Old 02-01-2011, 02:08 AM   #1591
May I ask what this aluminium crank bell is? I have a TT-01 Type E.
Will it fit my car and what are the advantages?
omegaf is offline   Reply With Quote
Old 02-01-2011, 12:20 PM   #1592
fantapants22's Avatar
the bell crank is the piece that goes inbetween the steering servo arm and the steering rods attached to your knuckles, its mounted in place with two arms attaching to the steering rods that pivot 90 degrees left or right which turns your wheels,
the advantage of having an aluminum (or carbon fibre even better as its lighter) is that it will tighten up the stock plastic steering slop and play which in turn will give you better accuracy and response in steering along with the car not verring of to one side when going down a straight,
the pic attached is the bell crank you need which fits all TT01 and E, they are about $24 at most
http://cgi.ebay.com.sg/Alum-Bearing-...-/280574248048
Savage X with LRP.30, Team Associated RC8.2 With LRP.21, Kyosho MP9 CNC upgraded with JS Racing 521R, Kyosho Spada 09, Kyosho Mini Inferno 09 (nitro), Traxxas Mini Revo massively hopped up, Parkzone Radian Pro DX6i. Eflite Blade MCPx
fantapants22 is offline   Reply With Quote
Old 02-01-2011, 12:38 PM   #1593
ah i see. i have already ordered one of those. i just didn't know what it was called. thanks
Old 02-01-2011, 12:44 PM   #1594
hahah all good mate, definitly better off with it than without it!
Old 02-01-2011, 10:21 PM   #1595
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default To rotate or not rotate... That is the question :)
Last race at TCS one of the Pros marked my tires with a sharpie (RL, RR, FL FR). But what for I asked, don't you rotate them?
When running foam tires after each race I rotate them to prevent uneven wear. Do you guys recommend or not rotating rubber on the TA05 V2?
Thanks for the input...
Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 02-02-2011, 04:07 PM   #1596
Originally Posted by Gyr0 View Post
So im looking to get a servo for my car and curious as to what specs I should be looking for. Like how much torque is sufficient and stuff.
part number HRC31077S
I ordered this Hitec low profile servo, it is easier to fit a reciever in its spot it has 61oz of torque...it is about 2 1/2X the price of a standard servo so I hope it will perform better.
TA05V.2+TA05V.2R+TG10.MK-2+LST2+TNX PRO+TERRA CRUSHER PARTED AND SOLD+TNX 5.2 SOLD
daycrusher is offline   Reply With Quote
Old 02-06-2011, 10:30 AM   #1597
Zac_with_no_K's Avatar
Questions??
My TA05 is way louder compared to everyone else's cars at the track. Is there anything I can do to make it way quieter?
I think it has something to do with the spur/pinion?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 02-07-2011, 03:24 AM   #1598
Zac,
If you are using 48 pitch gears, it's going to be louder than the cars that are running 64 pitch gears. That being said, you may have the gear mesh a little tight. You can run the 48 pitch gears pretty loose. Try backing the mesh out just a tad. You may have a bearing going bad too so check those.
You have a pm
woodys3b is offline   Reply With Quote
Old 02-07-2011, 09:03 AM   #1599
Trader Rating: 14 (100%+)
also make sure your belts are not too tight... its a rookie mistake, heh
boza is offline   Reply With Quote
Old 02-07-2011, 10:11 AM   #1600
Originally Posted by woodys3b View Post
Zac,
You have a pm
Thanks, I am using a 48 pitch pinion with the stock spur. There's already a little play inbetween but I'll try backing it off a little more.
And belts are more loose than tight.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 02-07-2011, 10:17 AM   #1601
digitrc's Avatar
Since the TA05 does not come with a 48dp spur gear as standard, this is probably your problem. Your pinion does not mesh with the spur. Depending on the TA05 kit you have, it either has a 0.6 or 0.4mod spur, and you need to get a pinion of the same pitch, or exchange the spur for a 48dp one.
David Allen - www.digitrc.co.uk - Xevo - Much-More Racing UK
digitrc is offline   Reply With Quote
Old 02-07-2011, 01:20 PM   #1602
Default low profile servo
Well I got HRC31077S hitec servo in the mail today...doesn't fit anyone know of a low profile servo (shorter) that will fit in this car?
Old 02-07-2011, 01:42 PM   #1603
Trader Rating: 20 (100%+)
Really so your still looking for a shorter servo? Are you mounting the receiver on the floor of the chassis? That might be it. I usually have to mount it on top of the servo. I went going with a savox mg125 I think, but I think Im still going to have to get one of the pro receivers so all the electronics can be on the "floor".
Gyr0 is offline   Reply With Quote
Old 02-07-2011, 03:58 PM   #1604
I didn't know that.. Is it bad to run like that?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 02-08-2011, 12:32 AM   #1605
Won't be very effecient......either get the correct Tamiya pinion to match the Tamiya spur or change the spur to a 48P and use 48P pinions.
Will still be more noisey than running 64P but not as bad as you have it now!
mr lee is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
