Old 09-10-2001, 10:16 AM   #121
TPhalen's Avatar
R/C Tech Charter Subscriber
RE: Antisquat.
+2 gives 2deg of antisquat -- more forward traction
0 gives LESS antisquat -- less forward traction, slightly more steering
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 09-10-2001, 11:08 AM   #122
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Depending on the track surface, I always play around with the anit-sqat in the front.
For smooth tracks like SoCal i use the F-0 and for bumpy tracks like Ultimate i put the standard setting of F+2.
To me it does make a difference. Buy the option parts. In addition, you can also increase your castor with the F+2 and a company Megatech can actually take the castor up to -11 if you like.
I think those are the right numbers, dont have the car in front of me. Tony?
wolfeman09 is offline   Reply With Quote
Old 09-10-2001, 12:08 PM   #123
TPhalen's Avatar
Yes. Associated only offers the F+2 and F-0 anti-dive, or kick-up.
The castor Associated offers are 0deg, 2deg, and 4deg. 11deg caster would be REALLY wild...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-10-2001, 09:48 PM   #124
Jack Smash's Avatar
Trader Rating: 28 (100%+)
I tried f+o with 4 degree caster blocks on our very slick parking lot track this weekend. I had a ton of corner entry speed but sometimes a little too much. On med to high traction tracks i would definately like this setup.
Jack Smash is offline   Reply With Quote
Old 09-10-2001, 10:20 PM   #125
wolfeman09's Avatar
Tony > whoops, anti-DRIVE.
regarding the -11% of Castor, someone tried in in Vegas where there is really a big sweeper and said the car was awesome. May be worth a shot to try at Ultimate. That sweeper is bigger than SoCal.
Old 09-11-2001, 07:55 AM   #126
Default gear prep
Anyone here use Tri Flow or White Lightening on their gears to reduce friction? I hear some drivers do.
coolrcdad is offline   Reply With Quote
Old 09-11-2001, 08:08 AM   #127
redsand's Avatar
Send a message via Yahoo to redsand
Holy crap 11 deg front caster block ? That'll make the car oversteer when exiting corners for sure !
My home track has banked 25 deg sweepers, the surface is kinda bumpy a bit, therefore I stick with 4 caster block and 2 kickup - that stabilizes the car on straight lines. If the 2 antisquat is installed, I can bury the throttle on the banked sweepers, the otherwise happens whenever I run with 0 deg antisquat.
redsand is offline   Reply With Quote
Old 09-11-2001, 09:06 AM   #128
Corse-R's Avatar
Default Re: gear prep
Umm, I prefeer to run with nothing in my gears, these are made of self lubricating material.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-11-2001, 10:12 AM   #129
Send a message via ICQ to Jean Alesi
I already snapped 3 center driveshafts in just a week. Can anyone give me a suggestion how to get rid of this problem?
Thanks a lot.
Jean Alesi is offline   Reply With Quote
Old 09-11-2001, 10:42 AM   #130
wolfeman09's Avatar
Jean,
how hard are you hitting things I have had the car for 2 years and the only thing i have broke is arms.
Tony > have you got my private messages? i have not heard back from you and you usually do.
thanks...
Old 09-11-2001, 01:20 PM   #131
bebob's Avatar
Get yourself a YOKOMO!It is stronger than a TC3!TC3 sucks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
bebob is offline   Reply With Quote
Old 09-11-2001, 01:41 PM   #132
TPhalen's Avatar
hey bebob...yer on the wrong thread...
ya, i got yer private messages...i just haven't had a chance to look at the files yet...been mucho busy...
Shafts. make sure you have the little o-rings to take up the slop.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 09-11-2001, 02:15 PM   #133
bebob's Avatar
Stop crying and I know the yok is better!tusk tusk!!!!!You wont need to cry if you are running a YOK cause tou will always win with one!!!!!!!!!!!!!!!!
Old 09-11-2001, 02:27 PM   #134
JOHNNY RACER's Avatar
Default hey bebob
if your yok was so good, you wouldn't have to proclaim it on other threads. DOH!
JOHNNY RACER is offline   Reply With Quote
Old 09-11-2001, 02:38 PM   #135
bebob's Avatar
I just want all you TOTALY CRAP 3 racers to see what -- car you are racing!!!!!!!I think ,wait I know my old TL01 is better!!!!!!!!!!!!!!!
Later MONKEYMAN!!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
