Old 04-13-2011, 03:29 PM   #1741
@Art_Mighty's Avatar
Originally Posted by RCveteran View Post
I am rebuilding a TA05 IFS I bought used and have a few burning questions?
4) It seems the instruction manual for where to rotate the diff carriers to for belt tension is very loose too?
Yeah it's strange and I've asked a few people about it. So far everyone has directed me to run the car with those belts very slack.
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 04-21-2011, 12:57 PM   #1742
Hey guys,
I'm new to Tamiya cars, and just recently built up a Ta-05 v2.
its powered by a mamba max pro + 6900kv motor.
I took it out for a test run last night.. and drove it into the curb.
that has left me with a broken steering knuckle.
I'm looking to upgrade that to aluminum, just wondering what the correct part numbers are.
Also, I want to run CVD's as the ones that came with the car keep popping out.
does anyone know what would work for the v2's ?
nev_neo is offline   Reply With Quote
Old 04-21-2011, 04:32 PM   #1743
Trader Rating: 35 (100%+)
Originally Posted by nev_neo View Post
Hey guys,
CVD Parts List (Listed on page 17 in the TA05 ver.II instruction manual)
51092 46mm Swing Shaft
53500 Cross Joints For Assembly Universal Shaft Set
54076 Wheel Axle For Assembly Universal Shaft
Geppetto is offline   Reply With Quote
Old 04-21-2011, 04:52 PM   #1744
Thanks Geppeto.
Didn't think to look in the manual. This is a whole different set of parts in here !
Old 04-22-2011, 03:15 PM   #1745
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Or run a diff belt with one less teeth.
How much slack do yall have ?
There are some belts with their teeth counts. And what they came out off.
Just make sure to match wide and slim belts with correct diffs.
http://formuladrc.forumotion.com/t33...r-some-cs-mods
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 04-22-2011, 06:00 PM   #1746
bl4
bl4's Avatar
Anyone tried running center one way with front spool?
bl4 is offline   Reply With Quote
Old 04-23-2011, 05:25 AM   #1747
Well...
(as per the manual and your nifity table, everything's stock by the way)
Center = 18T
Diff = 37T
Belt = 166T
And the A2/A11 combo is set to notch "#4" from the center (on the loose side). What does that all mean?
When I take my finger and press down on the middle of the belt, it depresses almost to the point where I can make the two touch. It's really slack, but it's the stock settings and the car works REALLY well. I don't think it's wrong, just surprisingly loose...
ALL IS LOST
Old 04-26-2011, 05:50 PM   #1748
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default Q
Guys,
What is the best alternative to eliminate linear drive chuckle, I have my TX down all the way to 70% but for short tight tracks the turn rate is to wide.
It has Tamiya 416 universals and spoll.
Other universals? Someone suggested piccking up the front suspension have you heard about this?
I apreciatte your feedback,
Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 04-26-2011, 05:59 PM   #1749
Trader Rating: 69 (100%+)
Originally Posted by HeliYogi View Post
Guys,
Marcos
There will always be chattering for spool. It's something to do with resonance frequency since both wheels are locked and any slight variation in rotation mass would not get dissipated through differentials.
But if you put it down on the ground and run it, the problem will go away because overall ratation is slower, plus the tire act as a resonance damping for the spool. There are no known problem with the chatter, even when running in mod. The TRF driver Jilles said: "The chatter which you get running a spool is normal, when you drive you will not notice it anymore." from http://www.petitrc.com/reglages/tami...ssisSetup.html
eComet is offline   Reply With Quote
Old 04-27-2011, 12:11 AM   #1750
Guys,
Marcos
the spec.r dcj's or the arrowmax ecs' should get rid of the chatter especially if u feel like spending some hard earned money.
platypus_s13 is offline   Reply With Quote
Old 04-27-2011, 12:39 AM   #1751
HeliYogi's Avatar
Thanks guys!
Old 05-12-2011, 08:41 PM   #1752
Zac_with_no_K's Avatar
Questions??
Should I make any changes in the car from switching from carpet to asphalt?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 05-13-2011, 05:15 AM   #1753
What class are you running? (...because I'm wondering this as well)
ALL IS LOST
Old 05-13-2011, 06:06 AM   #1754
skadoosh's Avatar
Does anyone run this for drifting? If so, what ESC or motor do you recommend?
yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the "present."
skadoosh is offline   Reply With Quote
Old 05-13-2011, 06:11 AM   #1755
Chrissy C's Avatar
Default Gear Diff
Am I right in thinking that Tamiya were showing a gear diff for the TA05 at a recent show? Any more details on release dates etc?
Chrissy C is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
