Old 11-22-2011, 08:20 PM   #11626
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Hey I want to run my LRP x12 17.5 boosted. What timing should I have on the motor? It's on -10 right now.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 11-23-2011, 12:53 PM   #11627
On the 10.5t the 4 dot comes std, but I run mine on 0 in boosted mode, then it all depends on what speed controller you are using and its settings.
If it is a Tekin RS/pro or HW 120A i can help, other speedos...sorry cannot
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-23-2011, 05:02 PM   #11628
The esc is a Tekin RS.On the back of my motor the timing insert is tilted to the far right.
Old 11-24-2011, 09:01 PM   #11629
Angry asiatees
Originally Posted by Aries326 View Post
2 months? Shoot, I start going crazy after something doesn't arrive a few days after someone has promised it will arrive. I'd cancel the order and cancel it from your credit card if they've already charged you for it.
Same with me, but my part was shipped. The part is still in HK. 4 months no part my money is gone to. I ordered the same part from them but on Ebay.
gspiess1 is offline   Reply With Quote
Old 11-25-2011, 10:12 AM   #11630
I used Asiatees with no problem, they even look for feed back after delivery, this was the first time I bought things from them, they look sound to me, delivery was fast.
got steering and caster blocks but I do not like the little plastic pin holders (the one you screw a grub screw) it had a tendency to pull out if you screw too much, had to glue mine in place first.
Old 11-25-2011, 10:14 AM   #11631
If you open the plastic endbell (one screw) you can remove it and see what is the insert, to the right is 4 dots.
I would recommend a fan on top of motor too, X12 loves heat.
Give me your setup and I can direct you, I just help a fella with a 21.5t and he has improve a lot.
regards
Old 12-10-2011, 09:39 PM   #11632
Anyone know where i can get the small nuts that go into the chassis that the motor clamp bolts go into? I'm missing one. LHS didnt have ones that would fit, i tried taking a nut to a bench grinder to shrink it down but that didnt turn out so well,... AE doesnt list it on the parts explosion for the kit,.. does it come with a new chassis or can I get it separate?
Mattpar is offline   Reply With Quote
Old 12-10-2011, 09:42 PM   #11633
beemerfan's Avatar
Trader Rating: 34 (100%+)
http://www.amainhobbies.com/product_...inum-Locknut-5
beemerfan is offline   Reply With Quote
Old 12-11-2011, 01:38 AM   #11634
oreo's Avatar
Default ....4-40 threaded...
Greetings. An alternative to your LHS, a computer store probably has the nut in-stock; it's a 4-40 nut and the computer store (ie Radio Shack) may have nuts without the nylon( a.k.a. a jam nut or non-locking). If you broght the
TC3 with you to the store , the sales person will get a better idea of what you need.Good luck.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 12-11-2011, 06:37 AM   #11635
It's one of these:
http://www3.towerhobbies.com/cgi-bin...&I=LX2507&P=ML
Kevin Marcy is offline   Reply With Quote
Old 12-11-2011, 07:40 AM   #11636
unfortunately the nuts yall mentioned i think will be too big.
The factory nuts are realllly small. The thread is 4x40, but the overall diameter is smaller than the typical 4x40nut. The sliver nut on the right is one from the LHS, the gold lock nut is a nut from my losi, still too big to fit in the recess.
Tired grinding it down but just ended up butchering the nut,.
I'll try radio shack, or Ace Hardware. Hopefully they will have something. I'll report back if i find something!
Old 12-11-2011, 08:09 AM   #11637
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Kevin Marcy View Post
Originally Posted by beemerfan View Post
I just looked at the manual, Associated part number 4449 are the right ones; I think those links are the ticket.
http://teamassociated.com/pdf/cars_a...rtr_manual.pdf
See page 18.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 12-11-2011, 09:19 AM   #11638
beemerfan's Avatar
Yes they are the right ones. Both Associated and Losi used a "mini" locknut in various places on their cars. This link, http://www.amainhobbies.com/product_...rce=google_ext, is to the Losi ones which will work as well. I have 4 TC3s built and a couple more in spares and can verify they are the correct nuts. The standard size 4/40 nuts more commonly found are what is pictured above. Buy a pack because you'll want to have some extras around. They do "sneak" out unnoticed sometimes when working on motor adjustments.
Old 12-11-2011, 03:58 PM   #11639
awesome!!! I was looking the parts explosion team associated had on thier website and it didnt list the nuts separate. Didn't look in the owners manual. I'll order up a fews. Thanks!!!!!
Old 12-11-2011, 10:53 PM   #11640
vti-chris's Avatar
Any problems with the part availability of this car?
Will i be better off with a TC4??
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
