Old 03-10-2002, 11:27 PM   #1381
Tech Legend
Wild Cherry's Avatar
Tony Phalen,
You say running a one-way can result in faster lap times...
When can running the car with out a one-way be faster ???
I been told running with out a one-way is faster on small layouts & when there is little traction...
I guess what I`m asking is , what conditions work best for each ?
Are you saying running a one-way is always faster no matter what size layout your racing on ?
Wild Cherry is offline   Reply With Quote
Old 03-11-2002, 05:23 AM   #1382
Flyer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Flyer
Wonderboy you welcome.
Yes, It is the parts.
Also the long posts can use for the front posts on your TC 3.
Flyer is offline   Reply With Quote
Old 03-11-2002, 06:57 AM   #1383
TPhalen's Avatar
TRF Powered. Ya, that was me. I usually run the truck with 16-18 cells and 9 turn motors but for the demo I only ran 14 with 11 turn. I have to keep the truck prestine for another week or two before I can bring it out for some REAL power...
Wild Cherry. I was basically telling him that a oneway at SoCal is a must. A oneway ANYWHERE is good to try. A few examples of where you DON'T want to run a oneway might be carpet. Carpet is way to aggressive and the bite steering of a oneway might be too much. Yes, tight hairpin tracks you might want a diff, but I would probably try a oneway and try to tune the car to it. I just like the way a oneway works.
If you don't have one, I would suggest getting one and just trying it one different tracks. You might be surprised at the results...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 03-11-2002, 11:21 AM   #1384
Buda's Avatar
Default Diff building
Any tips on building the diff besides following whart is printed in the destructions? I just got the lite diffs from the steel. Does the car actually need to be run on the ground or can I simulate running by grabbing a wheel while free wheeling the car I dont want the hassel of adjusting the diff while racing and dont want to run on the street as it usually wet this time of year.
TP when I start to go to the snetterton track which is big fast and sweeping I may give the one-way a go. How exactly does it alter your handling?
Buda is offline   Reply With Quote
Old 03-11-2002, 12:11 PM   #1385
TPhalen's Avatar
Lots o' steering and Lot's o' speed. Big sweeping tracks will definitely see an advantage of the oneway.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 03-11-2002, 12:43 PM   #1386
Regional Moderator
Send a message via AIM to Mike F
Originally posted by rcruv
26 pinion will be faster than 28?
The track right now has a long banked quasi straight way.
I don't know how they will change track next week.
I'll try 26.
I tried 27 and was one lap slower.
I asked a guy running faster than me and he said 26 or 27 should work fine. I'm confused.
I use TC2, Airtronics receiver.
Right, my AM radio currently has some glitch problem so I retreat from being too aggresive.
I hope my new FM radio would solve that out.
I directly soldered the motor and wires are short enough.
I use deans for the side by side packs I converted from cheap
sport packs.
On the P2K2 it likes to be geared like an MVP, go with 25-26 and you should have the speed your looking for. make sure that your brush hoods are aligned correctly also, this will increase your RPM slightly and wont wear your brushes unevenly.
Cutting the comm - man there are some guys that cut their comms after every race, just a pass over but still too much for me. After every race day is a bit too much as well but if it works then I say go for it. I would cut my comm about every 12-16 packs but ony if it needs it, I also run my comm stick in it about every 4 packs. The brushes I wont change unless they are worn, clean them with a Orian comm stick, or any other good comm stick then spray it clean.
The glitching that you experienced can be from anything. have you tried a shocky diode on the motor?
That Tc2 is pretty cool. I have the Cyclone TC and I love it.
Good luck
Mike F is offline   Reply With Quote
Old 03-11-2002, 12:45 PM   #1387
Regional Moderator
I'll try 26.
sport packs.
Cutting the comm - man there are some guys that cut their comms after every race, just a pass over but still too much for me. After every race day is a bit too much as well but if it works then I say go for it. I would cut my comm about every 12-16 packs but ony if it needs it, I also run my comm stick in it about every 4 packs. The brushes I wont change unless they are worn, clean them with a Orion comm stick, or any other good comm stick then spray it clean.
Good luck
Old 03-11-2002, 12:47 PM   #1388
Regional Moderator
Default sorry for the double post, I hate when that happens
Old 03-11-2002, 01:03 PM   #1389
tc3screamin's Avatar
Send a message via AIM to tc3screamin
Default one ways?
since were on the topic of oneways how good is the middle oneway tc3 im running on a hightraction oval thats running about 6 second laps???? ne opinions?
tc3screamin is offline   Reply With Quote
Old 03-11-2002, 02:50 PM   #1390
robk's Avatar
Trader Rating: 22 (100%+)
You don't want to run a oneway on carpet with foams. They work well in most situations with rubber.
Old 03-11-2002, 03:03 PM   #1391
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Actually, I prefer a one-way on carpet with foams.... I use diff outdoors with rubber...
ChristopherKee
ChristopherKee is offline   Reply With Quote
Old 03-11-2002, 03:25 PM   #1392
TPhalen's Avatar
I agree with robk...a oneway on carpet with foams is WAY overkill!!!!
Unless, you can tone it down... I'm interested in the rest of your setup, though, Christopher...can you post it?
Tony Phalen
RCDriver.com
CompetitionX.com
Old 03-11-2002, 09:04 PM   #1393
stefan's Avatar
Send a message via AIM to stefan
Default Bloody TC3
Check out my latest anodizing project.
Not completely finished yet..
stefan is offline   Reply With Quote
Old 03-11-2002, 09:17 PM   #1394
Use 80w up front with AE White (40) spring stood strait up. 40w in the back with AE Purple (30) in the rear second whole in. run 0 degree kickup and squat with 4 degree caster blocks. 2 degree toe in rear with with 0 degree up front. 4 droop front 6 rear. 4.5mm all the way around. Purple's and Plaids, full compound on rear.
If you want insane reaction on the switch backs use AE Yellow (35) up front 2nd hole in with 2 degree kick and AE Copper (25) in the rear.
Just adjust your Dual Rate till you get this setup down. If it's a large flowing track, I recommend the first setup. If it's technical... the second setup will eat every car on your track.
And... If you cant drive, use AE Purple (30) all the way around with shocks stood strait up. You'll learn to drive faster with this neutral setup.
ChristopherKee... These setups also work well on my XXX-S (before I sold it)
Old 03-11-2002, 09:22 PM   #1395
Default Re: Bloody TC3
OH OH OH OH OH OH OH ME LIKE ME LIKE ME LIKE
Looks good stefan! Definitly a good change from blue! I want to see pics when its done. How much do you charge to anodize? I may want my own custom color.
Modena AL is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
