Old 02-22-2002, 11:15 PM   #1186
Jack Smash's Avatar
Trader Rating: 28 (100%+)
MX5 - a one way allows the front wheels to free wheel when off power so that breaking is done only by the rear tires. This allows all of the traction capability of the front tires to turn the car. Also the front wheels are locked together on power(no diff) and this gives a little more agressive steering when on the throttle.
Jack Smash is offline   Reply With Quote
Old 02-22-2002, 11:23 PM   #1187
MX5
Thanks for the info. I've seen one-ways talked about but didnt know what it did. Just got TC3 few weeks ago. I run it on carpet track and it seems to push too much. Maybe one-way would help.
MX5 is offline   Reply With Quote
Old 02-23-2002, 12:39 AM   #1188
Originally posted by Type S
modena al u have a pm
PM recieved and response sent
Modena AL is offline   Reply With Quote
Old 02-23-2002, 04:59 AM   #1189
Default oneways and carpet
If you run foam tires on carpet a one-way is not a good idea, rubber tires on carpet can benefit from a one-way.
If you hit the boards a lot a one way is not a good idea because you will end up breaking drive shafts or the oneway.
patcollins is offline   Reply With Quote
Old 02-23-2002, 09:35 AM   #1190
Trips's Avatar
Trader Rating: 16 (100%+)
pat,
Could you explain why a oneway isn't good for foams on carpet?
Thanks,
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-23-2002, 12:29 PM   #1191
robk's Avatar
Trader Rating: 22 (100%+)
i'm not pat but i have run one ways on carpet. A shaft,(or in the case of belt cars, layshaft) one way, can be used sometimes. In the case of the TC3, it tends to help the car roll thru the corners better without upsetting the balance too much. Depends on the car though. The one way diff usually is too much though. The difference between on and off power steering can be pretty violent, and the car tends to be really unforgiving off of the corner. In other words if you get on the power with the wheels still turned you go right into the board. And they feel really inconsistent and squirrelly. In other words turn all the one ways bad habits on rubber tires up to 11.
Old 02-23-2002, 02:02 PM   #1192
Bingo
Its just pretty much one of those "rules" I heard it from some people that have won national events in sedan with foam on carpet so I never really questioned it.
One-ways are best used on flowing tracks where you don't use brake. I don't think I have ever seen a flowing carpet track due to size restrictions indoors.
Old 02-23-2002, 11:27 PM   #1193
ottoman's Avatar
R/C Tech Charter Subscriber
Trips....I always wondered why they say not to use a oneway with foams. I always run a oneway on carpet but I only run rubber. I have noticed that the factory drivers setups for foams never seem to have oneways but they always run one for rubber tires. Any ideas why?
ottoman is offline   Reply With Quote
Old 02-24-2002, 04:34 AM   #1194
dw
So why do associated supply a starting set up for 1 way with foams on their website?
dw is offline   Reply With Quote
Old 02-24-2002, 08:45 AM   #1195
The One Way with rubber allows the car to have more turn in and exit speed.
The Onw Way with Foams is overkill. You already have enough traction that adding the one way will make the car over sensitive.
OUTofCONTROL is offline   Reply With Quote
Old 02-24-2002, 10:57 AM   #1196
DW can you point out that setup on Associated site, I dont see a setup for carpet with foams and a one-way.
Old 02-24-2002, 05:48 PM   #1197
Pat, it is in the manual as well as the tuning guide.
Old 02-24-2002, 06:35 PM   #1198
The setup in the middle that says carpet with foams up top?
I think its being misinterpreted. Look at it it says
General
1. Battery Position: rear
2. Oneway or Diff: Diff
It says use the diff
Old 02-24-2002, 07:20 PM   #1199
TPhalen's Avatar
Whew....
Gone a couple days and I spend 30 minutes reading post on all the threads...my eyes hurt...
...and it's not due to any drugs from the '60's....heh heh
One-ways with Foams on carpet is overkill to the MAX!!! That's alot of steering. One-ways with Rubber tires, on the other hand...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-25-2002, 07:32 AM   #1200
blueboy's Avatar
Has anyone noticed that if you swap the rear hub carriers/uprights/whatever round (put left upright on right wishbone etc) then you can get 0 degrees toe in?
They don't tell you that in the manual do they, its just "yeah, buy this bit, then this bit, then this bit..."
blueboy is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
