Old 06-01-2010, 06:18 PM   #11386
DaveW's Avatar
Thanx Tre.
A slipper spool is used in place of the front diff for more steering on rubber tire setups. Its less abusive to the front driveline components than a solid spool, and now even cheaper to assemble/use with the Tc5 pads.
DaveW is offline   Reply With Quote
Old 06-01-2010, 07:50 PM   #11387
bjholz's Avatar
Here is my Brushless setup
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Sav÷x, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 06-01-2010, 08:13 PM   #11388
Timbulb's Avatar
Originally Posted by DaveW View Post
Thanx Tre.
So can I just remove the ball bearings and add the slipper pads?
Timbulb is offline   Reply With Quote
Old 06-01-2010, 09:21 PM   #11389
DaveW's Avatar
Originally Posted by bjholz View Post
Here is my Brushless setup...
Looks good BJ... you race carpet or asphalt? Spring choice suggest carpet...
I gave everything a thorough cleaning, and removed both diff rings and the diff balls. You HAVE to use the regular steel outdrives. The lightweight steel outdrives have material removed where the pads would seat, and the plastic outdrives wont handle the abuse. I seriously doubt if you could make more than a few turns with a plastic slipper spool and aluminum CVD bones.
A front steel diff/spool is optimal anyways. Its more durable, and adds weight over the front for more steering.
Old 06-01-2010, 09:23 PM   #11390
bjholz's Avatar
Looks good BJ... you race carpet or asphalt? Spring choice suggest carpet....
Thanks! Yup carpet!
www.trackside.com
Old 06-01-2010, 09:39 PM   #11391
What low profile servo is that?I like the way you fitted a GTB in there without stacking the receiver.The work you have done there is jaw-dropping.I like what I am seeing...It was worth the wait
tc3jp is offline   Reply With Quote
Old 06-02-2010, 04:51 AM   #11392
bjholz's Avatar
futaba s9551
www.trackside.com
Old 06-02-2010, 04:12 PM   #11393
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Does anyone still have or make an after market woven graphite chassis still?
AE FT TC3 "VTA"
AE FT TC6.2 blinky cert.d4 17.5
AE B5m lite TP 17.5
BIG DADDY8 is offline   Reply With Quote
Old 06-02-2010, 05:24 PM   #11394
azeroth's Avatar
Trader Rating: 20 (100%+)
http://www.diggitydesigns.com/D3_OnRoad_Products.html
http://www.teamirsrc.com/tc3.html
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 06-02-2010, 07:24 PM   #11395
pejota's Avatar
Thanks for the info on the slipper pads, definitely gonna give that a try.
How far do you tighten the diff screw? Or maybe a better question is, how far do you back off the screw from full lock?
pejota is offline   Reply With Quote
Old 06-02-2010, 08:19 PM   #11396
DaveW's Avatar
No problem.
I tightened the screw till the gear wouldnt slip with reasonable force. It only needs to be tight enough to resist 'diffing' as the car corners, to simulate a spool. Its not used for traction control (like a slipper clutch). I can imagine a lot of slippage would cause too much heat and destroy either the pads, the plastic gear, or both.
The idea is to let the spool slip on impact, like if you clip a board or hit something... so the shock to the driveline doesnt break or bend front end parts. Im sure there will be some trial and error, but start on the tight side, and work your way back.
Old 06-02-2010, 09:33 PM   #11397
The Diggty Designs chassis set looks awsome.But I can't imagine the open gear concept lasting very long where we race outside.The gears would lock up sooner or later.
Old 06-03-2010, 02:05 PM   #11398
BIG DADDY8's Avatar
We run on asphalt here too. I don't like the open diffs either. The IRS is $180. Thats too much for a vintage.
STILL LOOKING............
AE FT TC3 "VTA"
AE B5m lite TP 17.5
Old 06-03-2010, 06:59 PM   #11399
trerc's Avatar
Trader Rating: 89 (100%+)
All of the woven chassis I can think of were designed during foam tire hay day and are thick as bricks and not designed to flex or be optimal for low traction rubber tire racing we are doing today. IMO you are better off with the tub, especially on asphalt not to mention I can throw my tubby down outside and not really worry about scratching up the plastic tub chassis. Tubbys are just fun.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 06-03-2010, 09:36 PM   #11400
IndyRC_Racer's Avatar
Another company that makes a carbon fiber chassis for the TC3 is Xtreme Racing. Here is their TC3 product page (http://www.xtremercracing.com/Page.c...D=2995&Search=)
Obviously an carbon fiber conversion chassis won't be cheap, but I was very happy with the quality of the oval conversion kit that I bought.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
