Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-16-2009, 04:08 AM   #1
Default Shock oil tuning?
Could someone explain what difference the oil weights make when tuning.
Goggles Paesan is offline   Reply With Quote
Old 04-16-2009, 08:02 AM   #2
Fastforward's Avatar
Higher viscosity shock oils take more time to flow through the holes in the shock pistons and therefore slow down the transition time for that corner of the car. Lighter oil will let the car transition faster. Finding the right balance is what chassis tuning is all about. You can also tune the shocks (sometimes called dampeners) by changing the piston in the shock to have more holes or larger holes.
Also, remember that the springs control how much travel you will have for a specific load and the shocks control the speed of the transition. If have too soft of a spring, you can't hold the car up with heaver shock oil.
Hope that helps.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 04-18-2009, 05:27 PM   #3
Thanks BBB.
Old 04-18-2009, 05:41 PM   #4
DaveW's Avatar
Keep in mind also that dampening pack can "feel" similar by jockeying piston hole size and oil weight.
For example... an Associated #1 piston with 50wt oil might "feel" the same as an Associated #3 with 20wt oil. By "feel" i mean when the shock shaft is moved in and out of the shock body by hand.
The difference on the track is a larger holed piston (less piston surface area) with heavier oil will always feel more planted and seem to provide more overall traction... and works great on medium bite asphalt and carpet tracks (even off-road).
DaveW is offline   Reply With Quote
Forum Jump
Hot Bodies Cyclone Frank McKinney Electric On-Road 17873 Today 02:00 AM
VTA tuning Q&A liljohn1064 Electric On-Road 408 11-19-2009 06:38 AM
Micro RS4 Thread thachowman Micro and Mini Scales 304 11-17-2009 02:54 PM
TC3 Forum Lowrider Electric On-Road 11301 11-16-2009 06:31 AM
Adding more steering rcjunkie3000 Rookie Zone 20 12-02-2008 01:18 PM
Complete Sell Out Everything To Go Racing! Matt S. R/C Items: For Sale/Trade 10 05-22-2008 06:04 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
