Old 08-09-2009, 11:35 PM   #136
slakr's Avatar
Trader Rating: 25 (100%+)
Found it...
Low = 10*
Mid = 20*
High = 30*
Turning the endbell counter clockwise inceases timing
AE B6D,TC7|Mugen MBX7TR Eco|JQ THE Car WE,eCar WE
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 08-12-2009, 12:05 AM   #137
kdeselms's Avatar
Hey, took my car out to the track on Sunday and encountered a couple issues, was hoping I could get some tips. First of all, I think I'm going to upgrade the front axles to CVD's - I found that when I had the front wheels turned all the way left or right, the pin on the axle side of the dogbones would be almost completely out of the axle - so when I'd accelerate with the wheel turned, the dogbone would pop right out of the axle and get stuck. I stuck an o-ring in the outdrive to push the bone further into the axle, but that's an issue with the kit setup.
The other thing was, after I would have a collision - even a minor one, sometimes - my steering would start pulling to one side or the other. I looked at the axles and the steering linkage but it seemed fine. Any idea what this might be caused by? Everything is pretty much plastic in this kit, so I'm assuming there's a lot of room for slippage or tweak if I run into something...which I'll hopefully do a lot less of, with a few more practice sessions!
I love this car so far though, tons of fun. Huge adjustment from driving off-road for the last year!
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 08-12-2009, 01:17 AM   #138
niznai's Avatar
The driveshaft popping out of the wheel axle is pretty much common on the TA05 type cars as well. You have found the solution however. Later, universals.
About the steering becoming misaligned I would check to make sure there is no binding or any other problem with the linkages, suspension, etc. Assuming everything checks out, I would guess it is a servo saver issue. The kit savers on these kits (and even the high torque upgrade saver from Tamiya) are pretty crappy. What happens is that for every shock in the steering, the circular springs hit the plastic shoulders on the saver arms and chip away a bit of plastic so the spring doesn't rest against the shoulders where they did when new any more. This allows for a new "zero" position to be set and of course your wheels are not going to be straight with this new zero position.
Get some decent saver such as one from Kimborough and you'll be fine. Plastic everywhere doesn't help as you realised, but the saver really leaves a lot to be desired.
The other way around it is to get a serious servo and go without a saver, but I am not a fan of this idea. I run some of the best servos there are in my cars and still use savers. After all, a JR servo (8715 I think is the number for the US market) is almost the price of the whole damn car!
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-12-2009, 08:43 AM   #139
nagatahawk's Avatar
I have run touring cars and the plastic parts have more give than the composite parts such as the arms, uprights etc. they should be able to take a hit without breaking than the more brittle parts. that is unless you should hit the driverstand wfo! The composite parts should give you a more precise fit, then again your set up needs to be more precise. You will see set up stands ($$) in the pits. It all depends upon what level you want to take it.
nagatahawk is offline   Reply With Quote
Old 08-12-2009, 10:09 AM   #140
Hebiki's Avatar
Trader Rating: 26 (100%+)
upgrade your servo saver. the stock plastic one strips easily in a crash and will cause your car to wander.
as mentioned above, the kimbrough servo saver is great!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-12-2009, 03:02 PM   #141
kdeselms's Avatar
Can you guys give me a part number or link on the servo saver you're talking about? I was kind of wondering whether or not that could be the issue, the way their kit saver is set up seemed a little iffy when I assembled it.
Kevin Deselms
Old 08-12-2009, 07:19 PM   #142
bl4
bl4's Avatar
Is this the part number KIM114 for the servo saver?
bl4 is offline   Reply With Quote
Old 08-12-2009, 07:50 PM   #143
Super Moderator
Grizzbob's Avatar
That's not the one I use, I think mine's their 201 saver(at least it looks just like mine, hadn't really looked at the part numbers before now), works just fine on both my 416 & my TA05ver.2....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-12-2009, 09:43 PM   #144
bl4
bl4's Avatar
KIM201 is mid size. Will get 1 of this also.
Old 08-12-2009, 10:39 PM   #145
niznai's Avatar
Make sure the saver you buy fits your servo output shaft. Kimborough make them in various fittings but each will only fit one servo, so be careful.
Team Greasy Weasel
Old 08-13-2009, 06:24 AM   #146
bl4
bl4's Avatar
KIM114 is for Futaba
KIM201 will fit Futaba, Hitec, and Airtronics servos with holes 23,24,25 spline
Old 08-14-2009, 03:47 AM   #147
Default Large diff plate
Hi guys. This TA05 v2 uses large diff plate that requires synthetic cement. I have never used this style. The small diff plate, because it is not round in the inner edge, does not require glue or cement. So does that mean if we are to change the diff plate, we have to change the diff cup, too? Or can we disassemble the plate and reuse the diff cup with a new plate? Thanks.
xniperliams is offline   Reply With Quote
Old 08-14-2009, 03:52 AM   #148
Skitee's Avatar
You can use the old diff out drives with the new larger diff rings but you will need to use CA or the cement you spoke of to secure the diff ring to the out drive.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-14-2009, 04:05 AM   #149
Hi Skitee. Thanks. But that is what I am trying to figure out. After gluing it with the cement, would I still be able to reuse the cup if I need to replace the diff ring/plate in the future? If replacing the ring/plate requires replacing the cup too, that is a bit ridiculous.
Old 08-14-2009, 04:16 AM   #150
Skitee's Avatar
If you use the aluminum out drives yes you will be able to, if you use the plastic out drives then it depends if you can clean the glue/cement off the plastic.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 10:33 PM
SEO by vBSEO 3.5.0
