Old 03-09-2013, 01:22 PM   #11941
IndyHobbies.com's Avatar
Taking it completely apart will give you a chance to clean that puppy up too. Just use your wife or girlfriend's toothbrush to get in the nooks and crannies. Just remember to clean the toothbrush again before you put it back with her things...
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 03-09-2013, 02:38 PM   #11942
slowclod's Avatar
can't do that because she's gonna wonder why I won't kiss her anymore.
I have like 50+ brand new cleaning brushes that I got from work so I won't have to use hers.
slowclod is offline   Reply With Quote
Old 03-10-2013, 06:16 AM   #11943
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
DUDE!! TC3 forum is a mans man forum --- Laugh say she will never notice that you used her brush and give us our moment.. LMAO!!
(hope my wife does not read this!!!!)
James
Xray T3'11 (17.5t spec)
Xray T3'11 CanVTA
12rr BMI 1/12
Bikerbob is offline   Reply With Quote
Old 03-10-2013, 03:29 PM   #11944
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
My TC3 will be making it's debut this Tuesday night unless something comes up and prevents me from making it.
I still have a list of things to do with my TC3.
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Old 03-12-2013, 09:36 PM   #11945
BadPanda818's Avatar
Trader Rating: 16 (100%+)
I have really under estimated my tc3. Last Sunday, it was up against 415, 417, t2, and t3's and it completely decimated at my local track. At first the tc3 ran into problems due to spur stripping out and suspension set up being out of spec. With all deficiencies aside, the car proved it's worth. Running consistent sub 18 sec lap times compared to my Tamiya TA06 with sub 19 sec lap times. gear consist of "see signature below" with 5.07 FDR with 135 F temp after 10 min race. After the second race, a handful of racers decided to check out my chassis and was dumbfounded that it was a tc3. Don't let your tc3's go. Keep the chassis strong and hopefully AE would re-release the chassis like what they did with the tc4
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 03-13-2013, 07:04 AM   #11946
tc4 was never discontinued
Rojna is offline   Reply With Quote
Old 03-13-2013, 09:56 AM   #11947
GeekSpeed's Avatar
Guys, I am getting back into racing and am bringing my old TC3 out of retirement. I am looking for some suggestions on suspension setup. I am running on a well-maintained, prepped outdoor asphalt track. I would say that it has medium-high to high grip. The tires I am using are Sorex 36R. My car is a standard TC3 model with the aluminum shocks, but otherwise stock. I am going to run novice class, so something that is easy to drive and as neutral as possible would be what I am looking for.
Any suggestions? Thanks!!
GeekSpeed is offline   Reply With Quote
Old 03-13-2013, 10:03 AM   #11948
Oh that's my fault. I thought that it was re-release when the club racer came out. Thanks for the correction
Old 03-14-2013, 11:09 PM   #11949
AudioStylz's Avatar
GeekSpeed, I've raced VTA a few times at my local track on the parking lot during the summer. Carpet setup vs pavement setup were slightly different and most of it was in shock oil. I run Silver front springs with 35wt oil and green rear springs with 30wt oil on carpet. For the pavement I went 25wt front and 20wt rear. You can't go softer on springs unless you run green front and rear. The other thing I ended up doing was raising my ride height 1.5mm from 5mm just to help clear some of the bigger rocks/pebbles that might get kicked into the racing groove from other cars that might get pushed into the marbles. Another suggestion, get another set of tires just for pavement. The tires I used for carpet then for pavement were junk in 2 weekend worth of racing. When I got new tires they lasted the rest of the summer with minimal wear.
Just my experience with pavement racing. Your results will vary, lol.
Really the best thing to do is just get out there and start working with 1 thing at a time. No other way to go about it other then just doing it.
Mike Zadler
Tamiya M-05
Old 03-25-2013, 05:44 PM   #11950
Trader Rating: 44 (100%+)
Anyone got a good basic setup for CARPET VTA?
Justin33 is offline   Reply With Quote
Old 03-28-2013, 09:11 PM   #11951
Three's Avatar
Will the TC4 steering rack fit/work on the TC3?
Electric good..........
Three is offline   Reply With Quote
Old 03-28-2013, 10:04 PM   #11952
Hi Guys,
I've had fantastic success with my TC3 over the summer in New Zealand. I have won the National Championships in Touring Stock (Silver can) and also won the Southern Clash in the Super Stock class (13.5 Turbo). It can easily still keep up with the newer chassis, especially in the stock classes.
ixlr8nz is offline   Reply With Quote
Old 03-29-2013, 07:58 AM   #11953
you will need to grind the chassis webing and drill 2 holes to make the tc4 steering work.
Old 03-29-2013, 09:16 AM   #11954
Three's Avatar
So its like the nitro TC3 steering mod?
Old 04-02-2013, 09:10 AM   #11955
AudioStylz's Avatar
Setup the suspension to be soft, very soft.
I run silver spring in front with green in the rear. 35wt in front with 30wt in the rear. Shock position outer hole in from control arm with the top in the middle and my current rear control arms only have 1 shock location with the rear shock in the middle on the shock tower. No sway bars since I don't have any. Ride height is a touch high.
I have yet to play with shock location or ride height on my TC3 because of how well it handles right now on carpet. I can run lap times a few tenths off the top5 drivers but not as consistently as them yet. I haven't played with my camber link mounts yet either but later this summer I plan on getting the TC4 chassis braces and shock towers. Better camber link locations and more shock position locations.
Mike Zadler
Tamiya M-05
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
