difference in 008 and 009 chassis and rear belt??? >
Old 04-18-2009, 12:57 PM
mickrcarver's Avatar
Trader Rating: 101 (100%+)
Default difference in 008 and 009 chassis and rear belt???
ok so what is the diff in the 008 and 009 chassis can you see a difference?? what all do i need to convert from foam us to rubber eu
mickrcarver is offline
Old 04-18-2009, 05:19 PM
freeway's Avatar
for the 008 all you need do is get the chassis, i use a US spec for my drifter and to use the 2.5mm EU spec i just buy the chassis. was planning to do that but i figured i will not get the flex in the chassis i was hoping for.
freeway is offline
Old 04-18-2009, 05:53 PM
but is there a physical diff in the chassis?
Old 04-18-2009, 06:00 PM
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Batteries are more forward on the 9 than the 8.
Kraig is offline
Old 04-18-2009, 06:02 PM
so the chassis will interchange?
Old 04-18-2009, 06:05 PM
Trader Rating: 38 (100%+)
I think they will interchange. Like mentioned above the battery is moved forward and out 1-2mm for better pinion clearance with NIMH battery bars.You may also need to change the top deck, but not for sure. And the belt on the EU is longer when you use the the forward holes on the 09 EU chassis.
chensleyrc1 is offline
Old 04-18-2009, 11:22 PM
lochness42's Avatar
Chassis is interchangable and belts are the same (if you're not using 38T diff gears instead of 34T).
Different belts are in new conversion for 009 for more forward motor position (not included in kit)
For conversion from US to EU, you'll need chassis and top deck, otherwise your car will be too stiff. Maybe front spool, but diff can do the job as well (also depends on motor you want to run).
lochness42 is offline
Old 04-19-2009, 11:21 AM
thanks
