Old 07-03-2013, 07:01 PM   #11986
jerrie_RcRacer's Avatar
I would like to show you guys my nitro tc3 that I'm building for racing but I have no clue on how to post pictures :/ please help. Will appreciate it. Thanks.
jerrie_RcRacer is offline   Reply With Quote
Old 07-04-2013, 02:33 PM   #11987
RussF's Avatar
Trader Rating: 21 (100%+)
Best way I've found is to use a photo editor (I like MS Picture Manager) to size them smallish like 640x480, get yourself a photobucket or similar hosting website account, and post/link the pics here. There might be easier ways and I know theres some other methods posted here somewhere, but I like this method as I can link the pics to any post I make on any site or just link a whole album.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 07-08-2013, 08:11 PM   #11988
EM1-TC3's Avatar
Default Apex Touring Car Diff
Hi, I was wondering if anyone has tried or looked into these Apex sealed gear diffs as an alternative to the ball diffs?
Associated # 31413
Thanks,
EM1-TC3 is offline   Reply With Quote
Old 07-08-2013, 09:32 PM   #11989
azeroth's Avatar
Trader Rating: 20 (100%+)
i thought i saw earlier in this thread about a gear diff install
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 07-08-2013, 09:38 PM   #11990
EM1-TC3's Avatar
Yeah I sent a PM to the original poster and he no longer has the car and said there's a lot of fab work to make it work in the case. This looks like a drop in replacement.
Old 07-09-2013, 06:52 AM   #11991
misplacedtexan's Avatar
Trader Rating: 27 (100%+)
I just got a TC3 about a month ago used(first road car), and started tearing it down to go through everything and rebuild. Got to the rear diff where the spur is, and the pinion shaft in the case moves up and down!!?? It only has 1 bearing and this just doesn't seem normal to me. I need some feedback on this for sure.
It is a FT kit and has the steel diff out drives.
Can someone shed some light on this?
Confused
And this is the electric version.
misplacedtexan is offline   Reply With Quote
Old 07-09-2013, 06:55 AM   #11992
Originally Posted by misplacedtexan View Post
I just got a TC3 about a month ago used(first road car), and started tearing it down to go through everything and rebuild. Got to the front diff where the spur is, and the pinion shaft in the case moves up and down!!?? It only has 1 bearing and this just doesn't seem normal to me. I need some feedback on this for sure.
Confused
you need 2 bearings on that shaft, download the TC3 manual from the AE web site, it will help you with ??? like this.
Rojna is offline   Reply With Quote
Old 07-09-2013, 07:18 AM   #11993
The drive hub for the spur sits in the outer groove, the one bearing it has is next to the pinion gear that sits in the inner groove. Manual has it that way, am I missing something here?
I said it's the front, I meant the rear.
Old 07-09-2013, 07:45 AM   #11994
the spur hub goes on the rear diff, not the front.
Old 07-09-2013, 08:05 AM   #11995
build it exactly like the manual shows
Old 07-09-2013, 08:09 AM   #11996
I did, this ain't my first rodeo building r/c, just my first on road.
Old 07-09-2013, 08:11 AM   #11997
Already corrected myself, had one of them thar' brain farts!
Old 07-09-2013, 08:13 AM   #11998
I was thinking maybe the case might be wore out, but I swapped cases and it's the same thing.
Old 07-10-2013, 05:40 AM   #11999
Confused
Is this normal? Can someone let me know?
Old 07-10-2013, 07:14 AM   #12000
Its not normal for the shaft to have play when the diff is mounted in the car and that shaft is supported by 2 bearings, 1 in the diff case and 1 on the chassis.
It is normal for it to have play when the diff case is out of the car and the shaft is supported by 1 bearing at that time.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
