Old 06-24-2014, 01:03 PM   #12076
angrymelon's Avatar
Originally Posted by Cancun Tom View Post
I have an early TC3. The trans ratio is: 2.5:1
So to obtain a FDR of 3.6 I would need to run a 72 T (48pitch) spur with a (48 pitch) 50T pinion......that just doesn't seem right??? Am I missing something here? My tires are 2.57"dia. so that would give a roll-out of 2.25"
I am able to get the lower ratios running these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYGN4
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYGN3
They are a direct bolt on. I then pair them with 34 to 37 tooth pinions. I did have to remove some of the webbing behind the motor mount to make room for the larger pinion.
-melon
angrymelon is offline   Reply With Quote
Old 06-24-2014, 01:24 PM   #12077
IndyHobbies.com's Avatar
I bought a used TC3 recently. I've got three others. What's different about this one is that the chassis tub is in great shape, but there are no pads on the chassis for the droop screws to press against. The A-Arms don't have droop screws either.
Earlier version of the TC3?
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 06-24-2014, 04:56 PM   #12078
oreo's Avatar
Greetings Indy. I'd picked-up a used roller several years ago and discovered the same thing(s). I was always under the impression that this [chassis] was a rally car version of the TC3.Anyways, i'd held on to it as a parts car-it's still whole in a drawer.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 06-24-2014, 05:46 PM   #12079
moparSRT's Avatar
yes, on the first TC3's droop was adjusted with shocks later came the extra hole for shock position and droop screw known as V2. Arms with droop setting will work just fine on that chassis ... there is just enough for the set screw to rest on
rally coversion was just 200mm arms, cvd's & turnbuckles, a new bumper, longer shock shafts with buggy springs and some wheels and tires.
moparSRT is offline   Reply With Quote
Old 06-24-2014, 06:05 PM   #12080
A question for rc gurus
Which scenario would be more preferable. A larger spur gear and a larger pinion gear or a smaller spur and a smaller pinion gear....
55/37--- 3.7162 final drive for tc4 or
52/35--- 3.7143 final drive for tc4.
Would one be more durable or efficient than the other?
I know this is the tc3 thread but u guys were talking about gearing..
SouthFloridaApp is offline   Reply With Quote
Old 06-24-2014, 10:18 PM   #12081
azeroth's Avatar
Trader Rating: 20 (100%+)
personally i would use what made the car balanced better with the rest of my componants
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 06-24-2014, 10:38 PM   #12082
Smile
I would go with the 55/37 just because of the better gearing range for most motor: 17.5t, 21.5t, 13.5t(big track)..
bertrandsv87 is online now   Reply With Quote
Old 06-24-2014, 10:44 PM   #12083
Smile
I would suggest the the 60T, I think it allows the largest range of pinions. I am on the third summer season with the same spur using Novak 21.5 blinky....Or for the price get a 55 and a sixty. Some guys here run 55 some 60, You pays your money and takes your choice !!!!! The 52T limits pinion size in the other direction. Have fun!!!!
BE
THEBIGBULL is offline   Reply With Quote
Old 06-25-2014, 08:56 AM   #12084
Thanks MoparSRT and Oreo! Knowledge gained.
USVTA #144
Old 06-25-2014, 06:02 PM   #12085
oreo's Avatar
.....Knowledge indeed.For what it's worth, after crap-tastic day of work especially a race day during the winter months[when I can't race because of work], i'd open the drawer where my tc-3's are,and tinker a little.....eventually leading to a Diggity conversion.
Rc 10L (x6)
Old 07-31-2014, 08:09 PM   #12086
Jason Baliban's Avatar
Hey guys,
Just pulled my TC3 off the shelf for some fun and the first thing i need to do is replace the wheels/tires. I have tried reading through this insane thread and still have some questions about what wheels will fit on there.
I am looking at the HPI 26mm wheels but i am seeing some say they fit right on and others saying you need to drill the holes. Some are saying i need to get the aluminum hexes.
I have a V1 team kit with the plastic hexes.
Can anyone let me know what the best approach is for replacing the wheels?
Also, any other obvious upgrades?
Thanks so much!
jB
Jason Baliban is offline   Reply With Quote
Old 08-25-2014, 08:04 PM   #12087
Originally Posted by Jason Baliban View Post
Hey guys,
Thanks so much!
jB
For those that might have the same question....
I bought the HPI 26mm wheels and they fit right on the stock hexes without a problem.
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Old 08-25-2014, 08:10 PM   #12088
Just ordered a full set of Avid bearing for the TC3. Here is a list of what i bought.
(8) 3/16 x 3/8 x 1/8 Revolution - Hubs
(4) 3/16 x 5/16 x 1/8 Metal - Diff
(4)1/8 x 1/4 x 7/64 Metal - Steering
(3) 3/16 x 3/8 x 1/8 Ceramic Revolution - Input shaft outside Front, Input shaft rear, and Drive bearing
(1) 3/16 x 3/8 x 1/8 Ceramic Metal - Input shaft inside front
(4) 3/8 x 5/8 x 5/32 Ceramic Revolution - Outdrive Hubs
jB
Old 10-12-2014, 10:04 AM   #12089
Indy RC Racer built this TC3 for me out of as much BLUE stuff as we could find! We raided his parts box and mine. Together, we have a BLUE beast! Yes, that's a brushed motor, but it was BLUE! Indy RC Racer says there is more blue TC3 stuff out there that he's seen over the years, so I'll start looking... The KISS body I airbrushed was the BLUE-est one I had.
TC3 Forum-img_7791r.jpg   TC3 Forum-img_7792r.jpg   TC3 Forum-img_7793r.jpg   TC3 Forum-img_7794r.jpg   TC3 Forum-img_7795r.jpg
USVTA #144
Old 10-12-2014, 04:58 PM   #12090
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
I've seen blue aluminum diff covers, control arms, chassis braces and a few other things.
Mike Zadler
Associated TC3 VTA (RIP 4/23/17)
AudioStylz is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
