Old 03-11-2002, 10:28 PM   #1396
littledog's Avatar
R/C Tech Charter Subscriber
Al,Stefan has some pics posted in the xxx-s forum if you want a quick fix.
littledog is offline   Reply With Quote
Old 03-11-2002, 10:33 PM   #1397
stefan's Avatar
Send a message via AIM to stefan
Default Modena Al
shoot me an e-mail please, with a list of the parts you want done and what color you'd like and I'll get you a price.
stefan is offline   Reply With Quote
Old 03-12-2002, 12:53 AM   #1398
rcruv's Avatar
stefan > Great looking car. Do you have leftover parts?
TP > Are you using AE one-way or from other manufacturer?
Is AE front one-way long lasting?
Thanks for the help.
rcruv is offline   Reply With Quote
Old 03-12-2002, 02:09 AM   #1399
Corse-R's Avatar
Default Re: Diff building
Originally posted by Buda
when I start to go to the snetterton track which is big fast and sweeping I may give the one-way a go. How exactly does it alter your handling?
Buda:
This is the setup that I used on the snetterton track at Reedy Intl 2001. Maybe can be of advantage to you, is a setup with one-way, very docile and quick.
Front:
4 degree caster block.
2 degree kick up.
0 degree Toe-in.
2 degree camber.
#5 of ride height.
3 .020 of bump steer at each wheel.
No anti roll bar.
Gold spring.
50wt oil.
Piston #2
Middle hole at upper shock mount.
Camber link @ upper and inner.
Rear:
2 degree of anti squat.
2 degree toe-in.
2 degree camber.
#6 of ride height.
No anti roll bar.
Medium wheelbase.
Silver spring (maybe you can check with blue spring).
50wt oil.
Piston #2.
Camber link at upper and inner (move to the outside the other ball to enlarge the camber link).
Front one-way.
Tyres: Proline 1095 'BRCA' control tyre. Tire traction at your needs.
Inserts: Pit soft.
Body: PF Vectra.
If you got traction, reduce on one the amount of ride height (#4 front and #5 rear). All my problems at the Intl 2001 came from those nasty tyres and the choose of the insert (very critical).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-12-2002, 06:09 AM   #1400
D_Ames's Avatar
Send a message via AIM to D_Ames
Hey Stefan,
Nice car dude!!! looks a little different now. How's it running?
Dave
D_Ames is offline   Reply With Quote
Old 03-12-2002, 06:38 AM   #1401
Hi Guys
Can anyone tell me what general changes should be made to setup to incorporate a one way?
Should the car be softer all round?
Does it handle horribly whenu brake?
Also Corse R, do you reckon that setup would work on Take Off or Pitshimizu tires?
Thanks guys
Indy is offline   Reply With Quote
Old 03-12-2002, 07:19 AM   #1402
stefan's Avatar
Default Dave
I loved the car from the first day (except the Delrin diffs)
It's my carpet car and it's flying....
How about the pan car? Do you race it?
Old 03-12-2002, 07:47 AM   #1403
Corse-R's Avatar
Last weekend I raced on a track with microasphalt with a simmilar setup with Take Off 'B' with Sorex 'B' and Sorex 28 with Sorex 'B' insert.
Maybe you need to investigate a little and modify, but can be valid for you as a ballpark.
Cheers,
Corse-R
Old 03-12-2002, 08:07 AM   #1404
TPhalen's Avatar
rcruv- Ya, AE one-way. I've been running it since the car came out. Every 4th or 5th race night I do tear it down and do some maintenance. But, it's the same one, and I haven't had any problems....yet!!!
Indy- Brakes???? No brakes with a oneway... Well, that's not totally true. You will have to dial them out to something like 30-50%. I have a little in my car but they're for emergency purposes only. The surface you run on will determine how much you need to stiffen the suspension. Carpet, ALOT!!!! Hi-traction surface (not quite as much as carpet), a little bit more. We actually gold fronts and silver rears with a oneway. That seems to be a really good setup I have a couple oneway setups on my site or I'm sure there are a couple guys here that can help you out, too!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 03-12-2002, 10:11 AM   #1405
D_Ames's Avatar
Stefan, Yeah I know. Those delrin diffs were $50 bucks too
that was before AE had the plastic diffs.
I just started racing the 10L at SO Cal.... it flies. I'm doing pretty good with it.
Old 03-12-2002, 12:07 PM   #1406
stefan's Avatar
Dave,
did I ever tell you where I bought this car?
Old 03-12-2002, 12:37 PM   #1407
D_Ames's Avatar
No, could it have been So Cal!!!! LOL
Old 03-12-2002, 12:42 PM   #1408
stefan's Avatar
It was actually Ultimate Hobbies at Orange Mall :-))
So, that little car had a bunch of miles on it w/o ever touching the ground...
Old 03-13-2002, 09:25 AM   #1409
Thanks for your help Corse R and Tony.
Can you guys give me some advice? I'm racing indoor until April on a rubberised gymn type floor, where everyone uses Schumacher yellow mini pins. My problem is that the Losis seem to generate much more grip than the TC3s. My car seems to break away quite suddenly and the tyres only work when about 1/2 worn, whereas this is not as critical on other cars (ie HPIs and Losis).
Setup is close to standard - front 40wt, blue spring, standard shock and camber positions. rear 30wt, silver spring, standard positions. Battery forward.
Would moving the camber link to the upper inner hole help?
Help!
Old 03-13-2002, 09:45 AM   #1410
Buda's Avatar
Is the rubberized gym floor like astro turff or is it smooth. I race on an astro turff type floor with the mini pins in back and rally blocks in front that helped my back end from hooking around along with other set up stuff let me know if it is the same type of surface and I can give yuou my set up. However I still am working on it.
Buda is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
