Old 08-30-2010, 09:50 PM   #11446
AdminD's Avatar
Default Tc3 brace take off.
Any one know , is it safe to take off the (rear-right) brace during races?
I was Planning for easier pinion change.
Sliders
AdminD is offline   Reply With Quote
Old 08-30-2010, 10:07 PM   #11447
beemerfan's Avatar
Trader Rating: 34 (100%+)
Attached are some photos. Depending on how far you want to go, you are not done with the motor mount alone. The chassis may need milling (or Dremeling) in several areas. The chassis reinforcement below the pinion in particluar. You may also need to remove some of the outer reinforcing wall next to the motor as well as the rear wall to allow space for the sensor wire. And in some cases, you may need to modify the right rear chassis brace. Check the pictures, they're worth a thousand word explanation. With all these mods combined, I can get a 62 tooth pinion in with an 84 tooth spur (64 pitch) for a final drive ratio of 3.39. That gear ratio isn't of much use though on anything but an oval layout, so you probably don't have to go as far as I did. It was a trial and error learning process for me.
TC3 Forum-tc3-motor-mount-mods-002-large-.jpg   TC3 Forum-tc3-motor-mount-mods-003-large-.jpg   TC3 Forum-tc3-motor-mount-mods-004-large-.jpg   TC3 Forum-tc3-motor-mount-mods-006-large-.jpg   TC3 Forum-tc3-motor-mount-mods-009-large-.jpg
beemerfan is offline   Reply With Quote
Old 08-30-2010, 10:10 PM   #11448
beemerfan's Avatar
You will get more flex around the motor mount which could affect your gear mesh. However, I've never had any problem running the modified brace pictured in the previous post. But I didn't do it for the purpose of easing pinion removal and I've never really tried to get the pinion out without removing the motor first.
Old 08-30-2010, 10:55 PM   #11449
AdminD's Avatar
great advice, will try to mod that brace, if could be wear to be easier pinion changing, as i will loosening the motor cam mounting, hope this is the solution, by keeping the chassis rigidity.
Sliders
Old 08-31-2010, 10:02 AM   #11450
DaveW's Avatar
Good lookin work Beemer!
Spur/pinion mesh flex is a potential issue for a composite tub if youre racing on HOT asphalt. Pick your tub up and give her a twist after a 6 minute run on some 130+ degree asphalt.
If youre racing on rubber tires, torsional flex consistency is more important than overall chassis rigidity. As long as you dont strip gears, then have at it.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 09-01-2010, 07:29 AM   #11451
beemerfan's Avatar
When I started milling out parts of my chassis around the motor mount I was a bit concerned about unwanted flex or tweak. But I'm on my third chassis with the similar mods and I've been racing with all of them. So far I haven't had any problems on the hot summer asphalt. However, these are the molded graphite tubs, not the plastic ones and I only race stock or spec classes. I've also milled the center ribs down and then reinforced them with a piece of 1/16 model aircraft plywood and epoxy allowing the battery to sit closer to the shaft. This mod helps balance but I also think the wood and glue add to the chassis rigidity. The cars have been excellent performers in VTA.
Old 09-01-2010, 09:05 PM   #11452
Thumbs up Re...TC3 gearing for VTA
All you have to do is get a robinson 68 tooth 1/12 scale spur and replace the the associated spur and it brings the gearing back in line. I think I'm geared 68 to 33 or 34 for an 80 X130 asphalt track with a 21.5 Ballistic motor. Got this tip from a friend of mine, works good!!!!
TJ
THEBIGBULL is offline   Reply With Quote
Old 09-02-2010, 03:35 AM   #11453
peter george's Avatar
Trader Rating: 323 (100%+)
TJ
thats good info thanks to every body ,now with the new rules (25.5) does any body know the new pinion /spur combo?
Team Underdog-Team UPURZ-Island Raceway & Hobby-If we trade lower feedback always ships first.Team Associated B5m-CRC-Durango DEX210-DESC210-Intech-Eagles of Death Metal-Tylenol
peter george is offline   Reply With Quote
Old 09-05-2010, 02:28 PM   #11454
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Hey "beemerfan" what ball caps are those your using?
AE FT TC3 "VTA"
AE FT TC6.2 blinky cert.d4 17.5
AE B5m lite TP 17.5
BIG DADDY8 is offline   Reply With Quote
Old 09-05-2010, 02:52 PM   #11455
DaveW's Avatar
Theyre Schumacher ballgrippas...
Old 09-05-2010, 04:47 PM   #11456
BIG DADDY8's Avatar
Whats the part #? Theres a bunch of different ones and sizes?
AE FT TC3 "VTA"
AE B5m lite TP 17.5
Old 09-05-2010, 06:11 PM   #11457
beemerfan's Avatar
I honestly don't know anything about them except that they are Schumachers. The car in the photo was an eBay special that came with those ball links already installed. I do like them though. They stay on much firmer and operate much smoother than anything associated has ever made.
Old 10-28-2010, 11:04 AM   #11458
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
Put this page up front
hotrodchevy14 is offline   Reply With Quote
Old 10-28-2010, 11:15 AM   #11459
I am hoping someone can point me in the right direction. I am looking for the thread about modifying the motor cam in order to run larger pinions. Thanks in advance..
Old 10-28-2010, 11:39 AM   #11460
beemerfan's Avatar
Did you catch the photos at the top of this page in post 11447?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
