Old 02-11-2016, 01:22 AM   #12136
heretic's Avatar
Originally Posted by gigaplex View Post
I'm in a similar boat, just in the process of replacing the NiCD/Brushed config with something a bit more modern. The tweaks you've made look good, although I didn't see an option to specify TC4 shock towers. Not that I have them, but I might do so eventually
I think the TC4 towers have 4 holes right? So you can use the sheet as is for TC4 towers, by using the 4th hole on the rear TC3 tower (the hole for the body post screw).
The TC3 towers are funny. Right now I have the composite ones on my car and just by the weight of the car resting on its wheels you can see the tower flex a little bit. I'm reluctant to install TC4 towers, because I'm cheap and it makes the car look too much like a TC4, haha !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 02-11-2016, 01:47 PM   #12137
IndyHobbies.com's Avatar
What's hard to find these days is the blue TC3 parts. There were many by associated and other aftermarket companies too. A friend of mine took all his blue stuff and all of mine an created this one. Its as blue as we can get it. So, if you have any BLUE stuff, you want to get rid of, let me know! LOL
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 05-10-2016, 09:30 PM   #12138
DMD
Originally Posted by angrymelon View Post
Well I managed to do it. With a 6200mah pack the car sits at 1445 grams. I actually had to add a 7 gram lead weight! I still havent put on the carbon rear tower, or the titanium hinge pins, so more weight loss is possible.
I'm sitting at 1425 grams with a 5000 mah lipo. I'm running the LTC-R lightweight body. I am having great results running a 13.5 setup.
DMD is offline   Reply With Quote
Old 06-16-2016, 04:19 PM   #12139
Capelracer's Avatar
Wow, the TC3 is alive & well!!!
Just pulled mine out, haven't run them since the early 2000's when my son & I used to race them.... Now it's the grandkids turn, I've still got boxes of parts, def time to resurrect them!!
Capelracer is offline   Reply With Quote
Old 06-18-2016, 08:20 AM   #12140
USVTA #144
Old 06-18-2016, 09:41 AM   #12141
DMD
Way to go Cap! The process of rebuilding and relearning setups has been very satisfying. The fact that this chassis is still competitive against todays onslaught of technical wizardry is mind blowing. Sure beats spending $400 on a new kit. Although, the new Serpent rig looks very interesting. Have fun with the grandkids sir.
Old 06-18-2016, 01:09 PM   #12142
Switch to a blitz(0.5mm) gsf v2 and you will lose 30+grams instantly, getting you down to 1395grams or less.... In addition, you could use tape to secure your lipo pack, and shave another 12 grams , bringing you close to the 1380grams minimum weight.... Cheers....
bertrandsv87 is offline   Reply With Quote
Old 10-04-2016, 05:52 PM   #12143
gigaplex's Avatar
I went to install the TC4 braces onto my TC3 last night since there's been much talk about how there are much more adjustment options with them. I've noticed that even when using the short black ball stud with no spacers, the joint sits much higher than the stock TC3 setting. Hopefully I like the higher positions on the track, otherwise I'll have to go back to the old parts.
I also broke one of my rear suspension arms by screwing in a 0.300 ball stud for the lower shock mount - the thread is about 1mm longer than the hole in the TC3 suspension arm
gigaplex is offline   Reply With Quote
Old 10-04-2016, 06:08 PM   #12144
Roar minimum weight went down to 1350grams, so you will have 75grams to shed fast..... BERT mods ????
Lighter body, battery, servo, drivetrain, diffs/spool/axles, dogbones, screws, etc, .....
Old 10-05-2016, 05:14 PM   #12145
For what it's worth I have three of the super light bodies. I run on medium to large outdoor tracks and I run 21.5 and 17.5 TC. The bodies flutter. I will not be purchasing the 55 gram +/- bodies again. I will purchase the 85 gram bodies +/-.
SouthFloridaApp is offline   Reply With Quote
Old 10-05-2016, 07:21 PM   #12146
I think these superlight bodies were designed mainly for indoor carpet racing, not outdoors... You also can try the foam body post dampers(tight body pins) in addition to extra foam on the front bumper to minimize the fluttering effect...
Old 10-05-2016, 08:42 PM   #12147
gigaplex's Avatar
Or you could just use a functional body. There's no use compromising the performance of many aspects of the car just to reach minimum weight. It's a minimum requirement, not a maximum. I've seen people cut their lap times by adding weight.
The easiest way to cut weight without too much compromise on a TC3 is to use a shorty battery and mount the ESC on the battery side to balance weight. Unstable bodies, custom fabricated drivetrain components etc are not reasonable recommendations.
Old 10-05-2016, 09:27 PM   #12148
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
The one guy who has researched how to lighten a TC4 (many can be used on a TC3), more than anyone is Burt.
Race application, some don't work, some work very well.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 10-05-2016, 09:32 PM   #12149
gigaplex's Avatar
I think most of us are aware already, I've seen his TC4 suggestions referenced in just about every TC thread I've seen on here.
Old 10-06-2016, 06:50 AM   #12150
DARKSIDE's Avatar
it pointless if you are not racing....cant give advise if the advise you give isn't tested
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
