Old 12-29-2011, 03:38 PM   #11686
DaveW's Avatar
Originally Posted by beemerfan View Post
I've experimented with different shimming options and always wind up back to what the instruction manual says. I think it is the way to go. I do believe the requirements are different between plastic or metal diffs.
Hes referring to removing plastic inside the diff casing to keep from binding the bearings/diff when the two case halves are screwed together. Shimming the diff and layshafts are kinda self explanatory.
The shock tower screws will press down on the case just over the bearing race. Its best to drill and tap out the two tower holes on each case that ride over the diff bearing race. This removes most of screw installation stress and bearing fit inconsistencies related to case/tower bolt tightness.
After that you want your diff bearings to ALMOST fall out of the trans case holes when installed and tilted by hand. A large Dremel fine sanding drum used by hand to remove high spots will get the job done right. Minimal binding will give you a cooler running motor, freer driveline, and predictable throttle response.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-17-2012, 08:56 PM   #11687
This has been bugging me since the last time I hit the carpet, when I let off the throttle at the end of the straight to make a right turn, the car just spins out without any brake application. I have no drag brake on it, camber is at -1.5 degrees on all four wheels, could this be a diff issue?
Machine1 is offline   Reply With Quote
Old 01-17-2012, 09:31 PM   #11688
Trader Rating: 75 (100%+)
Here are some possible ideas:
  • too much rear droop
  • car is tweaked or has wedge (check on a 4 corner scale setup if you have access to one; otherwise check that the preload on your springs is equal
  • shock issue (a shock has leaked it's oil out and is transferring weight to the front end too fast when you let off)
  • cracked chassis, bent hinge pins, other damage
TC3+parts for sale
I race at:
SpeedWorld Raceway
Roseville / Sacramento, California
VTA, 1/10 nitro, touring, USGT, F1, and more!
www.speedworldraceway.com
slashdriver is offline   Reply With Quote
Old 01-18-2012, 07:20 PM   #11689
I will start by rebuilding the shocks. The car has sat for a few years.
Old 01-18-2012, 11:51 PM   #11690
I'd go for a full rebuilt, you cannot expect an "old" car that wasn't touch for a few years to perform like a newly buit chassis.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 01-19-2012, 08:54 AM   #11691
Yes and I also went from nimh brushed to lipo brushless power.
Old 01-19-2012, 09:02 AM   #11692
Your balance is likely way off then. lipo is much lighter. measure carefully the front and back of the chassis and mark a spot on dead center, then use two xacto razors to balance the car on these marks. add lead to the light side (the lipo side) until the car balances. this could take a few ounces..
TC3+parts for sale
I race at:
SpeedWorld Raceway
Old 01-24-2012, 08:27 AM   #11693
Is there a benefit to running the new vcs3 shocks on a tc3? Just curious my shocks are pretty beat up and need to be replaced if I should just go with the newer design?
gguertin145 is offline   Reply With Quote
Old 01-24-2012, 09:28 AM   #11694
they might be a bit smoother, but probably nobody has used the new tc6 shocks on a tc3. the tc6 is a metric car so the mount sizes MIGHT be different, and the lengths might be different too??
You are probably better off to use the regular tc3 shocks, unless you want to tinker/try something new/are willing to do a little tweaking if necessary.
TC3+parts for sale
I race at:
SpeedWorld Raceway
Old 01-25-2012, 07:52 AM   #11695
EM1-TC3's Avatar
I got a set of Tamiya Racing Factory shocks ( item # 42102 ) and absolutley love them. They're super smooth! I picked them up on eBay for $50 shipped from Tokyo but for approx $80 you can get them quicker by buying from a US seller. It took under two weeks to get them so it's a matter of how fast you need them. I used green slime on them 3 months ago and they have not leaked at all unlike my original AE Team shocks
EM1-TC3 is offline   Reply With Quote
Old 01-25-2012, 07:56 AM   #11696
EM1-TC3's Avatar
You might want to also mention your TC3 is doing about 50mph down the back stretch into that turn
Old 01-25-2012, 09:53 AM   #11697
Default tc3 manual
Anyone have a factory team tce manual 4 sale?
narkix is offline   Reply With Quote
Old 01-25-2012, 10:04 AM   #11698
SteveM's Avatar
Trader Rating: 128 (100%+)
http://www.teamassociated.com/pdf/ca...tc3_manual.pdf
http://www.teamassociated.com/cars_a...anuals_setups/
SteveM is offline   Reply With Quote
Old 01-25-2012, 12:00 PM   #11699
Thumbs up tc3
my printer broke down, i just wanted original manual if anyone had 1
Old 01-25-2012, 12:07 PM   #11700
actually I know we have one local racer running these on a tc4. Do you have any limiters inside of the shocks or have you had to adjust the lengths any?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
