Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-16-2009, 03:56 PM   #1
pakk's Avatar
Trader Rating: 16 (100%+)
Default balancing your tc
Just curious to what methods you guys are using to balance your tc's as best as possible?
Do they make mini pad scale? or just weight individual components.
--pakk
TC5
Slash
CRC 3.2r
CRC GenX10
pakk is offline   Reply With Quote
Old 04-16-2009, 05:07 PM   #2
--pakk
The easiest way to balance you car from left to right is with acouple of "Buttons" from either Hudy or IRS. You can find them at stormerhobbies pretty cheap.
Shawn.
Shawn68z is offline   Reply With Quote
Old 04-16-2009, 05:19 PM   #3
freeway's Avatar
i use the hudy`s myself, i heard there is a better alternative to the hudy buttons at amain hobbies.
freeway is offline   Reply With Quote
Old 04-16-2009, 06:46 PM   #4
Mr RCTech's Avatar
--pakk
Racers forget to balance the front to rear weight and not just the cross weights.
This is very important.
Scales is the best way on a level board or surface that can be repeated.
Tire wear (foams), spring sag, shocks pack, etc can change your wheel weights that may affect the vehicles handling.
Needs to be checked after every run.
Mr RCTech is offline   Reply With Quote
Old 04-16-2009, 06:54 PM   #5
pakk's Avatar
can you recommend a scale?
--pakk
TC5
Slash
CRC 3.2r
CRC GenX10
Old 04-16-2009, 07:06 PM   #6
Stratus Racer's Avatar
Trader Rating: 51 (100%+)
This is what I used for a while then just opted to sell them. Also by using only two of the four you can check for tweak. I now just use the hudy buttons as mentioned by others. Each scale holds upto 500grams so one scale couldn't give you the total wieght of a TC.
F. Mendoza
www.speedtechrc.com www.rclaps.com
Passing of Mr. Shookie 10-6-08
(( My Feedback Link )) www.rctech.net/forum/showthread.php?t=140685
Jim S swindled me: www.rctech.net/forum/showthread.php?t=181126
Stratus Racer is offline   Reply With Quote
Old 04-16-2009, 07:21 PM   #7
pakk's Avatar
That is not a bad idea. You can get pocket digital scales from ebay fairly cheap. I'll look into getting 4 of them.
--pakk
TC5
Slash
CRC 3.2r
CRC GenX10
Old 04-16-2009, 11:20 PM   #8
Jochim_18's Avatar
go to harbor freight around $12 for pocket scale....
--pakk
Goldenhillsraceway.com
Old 04-17-2009, 01:33 AM   #9
pakk's Avatar
cheapest ebay scale I could find that was located in the US.
This came out to $32 shipped for four of them if they do not combine shipping. I sent a message to the seller asking to combine shipping. Harbor freight would be around $52 after taxes. I'm going to try this.
--pakk
TC5
Slash
CRC 3.2r
CRC GenX10
Old 04-18-2009, 05:22 AM   #10
jrxs-r's Avatar
I personally use the Hudy Balance Pins on my Losi... The chassis comes drilled with Front/Rear Right/Left balance holes already, so the pins are convenient. I have seen the scales being used as well, and have also tried them myself, but make sure that the weighing face of the scales are exactly the same height in comparision to each other or the tweak/balancing will be out.
Cheers,
Zack
jrxs-r is offline   Reply With Quote
Old 04-18-2009, 05:47 AM   #11
Mr RCTech's Avatar
--pakk
All you need is a leveling board with four thumb scews and four scales.
Here are some links to scales:
http://rc4less.com/Parts_Boxes,_Wren...duct_info.html
http://www.lefthander-rc.com/catalog...roducts_id=763
Old 04-18-2009, 05:53 AM   #12
Mr RCTech's Avatar
Originally Posted by jrxs-r View Post
I personally use the Hudy Balance Pins on my Losi... The chassis comes drilled with Front/Rear Right/Left balance holes already, so the pins are convenient. I have seen the scales being used as well, and have also tried them myself, but make sure that the weighing face of the scales are exactly the same height in comparison to each other or the tweak/balancing will be out.
Not all scales are the same.
No food scales!!
You need to find 4 of the same scales that weight in troy oz,as well grams,oz etc. also, max capacity at least 600 gram or more per scale.
Old 04-18-2009, 06:00 AM   #13
Cammer's Avatar
I used the Hudy pins to balance the chassis laying out my components and balance weights, this doesnt change once its set. Then use 4 scales to ensure each tire is carrying its portion of the load. It is quite surprising how a quarter turn of the shock collar will make. It is also surprising how repeatable it is but this does have to be checked every time a suspension part is replaced. You can also see the tweek pretty quick with this.
Cam Mayor
Dyno Twister Motors and Batteries
Cammer is offline   Reply With Quote
Forum Jump
Hot Bodies Cyclone Frank McKinney Electric On-Road 17873 Today 02:00 AM
Around The Table With Paul Lemieux(RC-America/Trinity) Paul L Electric On-Road 1353 11-20-2009 08:19 PM
XRAY FK'05 setup rockstar81 Electric On-Road 77 06-17-2009 01:55 AM
Been out of the hobby for a little bit need a little refeshing C_Money Radio and Electronics 14 05-18-2009 10:13 PM
Is it time for Roar to update the TC weight requirement? dawgmeat Electric On-Road 35 03-26-2009 06:00 PM
A123/LIFE Batteries advice needed. Govert Electric On-Road 27 01-15-2009 01:16 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
