphalt setup for westcoast? I had no success with my car with high bite surface..... It does work really well on Tamiya America track though...
#1833
If you have a R spec chassis, I recommend using the 46mm universals all around, the 44mm keeps poping out on me so i went with the 46. also make sure to shim the diff properly. The diff housing has waaaaaaaaaaaaaaaay too much play....
I don't know what high bite aspalt tracks are like, but these cars don't work well on it?
#1834
Lol, Np! Actually, people tell me on high bite tracks, tub chassis doesn't work that well due to excessive flex but I don't know for sure. I think it's more of a skill and setup issue. I currently use the carbon reinforced chassis pan and it is a little stiffer then the stock ones. I'm not too concerned about if this chassis is not competitive on high bite tracks or not. I just wants to get the most out of my car So someone plz help me out with the setup!
#1835
Ball thrust bearing
Question for you TA05 guys. I see in the manual that the diff uses a thrust bearing not individual balls. If this is correct could someone tell me what the O.D of the bearing is. The reason I ask is I'm thinking about trying it my kyosho scr.
Thanks in advance, Gary
#1836
Super Moderator
I have to double check the number on them tomorrow when i get back home.
The Rear i am using Silver Stock Team Magic Springs that came on a E4RS.
2.5-3.0 rear toe, 1 degree camber front and 1.5 rear.
I have removed shims from my camber linkage aka roll center adj.
And then i have to transfer all the Droop and ride height info of my car to paper.
Front tight diff, rear normal.
Those major settings gave me good results.
Then i have switched to EX05 Chassis still with lay down shocks, i had a complete different set up. Which at times i am trying to get rid of traction to stop traction rolling.
#1839
I am using medium springs from a Losi JRX-S Type R in the front.
#1840
I believe the info you need is here: http://www.speedtechrc.com/store/ebp...id=866&id=7734 . And btw, that thrust bearing I linked to works VERY well, combined with ceramic diff balls, makes for an INCREDIBLY smooth diff(even use them in my DB01R, works great)....
Thanks, Gary
#1841
Super Moderator
Thanks for the info grizz. One more thing, because the id of the bearing is .5mm smaller than the kyosho thrust bolt and nut, I will need to get the tamaya ones. I have done searches but not nothing comes up on where to get one. Little help, if you may know. Never mind, I found it
Thanks, Gary
Thanks, Gary
#1843
R/C Tech Elite Member
Front: -1 Camber, 35W Oil, White Springs, 1 degree toe out, Front Gear Diff 300k fluid, 4mm rocker arm spacer, TRF Shocks with 2 hole piston
Rear: -1 Camber, 35W Oil, Yellow Springs, 1A, 1D Blocks, Shock position 1 on rear tower, no antisquat. Rear Spec-R gear diff 10k fluid.
No Sway bars, Direct Drive Centre, 5.5mm front, 6mm rear ride height. I use this as a general starting set up on whatever track I run and make minor changes from, there.
Running it in VTA at the moment.
#1845
I tried double gear diffs at the Tamiya TCS Final. Front at 100,000 and rear 1,000. I put green slim on the O-rings and gaskets.
Front no leak at all and the diff action stays consistent. But the rear did have some leak at the outdrives, nothing from the pulley.
