Old 12-15-2012, 06:39 AM   #11851
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Originally Posted by bo duke View Post
just bought a tc3 today, were is a good place to buy parts?
im comparing the tc3 and the tc4 I bought and im not seeing much diiference. I see the chassis is different in the two and a arms but is there anything else. im a complete noob .
Tower Hobbies and Stormer Hobbies still carry about all the TC3 parts.
As for shared TC3 and TC4 parts, best to look at the manuals and see if the part numbers are the same.
http://www.teamassociated.com/manuals/discontinued/
For the TC3,
http://www.teamassociated.com/manuals/TC4/
For the TC4.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 12-15-2012, 07:03 AM   #11852
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
There are some shared parts but some are different. The tc3 was a much stronger kit, the 4 a little faster if you could stop tearing it apart. When the 4 first came out many quickly decided not to go there from the 3 as not enough changed for the better.
Team Associated webstore has some stuff and some Online places have aftermarket parts. Get a manual for the 3 and the 4 and you can see if you can sub the part in - but I'm pretty sure if they used the same part it has the same part# so you will know that way.
Spare arms!!! Front drive shafts hubs and carriers - its very hard to break much else.
But as bull said - keep an eye out for someone flogging a roller and parts - strip it and you have your spares.
James
Bikerbob is offline   Reply With Quote
Old 12-19-2012, 12:58 PM   #11853
IndyHobbies.com's Avatar
These may help. You can print them or save the files. I printed them and then took a highlighter and went through them to see what parts were the same, and which were unique to the TC3 or TC4.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 12-23-2012, 06:12 PM   #11854
Bikerbob's Avatar
TWEEK?
I thought because of the body type chassis tweek was not really an issue.
I have a car setup.. suspension is rebuilt, droop is set, springs are set.. everything is in place,
but the weight on the 4 wheels is messed up.. the RR and LF are light.. and visa versa.. and off by more than 150g
Does this chassis tweek? and any other ideas what I am dealing with here??
James
Old 12-23-2012, 06:12 PM   #11855
Bikerbob's Avatar
Hmm posted my msg twice.. sorry.
Whats a good 64p combo for 17.5 blinky? I am using 60 37 in 48p but its really LOUD!
Thanks.
Old 12-26-2012, 11:18 PM   #11856
Thumbs up
Originally Posted by Bikerbob View Post
The point of saying that the battery was not in.. was saying that that the rear of the car is fairly balanced without the battery in.
In fact the battery in makes it worse. SO upfront on the non-servo side LH - its out by 150g - wow.... I can load lead on the front corner of the chassis but that will add weight over all and not specific to that corner.
Guess I am wondering if I should rebuild it again. If its common for this car to be out on that corner.. ????
James
Balancing my TC3 Tubbie with 3200 Lipo (212g)
LF...308G ...... RF....313G = 621G (48.0 %)
LR...337G ...... RR....341G = 678G (52.0 %)
Total Wht W/O body = 1299G W/B = 1450G.....68 HPI Camaro
(MUCHO SHOO GOO)
I balance it using one 600G scale and 3 3/4 inch plywood blocks. I
use a tweak bar to get it close. Then put the scale under one wheel
compress susp and read scale, carefully move scale to another wheel
compress susp and read scale, Do all four wheels, adjust shocks
accordingly. I had to add a lexan shim to the top of the scale to
get the same level as the ply blocks. Gets close enough for me.
We run 1430g min wht (NOT my choice) 21.5 motor No boost ESCs.
I won 2 mains and finished second once last summer We race on a
sugar water prepped track 80' X150'. Runs great nicely balanced. I
run it once in a while in TC stock and it is competitive. I replaced the
tub with an IRS carbonfiber chassis. So come Aprill I can give that
a try.
Be
TJ
THEBIGBULL is offline   Reply With Quote
Old 12-27-2012, 11:12 AM   #11857
Bikerbob's Avatar
See topic TC3 shaft in onroad forum.. I smoked my drive shaft this morning, just by testing the motor???#@$? no idea.. love to hear opinions.
James
Old 12-27-2012, 12:04 PM   #11858
Smile
I run all my driveshafts floating(no foam spacers at the ends), and never screwed a driveshaft ever , even with mod motors !
bertrandsv87 is offline   Reply With Quote
Old 12-31-2012, 05:47 AM   #11859
Bikerbob's Avatar
Carpet - small track - 9 sec laps - 17.5 blinky. looking for a carpet suspension setup.
One I followed was a AE driver pre-brushless - no sway and no uplimit. I feel i am getting too much roll, need more cornering.
Anyone have or point to link of 17.5 setup for small carpet I can use as a starting point?
James
Old 01-06-2013, 08:02 PM   #11860
Bikerbob's Avatar
Well I was out with the TC3 running our Canadian VTA which is 21.5
I was not planted very well.. I would be loose in the back and usually pushing in the front.
I have silver up front and gold in the read. Droop is factory I think, and I have adjusted for 5mm rideheight all around.
I am back to running VTA - I just like it better, so .. upper control arms - long or short? Caster Camber? what are people using on their tc3 for vta.
I run the HPI Camaro body.. sits kind of high.. need to get it planted.. suggestions for getting the car more solid.. do people run swaybars for VTA?
James
Old 01-06-2013, 08:03 PM   #11861
Bikerbob's Avatar
Old 01-06-2013, 08:35 PM   #11862
try a softer rear spring, should be softer then front.
so with a silver front go with a green rear, or put the silver in the back a blue up front.
Are you using tracktion compound ?? if so full front and rear ?? if so try full rear and 1/2 front or less.
Rojna is offline   Reply With Quote
Old 01-06-2013, 09:23 PM   #11863
WongTamiya's Avatar
How do I upgrade the tc3's steering to the ntc3 or tc4 steering system? I don't like the steering rack.
Julian Wong
Why so serious?
WongTamiya is offline   Reply With Quote
Old 01-06-2013, 09:47 PM   #11864
azeroth's Avatar
Trader Rating: 20 (100%+)
long upeer upper hole inside and shim up rear shock tower 3mm with 3 toe i am running green frt and rear 35w front 30w rear
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 01-06-2013, 11:18 PM   #11865
Thumbs up
CTA TC3, Ballistic 21.5, GTB2, 1450g with Team Checkpoit 3200lipo
Track 36' X80' Older CRC carpet
Front Spring Silver 35wt assoc oil
Rear Spring Green 30wt assoc oil
5mm ride height
Front diff slightly tighter than rear
Rear camber links long and high
Standard droop setting
SXT3.0 full front and rear
I get quite a bit of chassis roll, Car is very neutral, turns in good. I might try small front sway bar to reduce roll ????
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
