Old 07-10-2013, 08:28 AM   #12001
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
The spur gear shaft where the main shaft connects both diffs, without the center shaft I have some play in that area. On all of my TC3's and I've had 5 or 6 total they all had this similar play in that area. Never had an issue with anyone of them either.
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Old 07-10-2013, 10:24 AM   #12002
Rodarbal's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to Rodarbal
Originally Posted by misplacedtexan View Post
Is this normal? Can someone let me know?
I haven't had issues with the rear, but I've had similar play with the front diff. I swapped diff housings to an older one that I had as a spare and it eliminated the play. Not sure if there were some "bad" housings made for these cars, but I wonder if you just happened to have two sets of rear cases that are more open.
RJ Labrador
On Road: Tamiya & XRay
Off Road: Losi, Mugen & XRay
Rodarbal is offline   Reply With Quote
Old 07-10-2013, 11:49 AM   #12003
misplacedtexan's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Rojna View Post
Its not normal for the shaft to have play when the diff is mounted in the car and that shaft is supported by 2 bearings, 1 in the diff case and 1 on the chassis.
It is normal for it to have play when the diff case is out of the car and the shaft is supported by 1 bearing at that time.
Appreciate the help, this was in pieces when I got it, and I was finally able to round up most of the parts it was missing, and the outer bearing support was one of them.
Thanks again for your help Rojna!
misplacedtexan is offline   Reply With Quote
Old 08-28-2013, 02:38 PM   #12004
My new TC3 for VTA, this one will be set up for asphalt, chassis was cut out a little to add flex.
Rojna is offline   Reply With Quote
Old 08-28-2013, 02:50 PM   #12005
Where did you get the center brace and battery hold down from?
Old 08-28-2013, 02:55 PM   #12006
nice job.
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 08-28-2013, 03:07 PM   #12007
center brace is from a TC6, just cut down a little, I cut out the webbing in the center of the chassis, top brace is there to protect the drive shaft.
Battery brace is from ae http://www.teamassociated.com/parts/details/31039/
Old 08-28-2013, 03:25 PM   #12008
Here is a pic of the bottom, all done with a dremel.
Old 09-04-2013, 01:56 AM   #12009
Trader Rating: 69 (100%+)
Delete
bullet100 is offline   Reply With Quote
Old 10-04-2013, 06:51 PM   #12010
I have a tc3 factory car, niftech front and rear diffs (and rebuild parts), titanium shaft,full niftech bearings, niftech cvds...PM me if you are interested
TLR SCTE 3.0
TLR 22SCT 2.0
Powered by SMC and Tekin
JMURACN is offline   Reply With Quote
Old 10-05-2013, 06:00 AM   #12011
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
So Rojna its been a month, how are you finding your tc3 vta? been running it?
I found the tc3 still competitive in VTA. The guys who will spend themselves on new T4s etc.etc.. and are good drivers are hard to keepup with.. but whats new?
James
Xray T3'11 (17.5t spec)
Xray T3'11 CanVTA
12rr BMI 1/12
Bikerbob is offline   Reply With Quote
Old 10-05-2013, 09:13 AM   #12012
James
Ran it last weekend back to back with my FT TC4 in vta, times were pretty much the same throughout the day with my fastest lap going to the TC3 by.2sec.
The TC3 has the same chance of winning as anything out there, all about the driver now if I could only be more consistent and stay away from the walls
Old 10-06-2013, 10:47 AM   #12013
Bikerbob's Avatar
Well guys, just sold my TC3 to someone new who will be using it for a new driver. Love this car for that.
Thanks for all the tips and tricks.
Xray T3'11 CanVTA
12rr BMI 1/12
Old 10-20-2013, 11:47 AM   #12014
Does anyone know of a company that has a carbon chassis still in production? I am trying to set up a second car.
kylecav is offline   Reply With Quote
Old 10-20-2013, 12:44 PM   #12015
IndyRC_Racer's Avatar
You might try this company - Xtreme Racing (http://www.xtremercracing.com/TC3302.cfm)
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
