Old 04-06-2011, 03:24 AM   #1726
SteveM's Avatar
Trader Rating: 128 (100%+)
...edited
SteveM is online now   Reply With Quote
Old 04-11-2011, 07:25 AM   #1727
Almost got mine ready to run. V2 R with the aluminium rocker arms and racing steering set, and Tamiya Titanium screw set. It'll have a Hobbywing Extreme Stock ESC and 17.5 motor. Anyone got opinions on gearing for a medium sized outdoor track?
xsnoizta05 is offline   Reply With Quote
Old 04-11-2011, 07:34 AM   #1728
bl4
bl4's Avatar
Which one is the correct aluminum bulkhead #53990 or # 54019?
bl4 is offline   Reply With Quote
Old 04-11-2011, 07:54 AM   #1729
slakr's Avatar
Trader Rating: 28 (100%+)
54019 is for the front if you have the IFS suspension...
53990 is for the rear (and the front if you do not have IFS)
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 04-11-2011, 03:05 PM   #1730
this is probably a completely noob-ish question, and probably has been answered way back, but I couldn't find much on it. my question is, are there still rear spools available for this chassis? I'm looking to get into drifting my ta05 ver2 and understand that a 1 way up front and a rear spool would help out, but everywhere I looked, the spool is discontinued. Is my only choice to start gluing things together?
aroddalobster is offline   Reply With Quote
Old 04-11-2011, 04:03 PM   #1731
the front and rear are the same. so just get one for the front and you will be good. tamiya part # 53877
platypus_s13 is offline   Reply With Quote
Old 04-11-2011, 06:18 PM   #1732
cation3's Avatar
...and if this is for use with a VerII, get the 37T pulley (54023) to keep the gearing correct. The VerII has 37T pulleys, but the Front Direct Coupling (53877) comes with a 36T pulley and you'll still need another pulley, like my blue monster....
-Drew
cation3 is offline   Reply With Quote
Old 04-11-2011, 08:05 PM   #1733
I'm running a 10.5 on stock gearing with lots of torque and cool temperatures. What's a good pinion gear to go to for more top end?
Thanks.
So low my body sweeps pebbles.
chunked foam is offline   Reply With Quote
Old 04-12-2011, 05:09 AM   #1734
SKYLINEE's Avatar
Cool
i got the TA04 lol. i think its a lot better then TA05 but thats my choice
SKYLINEE is offline   Reply With Quote
Old 04-12-2011, 10:39 AM   #1735
Zac_with_no_K's Avatar
Questions??
Sorry I don't know how to make the pictures expandable when you click them..
I finally finished my new shocks. I got the small springs but I don't know if they're too small.
I had to twist the cylinder nut almost as far as it could go.
Will this effect how it handles?? Should I get springs a size bigger?
Anything helps thanks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 04-12-2011, 10:50 AM   #1736
OSherman's Avatar
There are still threads showing on the end of the shockshaft.. thread the lower ballcups on a lil more till they just bottom-out. that should help.
OSherman is offline   Reply With Quote
Old 04-13-2011, 01:35 AM   #1737
kentech's Avatar
To be announced at Shizuoka:
TA05 Gear Diff Unit
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 04-13-2011, 07:18 AM   #1738
WC
WC's Avatar
what's the wager the geardiff will be SpecR unit rebagged?
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 04-13-2011, 09:26 AM   #1739
I am rebuilding a TA05 IFS I bought used and have a few burning questions?
1) Does anyone have close up pics of the aluminum suspension mounts mounted. I have a bunch in a bag and want to make sure I use the spacers correct that slip over the suspension pins. In rear right now on FR mount, I have one blue aluminum spacer and not sure what to call it longer thingy plastic ball that fits inside mount and FR side one thin black plastic spacer and short black ball thingy. This seems to be my best combo I can find for free movement of the arm while not letting it move back and forth. I was going to start with zero toe in rear for now.
2) Does the diff need to be shimmed side to side in the housing, without shims it will move a bit side to side, not sure how much is "normal"?
3) I am combining some parts from an old highly modded TA05 one of which is the carbon 4004048 lower plate, any issues, it all seems to bolt up fine?
4) It seems the instruction manual for where to rotate the diff carriers to for belt tension is very loose too?
RCveteran is offline   Reply With Quote
Old 04-13-2011, 02:03 PM   #1740
I have used both springs a lot, the small springs compress up or pack up a lot quicker than the long ones, I found them suited to small circuits with tight corners because they tend to make the car slide and react much quicker.
The long ones will be easier to drive and generally suited to high speed corners because they will have a longer slower role in the car. But then again its whatever suits your driving.
Eat more possum!
Lees52 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
