Old 03-04-2002, 09:36 AM   #1291
TPhalen's Avatar
R/C Tech Charter Subscriber
I would suggest replacing BOTH blocks.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 03-04-2002, 01:59 PM   #1292
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
TP > thanks for the rear toe fix, i know i did it that way. You racing tomorrow or this weekend? HP is on the 10th
Cant wait to try the one way trick. next time i blast the bearings.
wolfeman09 is offline   Reply With Quote
Old 03-04-2002, 06:59 PM   #1293
The problem with taking the seals out of the bearings is that by the end of the day they arn't as free as they were with the seals in because of the dirt that got in the bearings.
In the tranny tends not to get dirty but in the hubs, even with just the inner seal removed somehow dirt seems to get in.
patcollins is offline   Reply With Quote
Old 03-05-2002, 07:49 AM   #1294
TPhalen's Avatar
Removing the seals WILL require you to do maintenance a bit sooner than if you didn't remove them, but, the performance difference should make up for that.
I will be at the HP race this weekend...
I heard it might rain Thursday...hope that comes and goes before the weekend!!!!
Tony Phalen
RCDriver.com
CompetitionX.com
Old 03-05-2002, 08:16 AM   #1295
Jack Smash's Avatar
Trader Rating: 29 (100%+)
After hearing about TP's holy grail of transmission freeness, I decided to see if all the hours I put into freeing my car up paid off. I took the motor out of my car, spun the front wheels forward, and "whalla", the shaft moved about a 1/4 turn.
Jack Smash is offline   Reply With Quote
Old 03-05-2002, 09:29 AM   #1296
Tech Legend
Wild Cherry's Avatar
Jack, here`s a couple of things you can do to "free up" your ride that was`nt mention...
* make sure you have installed bearing spacer`s on the outboard bearing hubs...(make`s a big differents)
* check the gear mesh in both transmissions, if the gear mesh is set to tight you what to slim the gears so they spin freely...
*remove the rubber O-rings from the drive shaftcups...
Check all of your bearing`s especially the front outboard bearing`s.....
After you have done all of this you will still need to run the car a few pack`s to break in the gear`s again.....
Hey Tony,
Mind spins so free you can get it to spin by blowin on the spur gear.( and thats with-out a one- way)......
Wild Cherry is offline   Reply With Quote
Old 03-05-2002, 09:32 AM   #1297
How does taking the o-ring out of the drive cups free everything up?
Modena AL is offline   Reply With Quote
Old 03-05-2002, 10:16 AM   #1298
Tech Legend
Removing the o-ring`s dos`nt free up everything...
It help`s though...
Stops the drive shaft from binding when it rotates....
Old 03-05-2002, 10:21 AM   #1299
TPhalen's Avatar
I would NOT suggest removing the o-ring. In a frontal crash, the o-ring prevents the shaft from slamming into the drivecups which will almost certainly result in a broken shaft. We ran the car alot in the beginning with out the o-ring found that this little .25c part will help prevent the shaft from breaking.
Free just by blowing on it, huh??? Have to try that....
The Blow Test. I like it...heh heh
Tony Phalen
RCDriver.com
CompetitionX.com
Old 03-05-2002, 10:39 AM   #1300
linger's Avatar
This is rated PG site. No blowing TC3's.
linger is offline   Reply With Quote
Old 03-05-2002, 12:47 PM   #1301
51
51's Avatar
Default Reedy Race
Tony,
Hey have you ran at the Tamiya track yet? (Site of the Reedy TC Race) I was wondering what you thought of the surface, what the dimensions are, and what the general layout is like (sweeping, tight, mix, etc.) Any idea what the AE host hotel is going to be? A few of us should be making the trek out there come May, and I need to start mentally preparing ...
-Brent
51 is offline   Reply With Quote
Old 03-05-2002, 01:29 PM   #1302
TPhalen's Avatar
I ran at the Tamiya track a couple years ago before I had sponsors. I was trying to win the trip to Japan (which, when I finally borrowed a friends car, I probably could have). My car was just crap that weekend. You cannot run any car on that track except a Tamiya car. BOOO!
As I understand it, they are closing the Tamiya track to redo it. Larger, more pit spaces, and bleachers. It's gonna become a true first class facility. Until then, NO ONE is allowed on it so not to take a 'home track' advantage (Tamiya drivers could get hundreds of battery packs on their cars while others couldn't - because it's a Tamiya track). So, not sure yet.
And sorry, not sure of the hotel, either....this is one of the first BIG races I'll be heading to that I can go HOME after each night of racing....happy about that!
Tony Phalen
RCDriver.com
CompetitionX.com
Old 03-05-2002, 01:41 PM   #1303
linger's Avatar
The Reedy Race:
Tamiya recently repaved their track right before the 3 hour enduro race. Attached is a link to some of the pics I took a few months ago.
The track is smooth and freshly paved. The rumor is that Tamiya is happy with their track and they are not redoing it for the Reedy race. If that's the case, I have a TA04 that I can rent out to run at the track.
The bigger question is: are they gonna make us use them crappy H13 tires again???
http://www.geocities.com/lingkang_tong/Tamiya.html
-ling
Old 03-05-2002, 01:42 PM   #1304
D_Ames's Avatar
Send a message via AIM to D_Ames
I live about 2 miles from the Tamiya track. If they are going to remodel it, they haven't started yet. At least it looks the same to me.
As far as hotels, there really isn't anything cheap in the area. People will probably have to stay around the El Toro area.
I mean, you could stay at the Ritz Carlton if you wanted to. Its about 5 miles away and $400 a night.
HMMM!! Maybe I'll rent a room out and make some money......
D_Ames is offline   Reply With Quote
Old 03-05-2002, 03:24 PM   #1305
TPhalen - regarding the 1-way (in back and/or front). Would a
combo diff/1-way device help with the backwards 1-way in
the rear? Since slippers are not allowed, it seems that the
diff action would help prevent one tire from breaking loose and
giving more rear grip on power.
Likewise, would AE consider the equivalent of a pulley 1-way (in a
traditional 2-belt car)? Maybe a slipper-like device like what Schumacher had on their adjustable one-ways on the Axis,
but adapt it to the shaft drivetrain. Or the "clicker" of the
Street Weapon. They would have the advantage that one
could dial in the amount of 1-way as needed if the
diff 1-way is too much.
rainblows is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
