Old 06-18-2011, 02:09 PM   #1801
theatriks's Avatar
Hey skitte great set up came 2nd today out of twelve racers thanks again
theatriks is offline   Reply With Quote
Old 06-20-2011, 03:45 PM   #1802
Zac_with_no_K's Avatar
Can someone post a links for both the yellow and the blue springs?
I don't know what to look for. And have very limited computer use, as my computer recently fried.
If possible www.tamiyausa.com or www.towerhobbies.com
Last time I ordered springs, I got all short ones.
Anything helps,
thanks
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 06-20-2011, 06:19 PM   #1803
Anything helps,
thanks
speedtechrc has the white set of regular sized onroad springs
tamiya part # 49382
speedtech has a lot of tamiya at great prices. jeff and albert are the best!
oh the regular set of onroad springs is tamiya part # 53440
platypus_s13 is offline   Reply With Quote
Old 06-20-2011, 11:12 PM   #1804
Skitee's Avatar
Glad I could help
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-01-2011, 01:57 PM   #1805
Questions??
I noticed in the hop-up section on the manual it said to get the florine coated TRF shocks. I have hard black coated TRF.
Will these not work as good? What are the differences?
And also noticed it came with white - yellow dot springs. Are these medium hardness?
Any advice helps,
Zac
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-01-2011, 02:46 PM   #1806
Any advice helps,
Zac
if i understand correctly you have a set of trf shocks that you bought. they should be the same shocks as the ones listed as a hop up in the manual. the white springs with the yellow marks denotes that it is the same as the regular yellows, so you are correct. they are medium. people used to and probably still do like to hide their setup secrets so tamiya came out with special white or milky blue springs that all looked the same but had small markings so you would know what rates u were running but at a glance ur neighbor wouldn't.
Old 08-02-2011, 11:27 AM   #1807
Thanks.
So it really doesn't matter that I got the hard black coated trf vs the florine coated
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-02-2011, 07:46 PM   #1808
Super Moderator
Grizzbob's Avatar
Thanks.
No, not much, the ones you have will do VERY well, & if you feel like upgrading sometime later, you can always just buy the HL shock bodies(but I think you'll be hard pressed to tell the difference, I sure can't)...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-02-2011, 08:31 PM   #1809
Awesome, thanks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-03-2011, 02:49 AM   #1810
BBP
Guys, I am running orca 11,5T with LRP SXX ESC, with 64p 103T spur gear and pinion gear is 34T. After several laps running, the motor is very hot. I think the spur and pinior gear are not matched. Could you suggest me what pinion gear I should use?
The track is about as big as backetball court
Thank you guys
BBP is offline   Reply With Quote
Old 08-03-2011, 09:46 PM   #1811
Super Moderator
Grizzbob's Avatar
Thank you guys
Well, as always, it's hard to diagnose without actually seeing the track layout, but I would think that your FDR(which would be about 6.22:1, if my math is right) might be a bit tall for an 11.5 motor(especially if your ESC has any timing advance in any of its throttle profiles, which I think the SXX can do), so you might try going down a couple of teeth on the pinion, maybe 3 teeth, & keep a close eye on the motor temp every couple of minutes(would also be good if you have access to a temp gun, maybe someone at your track can help you there). If you can monitor with a temp gun, I'd try as a rule to keep the motor temps below 170 F, that should keep your motor from being damaged....
Bob Seay
Go Pokes!!!
Old 08-04-2011, 07:43 AM   #1812
BBP
Ok thanks Bob, will give it a try
Old 08-04-2011, 04:12 PM   #1813
What is the best body for performance?
I have the Cusco that came in a kit, but I think it's better for looks than performance. It looks like the Rayberg bodies are pretty good.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 08-05-2011, 08:10 AM   #1814
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
the NSX's are pretty stable all around bodies... but i also like running the Corolla Axio... very pointy yet runs flat through the corners
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-05-2011, 11:32 AM   #1815
Awesome, I'll check those out. Thanks
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
