Old 04-06-2013, 07:44 AM   #11971
Originally Posted by heretic View Post
Wrong. I've used the TC4 braces on several TC3s and there is no need to use TC4 shock towers.
Originally Posted by SS LS1 View Post
Rojna, when using TC4 chassis braces you do not necessarily need to use TC4 shock towers but many do. We have guys at the track using TC4 braces with the camber links relocated but still have the stock TC3 shock towers.
That depends on the type of ball cups you use ... would you race like this ??
Rojna is offline   Reply With Quote
Old 04-06-2013, 08:53 AM   #11972
heretic's Avatar
I filed my RPM ball cups a little and it was fine. As long as I can freely rotate the whole camber link back and forth on its balls with my fingers I know it's working fine. Or you could dremel the tower a little, or both. Not enough of a problem to justify the purchase of 2 shock towers IMHO. I already have a bunch of TC3 front towers I'll probably never use again, no need to render the rears obsolete as well ;- )
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 04-06-2013, 09:01 AM   #11973
heretic's Avatar
You might want to cut the inner part of the braces to gain some flex. You probably know about it anyway. That doesn't get you nearly as much flex as today's cars but still better than the ultra-stiff stock setup.
One day I'll have to experiment a bit more to try and get torsional flex out of the stock chassis. Even the composite version too stiff. Maybe mill down the center webbing, of lower the sides of the bathtub... or both... Maybe cutouts on the electronics side...don't know yet. One day...
I already use a center brace between the F and R gear cases so I'm not worried about longitudinal flex.
Old 04-06-2013, 07:05 PM   #11974
SS LS1's Avatar
Trader Rating: 23 (100%+)
No, but I wouldn't race with rusty anti-sway bars and screws on my car either. ......... J/K with you
I do however see your dilemma with using RPM ball cups.
Like I said before the TC4 towers are not necessarily needed. For example the guys at our track running TC3 towers and TC4 braces are using the stock ball cups so there is no interference issues on their cars like you are having.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 04-07-2013, 08:08 AM   #11975
IndyHobbies.com's Avatar
Here's our three TC3's. The first one is our best and runs really great in VTA. I've worked on it and had some help from IndyRCRacer on it too. Drives great and can win in the the A Main in the hands of a better driver than me.
The second one is set up for "Sportsman" class which uses a silvercan motor (21.5 equiv.). That class has passed in Indy, so I'm going to convert this one over to another VTA car. My son is currently using it for a drifter on carpet. Works great for that too.
The last one is not being used right now. Its your basic TC3. I'm planning on keeping it for parts or maybe a chassis for a scale build I'm planning. Not sure. Right now, I've got a Parma '34 Ford Truck body mounted on it (bottom pic). Its a perfect fit. So, I may just put some basic components in it, all my old stuff, and get it drivable.
TC3 Forum-tc3chassis-1.jpg   TC3 Forum-tc3chassis-2.jpg   TC3 Forum-tc3chassis-3.jpg
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 04-15-2013, 06:52 AM   #11976
I pulled the guts from my TC5 that was set up for VTA, and have put them into my #2 TC3. I just haven't been happy with the TC5 in comparison to my TC3. Seems crazy that the older car works better, but it does.
Worked on it on and off over the weekend. Since my long time VTA TC3 has been so good, I decided to try to match it, setting for setting, degree by degree on this other TC3. We'll find out Friday night how successful I was and if its as good as my other car.
Using a new 25.5 Ballistic Novak with a Havoc Pro ESC. Steering servo is a Futaba S9452. I've got three of these and really like them.
USVTA #144
Old 04-15-2013, 07:44 AM   #11977
Rodarbal's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to Rodarbal
I've got a couple of them as well and love them. It seems it's often overlooked by racers in favor of the low-profile S9551.
RJ Labrador
On Road: Tamiya & XRay
Off Road: Losi, Mugen & XRay
Rodarbal is offline   Reply With Quote
Old 04-15-2013, 10:33 AM   #11978
sixace's Avatar
Default gearing help
Hi guys,
I recently picked up a used TC3 for VTA use. Never had a sedan type car before (pan and F1 guy). While there is great info on this thread, slogging through almost 12,000 post is a bit much (plus my search skills are lacking).
Indy, I see in your pics that you mark your spur/pinions on the chassis (thanks). In the last pic, is that an 84/55 for a FDR of 3.81?
I'll be running carpet, and some parking lot asphalt, and research seems to lead me this FDR may be in the ballpark.
My car came with the stock 48p (72t?) spur and I don't believe I can fit a big enough pinion to get where I need to be. I'll be swapping to 64p and here is my question:
Will a standard 64p Kimbourgh spur work on the TC3 or do I need to order an "AE" specific one? Where would one get them from? Any mods needed to run that big of a pinion?
If it matters, I'l be running the Novak 25.5 ballistic.
Any other gearing tips appreciated, especially from the Austin/Porter/EOS gang (RJ?).
Thanks!
sixace is offline   Reply With Quote
Old 04-15-2013, 11:11 AM   #11979
beemerfan's Avatar
Trader Rating: 34 (100%+)
A 76 tooth Kimbrough will bolt right in and give you a nice range with just a few different pinions for VTA racing. You may have to take down the chassis webbing under the pinion gear to work with the larger pinion sizes.
beemerfan is offline   Reply With Quote
Old 04-18-2013, 07:57 AM   #11980
Yes that's the FDR exactly. That seems to be about right for the track I've been running on. Like Beemer said above, I've had to use the dremel to remove some webbing below the gear. Not a problem, just a quick little modification.
The Kimbroughs fit just fine.
USVTA #144
Old 05-08-2013, 01:53 AM   #11981
slowclod's Avatar
here's a pic of my tc3 before I sell it. closest track is over a hour away and that doesnt work with my schedule so I've decided to let it go
TAMIYA- CLOD BUSTER, BULL-BUSTER, CUSTOM CRAWLER
LOSI- XXX, XXX-BK, XXXT-MF
ASSOCIATED- TC3 VTA, RC10 x2, RC10-T
HPI- RS4 MINI
slowclod is offline   Reply With Quote
Old 05-08-2013, 04:03 PM   #11982
smittyusmc's Avatar
How much do you want for it?
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 05-08-2013, 04:07 PM   #11983
slowclod's Avatar
You have a pm
HPI- RS4 MINI
Old 05-27-2013, 12:54 PM   #11984
slowclod's Avatar
decided to keep my tc3. I sold my tc4 instead. front diff is bad so I need to rebuild. I don't plan on racing it much but at least it will be ready when I do. one thing I am missing is a motor cam so I am looking for one
HPI- RS4 MINI
Old 05-28-2013, 07:46 PM   #11985
Thumbs up
Stormer Hobbies has in stock...Part #ASC3930 or try Fleabay, search associated TC3 in toys and hobbies. Good luck!!!
THEBIGBULL is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
