NEW TC design....have a look at this!
Hi guys, I was having a look around the web and found some pics of this new TC car. See what you think and put thoughts on here!
Cheers, Chris.
Cheers, Chris.
It looks pretty much like a type-r, excluding the shocks
I think we are. the chassis and belts are almost identical
Location: Colorado, USA, The land of the free and the home of the brave!
It looks like someone forgot to put the top deck on their JRXS-R dirt oval conversion..
Whoa, talk about balanced enough :P
"jesus tapdancing christ"
Looks interesting. The shocks really should be flipped over 180* to reduce suspension mass. We would rather have the shock piston & rod as part of the suspension mass and not heavy the cylinder & fluid...
That will move the weight further out from the centerline, but suspension mass is probably more important...
But the Suspension arms are very very short. I think it just works good on very high grip tracks.
LCG
I'm not loving the shock position! It's not efficace
I agree, the shocks should be flipped. I can't really tell what the other end is attached to but the shock shaft/piston end should be attached to the bellcrank. Probably makes almost no difference but I'm a perfectionist.
Also, the super short arms are a bit of a worry. Might work well like that though, have to wait and see.
